Question about Casio FX-115ES Scientific Calculator
Hi there. I'm using Casio FX-570ES scientific calculator. I would be glad if you could guide me as to how to obtain derivative of a polynomial expression e.g. y=12(x^2+6)^5
  • Casio Master
  • 7,993 Answers
Here is an example. Instead of SIN(X) insert your polynomials.
The syntax of the command is
Hi there.
where function is the expression you are differentiating
x is the value of variable x at which you are evaluating the derivative, and tol is the tolerance (the error) you are willing to tolerate in the result.
If you do not want to specify a tolerance just omit the last comma and tol.
To enter the command d/dx you use key sequence [SHIFT][Integral]
To enter the symbol x in the expression you press [ALPHA][ ) ]
To enter a comma you use [SHIFT] [ ) ]
To enter a power of 10 in the tolerance use [x10^X] key
Example : Calculate
The key sequence is as follows
[SHIFT] [Integral] 3 [ALPHA] [ ) ] [X^2] [-] 5 [ALPHA] [ ) ] +2 [SHIFT] [ ) ] 2 [SHIFT] [ ) ] 1 [x10^X] [(-)] 12 ) [=]
DO NOT confuse [SHIFT] [ ) ] which enters the comma and [ALPHA] [ ) ] which enters the varHi there. I'm using Casio FX-570ES - k24674_76.jpg>
Posted on May 28, 2011
I would be glad if you could guide me as to how to know the Factor Theorem using calculator.eg.P(X)=X3(cube)-6X=5. How to know the X value, and then the substitute the value X, the equation become 0.
Posted on Jun 27, 2011
Hi,how can I calculate median using fx-570es plus?
The median is the number is the middle.
Using the calculator, you can follow the Statistical Calculations (Stat) on pages 22 and 23 of the attached manual. http://support.casio.com/pdf/004/fx-570_991ES_PLUS_E.pdf
However, it might be quicker to just put the numbers is order from lowest to highest and pick out the number in the middle.
For example, take the numbers 3, 5, 4, 7, 6, 4, 9.
Putting them in order, we get 3, 4, 4, 5, 6, 7, 9
There are 7 numbers so we want the 4th number (3 numbers to the right and 3 numbers to the left). In this case, the 4th number is 5 and that is our median, as half the numbers are lower than it and half the numbers are higher than it. It the number of numbers is even, you take the average of the two middle numbers.
Good luck,
Paul
May 16, 2016 | Casio Fx-570es Scientific Calculator
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Dec 03, 2015 | Casio Office Equipment & Supplies
How to solve y3-113y2+350=0
You can try to factor the polynomial. If not you can find approximate roots graphically: You draw the function y=x^3-113x^2+350 then examine the graph to locate the zeros, i.e the values of x where the function is equal to zero.
Jun 22, 2013 | Casio Fx-570es Scientific Calculator
Fx 570es or fx 570es plus
Get the Plus. It adds a few functions, takes nothing away, and is the same price at most vendors.
Sep 04, 2012 | Casio FX570ES Scientific Calculator
How to find values of x in higher order equations(above cube) on casio 570 ES?
In equation mode, you have system of linear equations (3 unknown) you have polynomial (quadratic and cubic), and solver. Use the solver foe any type of equation (nonlinear, polynomial of order higher than 4, trigonometric, exponential, logs).
May 21, 2012 | Casio Scientific Calculator Fx-570 Fx570...
How do you find the derivative without values for x
I am not sure I understand what you want, but if I am guessing right, you need to calculate formulas for derivatives, where the name of some variable appears eg= d(x^2)/dx = 2 x.
Sorry, the calculator does not have a CAS, you cannot perform symbolic calculations regardless of the subject (derivatives, integrals, sums of series, factoring polynomials, expanding polynomial products, polynomial division, etc.)
Feb 08, 2012 | Casio FX-9860G Graphic Calculator
I'm using fx-570ES..i couldn't find the inverse matrix using the method shown..it keep showing syntax error..hope u can help me..
Not all matrices are invertible. The matrice must be square.The matrix must be non-singular: Its determinant must be different from 0. Your error comes probably from the key you used to calculate the inverse. Use the reciprocal key, the one marked with x^-1. If the marking is not ON the key, use the SHIFT button prior to pressing the relevant key.
Sep 04, 2011 | Casio FX-115ES Scientific Calculator
Does anyone know how to calculate derivatives using the casio fx-115es? For example: find the derivative of f(x)= 3x^3=3x. Thank you!
hello,
The calculator will calculate the derivative at a point. It will not give you the formula for the derivative, just the derivative at the point you choose.
Sorry, it can ONLY do NUMERICAL differentiations and integrations.
Oct 21, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
1,859 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
