Question about Velbon VideoMate Deluxe Heavy-Duty Photographic/Video Tripod 607 w/ FREE UPS
Velbon sx-621 I want to remove the secondary camera mount pin to accommodate a camera that only has a hole for the threaded mount. The steel pin prevents the Nikon camera from mounting onto the top of the tripod. I suspect if I could get the knurled adjusting knob off the bottom of the plate, I could remove the secondary pin, but can't see how to get at the screw that secures the threaded knob for the spring-loaded threaded mounted pin. I tried unscrwing the secondary pin, but just damaged the slot slightly. Perhaps it's just very tightly screwed into the mounting plate? Thanks for your help!
  • 10,865 Answers
Hello cars.... use a pair of vice grip pliers on that steep pin and gently but firmly unscrew it. joe
Posted on Jun 04, 2011
  • Lena Johansen
    Lena Johansen Jul 09, 2014
    Thank you so mutch. Just bought one of this and I thougt i made i mistake. But now i can use it.. Love it
Does the Velbon cx-300 fit most camera's
If your camera has a 1/4" thread socket on the baseplate, it can be fitted to the pan and tilt head in the illustration of this tripod provided by a Google search. The manual should give you definitive information if you are still not sure.
Jan 09, 2017 | Velbon Photography
One wins of the new Nikon 3200 locks in however cannot use camera camera says lens not locked
The contact in the lens is the ground contact. If it does not touch the camera mount the camera will, give an error code and not operate. Remove lens mount and check pin spring operation. If stuck slightly enlarge hole
Feb 14, 2015 | Nikon Coolpix 3200 Digital Camera
How much weight will the Velbon Victory 250 Tripod hold
The tripod will certainly hold your Canon camera and lens. However the limiting factor is the head. Without knowing the head you have mounted on the tripod I'm afraid I can't tell you whether it would hold your camera and lens.
Jul 30, 2012 | Velbon Victory 250 Tripod With Quick...
My speed don't work
Speed Sensors REMOVAL & INSTALLATION Front Fig. 1: The speed sensor sits directly over the exciter ring in the front knuckle 89609p51.jpg
Fig. 2: Detach the speed sensor connector in the engine compartment 89609p55.jpg
Fig. 3: Remove the speed sensor harness from the routing clips 89609p53.jpg
Fig. 4: A special E6 Torx® socket is required to remove the speed sensor retaining bolt 89609p52.jpg
  1. Disconnect the negative battery cable.
  2. From inside engine compartment, detach sensor assembly 2-pin connector from the wiring harness.
  3. Remove the steel routing clip attaching the sensor wire to the tube bundle on the left sensor or remove the plastic routing clip attaching the sensor wire to the frame on the right sensor.
  4. Remove the rubber coated spring steel clip holding the sensor wire to the frame.
  5. Remove the sensor wire from the steel routing clip on the frame and from the dust shield.
  6. Remove the sensor attaching bolt from the front spindle and slide the sensor out of the mounting hole. To install:
  7. Install the sensor into the mounting hole in the front spindle and attach with the mounting bolt. Tighten to 40–60 inch lbs. (4.5–6.8 Nm).
  8. Insert the sensor routing grommets into the dust shield and steel bracket on the frame. Route the wire into the engine compartment.
  9. Install the rubber coated steel clip that holds the sensor wire to the frame into the hole in the frame.
  10. Install the steel clip that holds sensor wire to tube bundle on left side or plastic clip that holds sensor to frame on right side.
  11. Reconnect the 2-pin connector to wire harness. Connect the negative battery cable.
Rear Fig. 5: Detach the speed sensor connector in the luggage compartment 89609p04.jpg
Fig. 6: Grasp the harness and . . . 89609p37.jpg
Fig. 7: . . . remove it from the routing brackets 89609p36.jpg
Fig. 8: The rear speed sensor is mounted on the back of the hub assembly 89609p32.jpg
Fig. 9: Remove the sensor retaining bolt and remove the sensor from the hub 89609p34.jpg
  2. From inside luggage compartment, detach 2-pin sensor connector from wiring harness and push sensor wire through hole in floor.
  3. From below vehicle, remove sensor wire from routing bracket located on top of rear axle carrier housing and remove steel clip holding sensor wire and brake tube against axle housing.
