Question about Dell OptiPlex GX280 PC Desktop
On my pc monitor appears " Floppy diskette seek failure"
    Scholar:
  • 97 Answers
If you do not have a floppy diskette drive as you have stated, it may be the case that your BIOS has the floppy as the first device to boot from even though you don't have a floppy - I'm guessing, so I could be wrong.
Try to get into your BIOS (F2) and check out what the boot order of devices is. If a floppy is first or occurs prior to your CD drive, then put your CD first before the hard disk drive and eliminate anything else.
thanks & regards
Anas K A
Posted on May 28, 2011
  • 243 Answers
To remove the message just go to bios, press f2 when you turn on your computer, press enter in boot menu, set first boot in hdd and second boot in cdroom (using + - key)and disable boot from floppy by pressing the space bar
Go to advance and if there is any setting about swap or seek from floppy make it disable
Hope it helps
4 Suggested Answers
SOURCE: floppy diskette seek failure
F2 Scroll down to "Drives" and open the menu. choose "Diskette Drive" and turn it "Off".
Posted on May 19, 2008
bigbiggs
  • 326 Answers
SOURCE: my pc go to diskette drive 0 seek failure
U'r hard drive is not communicating with the system. Open the pc (power off) and check the cable connections. While U'r there, clean with blow or vac. U'r HD may have died. The data may still be there and got to with a new hd.
Posted on May 23, 2008
try to go to bios set up..then change the boot order..in the boot tab,,change the "first boot" label with hard disk..then it wont seek for floppy again..
Posted on Jan 05, 2009
The floppy disk or drive is damaged, or if your trying to boot your computer and you have a floppy in the drive that is not bootable. It will try and boot from floppy first then cd then hard drive usually but floppy's are stupid and only return an error and then stops. Remove the floppy disk and boot
Dec 06, 2013 | Dell Dimension 5100 (D51L1) PC Desktop
Dell optiplex 745 Floppy Diskette Seek Failure
how to solution. Dell optiplex 745 Floppy Diskette Seek Failure
Jan 20, 2012 | Dell Computers & Internet
"Floppy Diskette seek Failure Strike F1 key to
maybe the floppy disk drive is defective or maybe the IDE cable is deffective, or maybe the cable on the floppy drive is not properly inserted , try to replace IDE cable of the floppy drive if still the symptoms happens replace the floppy drive
Jul 20, 2011 | Dell OptiPlex GX520n PC Desktop
My dell dimension 9200 is booting and then giving me a Floppy Diskette Seek Failure message. What is causing this to appear and not boot windows 7?
Hi. You computer seems to be booting up using the floppy disk and your floppy disk drive might not be connected properly, not working or not even there. Press F2 to run the setup utility and disable the floppy seek in the bios. It will most likely be in the "Advanced CMOS setup" area, or the 2nd screen depending on your bios. look for "Seek floppy drive at boot?" or, "Disable floppy seek at boot?" or something like that. When you find it, make sure it's not enabled for the seek. Save the change on exiting. :-)
Jun 05, 2011 | Dell Dimension 9200 PC Desktop
My Dell desktop computer is plugged into a master switch. But I still have to turn on the computer to use it. Lately when I turn on the master switch, the computer turns on automatically. But the Windows...
Press F2 to enter the system setup. Someone or something (Bad Motherboard battery most likely) has reset the BIOS defaults, which includes the Floppy diskette drive controller to be ON. Set Diskette Drive to NONE, then under integrated Devices, set diskette controller to off, save settings and reboot
(ALT + B)
if issue re-occurs then the watch battery on motherboard is bad and needs to be replaced
Jul 16, 2010 | Dell Dimension 3000® Pentium® 4...
Boot up screen says "diskette drive 0 seek failure"
Press F2 look through the menus and remove / disable 3.5 floppy drives.
Jan 06, 2010 | Dell Dimension 8400 PC Desktop
Boot into setup by pressing F2 or F10 depending on your bios and disable the floppy drive setting.
Jan 14, 2009 | Computers & Internet
Jan 03, 2009 | Dell Dimension E310 PC Desktop
Diskette drive 0 seek failure
Does the PC have a floppy drive? If it doesn't It appears that your BIOS (Basic PC setup) thinks that there is one! I think that pressing f2 on boot will bring you into the BIOS setup.
In there, see can you locate any reference to 3.5 inch floppy and amend it to the setting which suits the config of your PC.
Please take care as to what other settings you change in the BIOS
If you find this sugestion helps please take time to rate it
Aug 30, 2008 | Computers & Internet
Jan 14, 2008 | Dell Dimension 4600 PC Desktop
Dell OptiPlex GX280 PC Desktop Logo
113 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