  4. Remove screw from clip holding sensor wire and brake tube to bracket on axle.
  5. Remove sensor to rear adapter retaining bolt and remove sensor. To install:
  6. Insert sensor adapter and install retaining bolt. Tighten to 40–60 inch lbs. (4.5–6.8 Nm).
  7. Attach the clip holding the sensor and brake tube to the bracket on the axle housing and secure with the retaining screw. Tighten the screw to 40–60 inch lbs. (4.5–6.8 Nm).
  8. Install steel clip around axle tube that holds sensor wire and brake tube against axle tube and push spool-shaped grommet into clip located on top of axle carrier housing.
  9. Push sensor wire connector up through hole in floor and seat large round grommet into hole.
  10. Reconnect sensor 2-pin connector to wiring harness inside luggage compartment.
Aug 03, 2010 | 1992 Ford Crown Victoria
NEED AN EXTRA CAMERA MOUNT FOR VELBON CX686. THE PIECE THAT SCREWS TO THE CAMERA
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I’ve seen.
Mar 20, 2010 | Velbon VideoMate Deluxe Heavy-Duty...
Need repair guide for rear brakes 1990 E350 Ford
Ford Full-Size Vans 1989-1996 Repair Guide
Brake Shoes - REMOVAL & INSTALLATION
Light Duty Systems
  1. Raise and support the vehicle and remove the wheel and brake drum from the wheel to be worked on.
If you have never replaced the brakes on a van before and you are not too familiar with the procedures involved, only dissemble and assemble one side at a time, leaving the other side intact as a reference during reassembly.
  1. Install a clamp over the ends of the wheel cylinder to prevent the pistons of the wheel cylinder from coming out, causing loss of fluid and much grief.
  2. Contract the brake shoes by pulling the self-adjusting lever away from the starwheel adjustment screw and turn the starwheel up and back until the pivot nut is drawn onto the starwheel as far as it will come.
  3. Pull the adjusting lever, cable and automatic adjuster spring down and toward the rear to unhook the pivot hook from the large hole in the secondary shoe web. Do not attempt to pry the pivot hook from the hole.
  4. Remove the automatic adjuster spring and the adjusting lever.
  5. Remove the secondary shoe-to-anchor spring with a brake tool. (Brake tools are very common implements and are available at auto parts stores). Remove the primary shoe-to-anchor spring and unhook the cable anchor. Remove the anchor pin plate.
  1. Remove the cable guide from the secondary shoe.
  2. Remove the shoe hold-down springs, shoes, adjusting screw, pivot nut, and socket. Note the color of each hold-down spring for assembly. To remove the hold-down springs, reach behind the brake backing plate and place one finger on the end of one of the brake hold-down spring mounting pins. Using a pair of pliers, grasp the washer type retainer on top of the hold-down spring that corresponds to the pin which you are holding. Push down on the pliers and turn them 90° to align the slot in the washer with the head on the spring mounting pin. Remove the spring and washer retainer and repeat this operation on the hold down spring on the other shoe.
  3. Remove the parking brake link and spring. Disconnect the parking brake cable from the parking brake lever.
  4. After removing the rear brake secondary shoe, disassemble the parking brake lever from the shoe by removing the retaining clip and spring washer.
To install:
  1. Assemble the parking brake lever to the secondary shoe and secure it with the spring washer and retaining clip.
  2. Apply a light coating of Lubriplate®, or equivalent, at the points where the brake shoes contact the backing plate.
  3. Position the brake shoes on the backing plate, and install the hold-down spring pins, springs, and spring washer type retainers. On the rear brake, install the parking brake link, spring and washer. Connect the parking brake cable to the parking brake lever.
  4. Install the anchor pin plate, and place the cable anchor over the anchor pin with the crimped side toward the backing plate.
  5. Install the primary shoe-to-anchor spring with the brake tool.
  1. Install the cable guide on the secondary shoe web with the flanged holes fitted into the hole in the secondary shoe web. Thread the cable around the cable guide groove.
  2. Install the secondary shoe-to-anchor (long) spring. Be sure that the cable end is not cocked or binding on the anchor pin when installed. All of the parts should be flat on the anchor pin. Remove the wheel cylinder piston clamp.
  3. Apply Lubriplate®, or equivalent, to the threads and the socket end of the adjusting starwheel screw. Turn the adjusting screw into the adjusting pivot nut to the limit of the threads and then back off 1 / 2 turn.
Interchanging the brake shoe adjusting screw assemblies from one side of the vehicle to the other would cause the brake shoes to retract rather than expand each time the automatic adjusting mechanism is operated. To prevent this, the socket end of the adjusting screw is stamped with an "R" or an "L" for "RIGHT" or "LEFT". The adjusting pivot nuts can be distinguished by the number of lines machined around the body of the nut; one line indicates left-hand nut and two lines indicate a right-hand nut.
  1. Place the adjusting socket on the screw and install this assembly between the shoe ends with the adjusting screw nearest to the secondary shoe.
  2. Place the cable hook into the hole in the adjusting lever from the backing plate side. The adjusting levers are stamped with an R (right) or a L (left) to indicate their installation on the right or left-hand brake assembly.
  3. Position the hooked end of the adjuster spring in the primary shoe web and connect the loop end of the spring to the adjuster lever hole.
  4. Pull the adjuster lever, cable and automatic adjuster spring down toward the rear to engage the pivot hook in the large hole in the secondary shoe web.
  5. After installation, check the action of the adjuster by pulling the section of the cable guide and the adjusting lever toward the secondary shoe web far enough to lift the lever past a tooth on the adjusting screw starwheel. The lever should snap into position behind the next tooth, and release of the cable should cause the adjuster spring to return the lever to its original position. This return action of the lever will turn the adjusting screw starwheel one tooth. The lever should contact the adjusting screw starwheel one tooth above the centerline of the adjusting screw.
If the automatic adjusting mechanism does not perform properly, check the following:
  1. Check the cable and fittings. The cable ends should fill or extend slightly beyond the crimped section of the fittings. If this is not the case, replace the cable.
  2. Check the cable guide for damage. The cable groove should be parallel to the shoe web, and the body of the guide should lie flat against the web. Replace the cable guide if this is not so.
  3. Check the pivot hook on the lever. The hook surfaces should be square with the body on the lever for proper pivoting. Repair or replace the hook as necessary.
  4. Make sure that the adjusting screw starwheel is properly seated in the notch in the shoe web.
Heavy Duty Systems
  1. Raise and support the vehicle.
  2. Remove the wheel and drum.
  1. Remove the parking brake lever assembly retaining nut from behind the backing plate and remove the parking brake lever assembly.
  2. Remove the adjusting cable assembly from the anchor pin, cable guide and adjusting lever.
  3. Remove the brake shoe retracting springs.
  4. Remove the brake shoe hold-down spring from each shoe.
  5. Remove the brake shoes and adjusting screw assembly.
  6. Disassemble the adjusting screw assembly.
  7. Clean the ledge pads on the backing plate. Apply a light coat of Lubriplate®, or equivalent, to the ledge pads (where the brake shoes rub the backing plate).
continue...
Jan 15, 2010 | 2002 Ford E350
Lost mount for tripod can I get a new one?
Velbon QB-4W Quick-Release Platform is a nearly identical replacement for the plates that come with the Dynex tripod. You buy it from:
http://www.amazon.com/s/?ie=UTF8&keywords=velbon+quick+release&tag=googhydr-20&index=electronics&hvadid=3155273537&ref=pd_sl_6aoq8ub9ut_b
Apr 28, 2009 | Cameras
Missing Tripod piece (Quick release)
What you can do is find a local welder or metal shop in your area. Take the tripod with you, and ask them to fabricate a aluminum or steel replacement "shoe" for your tripod. Also have them drill a hole in the center so you can later insert the proper threaded screw that will mount to your camera. You may want to take your camera and get the proper threaded bolt first before you get the shoe made, so they can make the hole the correct size. You can go to any hardware or home improvement store and ask for assistance to find the right thread for you camera equipment. The bolt should not be any longer than1 inch, so it will mount tight on your plate.
** Note you want a flush mount type bolt that when tightened on the plate is smooth on the bottom** This is so when you mount the shoe in the head, it will be properly seated.
Aug 02, 2008 | Gemini Sound Products Jeva 60 Tripod
Velbon 5000
On the bottom of your camera there will be a threaded metal socket. It should look silver in color and appear like the inside of a hardware nut -- threads that a bolt can screw into.
On the top of the tripod is a threaded bolt that fits into the socket on the bottom of the camera. Place the bolt gently into the socket, align it with the camera and gently turn it to the right (righty-tighty) to engage. Be careful not to strip the threads by tightening without aligning the bolt and the camera.
You should tighten it to where it is snug but don't force it.
Dec 17, 2007 | Photography
Photography Logo
480 people viewed this question
Top Velbon Photography Experts
Bill Eager
Are you a Velbon Photography Expert? Answer questions, earn points and help others
