Question about Poulan Pro 22" Self Propelled High Wheel Mower
I have a poulan pro mower its has a honda motor the model number is pr160y21rdpc where does the attactment go on the back or on the side shoot. I cant figure it out. Thanks
ccrozier_agr
  • 36 Answers
SOURCE: Poula Pro Mower
Hi,your machine is probably a hydro static drive & needs the oil changed in the transmission.
But the pump that pushes the oil around inside it is probably to far gone for repair.
I am not sure about this machine but we have had a simlar problem with a rideon this summer.
It has one pedal that you push forward for forward movement & rearwards to go backwards.
We were able to get a new drive pump for the transmission but it was expensive, most of these machines have nearly the same transmissions so getting the parts should be no problem.
Also we do know is that there are some machines with oil emersed discs inside (like wet type clutches) these also need regular oil changes & can burn out without oil. (Bronze plated disc)
You would need to find the name plate on the transmission & there should also be model & serial no on the casing.
Once you have these details you should be able to find transmission parts lists online.
Posted on Nov 29, 2008
  • 84 Answers
SOURCE: carburetor adjustment
it would be a lot easier if you take the cover off the top of lawn mower.
find the carb, it usually sits near gas tank, there should be a screw sticking out of it. tighten until it runs normal. also adjust the air intake/ throttle arm on carb
Posted on Jun 24, 2009
  • 22 Answers
SOURCE: my poulan pro 6.75 self-propel mower stalls frequently
Replace the coil. Remove the top cover so that you can see the flywheel. There will be a horseshoe shaped peice with the plug wire attatched to it along with a small whir plugged onto it. Remove the two screws holding it on and unplug small wire and disconnect plug wire. When you put the new one on place a business card between coil and flywheel, this will give you the proper spacing, reconnect small wire and plug wire, reassemble top covers and you are good to go.
Posted on Aug 14, 2009
SOURCE: have a recoil pull start mower that won't recoil
Self propelled push mower the pull cord will not pull
Posted on Aug 27, 2009
  • 93 Answers
SOURCE: poulan push mower question
Check the engine manufacturers web site. You will need your engine number. .....You will find an on line diagram and part numbers for your engine. Also, Most Mower Parts stores have the same thing !
Posted on Sep 17, 2009
Proper spark plug number
Here is b&s 800number have make ,model,serial number handy 800 444 7774
Jul 01, 2014 | Poulan Pro PR550N22SH 22Inch Briggs ...
Where is oil plug on poulan pro 500 mower
It may not have one. Some newer models you can only suck the oil or tip the mower after removing gas on its' side.
Jun 20, 2014 | Poulan "Poulan" Push Mower
Replacing the muffler on the poulan pro 550 model number 961240002 00
there is two ways to mount mufflers on small engines. one with two bolts through the muffler to the block or threaded to it. if you don't see bolt heads then you unscrew the whole muffler.
Aug 06, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
What is the proper spark plug size for poulan pro 550 series
Go by the numbers on the original plug. The gap should always be set at 0.30.
May 24, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Poulan mower with honda engine runs a few min dies but starts back up then dies again and again
Hi and welcome to FixYa. I am Kelly. Fuel starvation is cause by debris in the bottom of the float bowl most of the time. Removed the bowl nut and bowl. Take some carb cleaner and shoot into the hole that the bowl nut screws into. Also clean out the holes on the side of the bowl nut. The fixes about 85% of all fuel starvation problems.
Debris in the fuel tank exit port, a dirty fuel filter, or a clogged float needle seat area can also cause the problem. I think if you follow the instructions above you should be back in business. If not pass the exact model number of your engine and I will help you by providing diagrams and how to steps at that point. The engine number is located just behind the oil fill hole on the bottom side panel of the crank case base.
Thanks for choosing FixYa.
Kelly
Sep 11, 2010 | Poulan Garden
Where can if i find a replacement air filter for my 21" poulan mower? no one seems to carry them. It's a honda engine.
there should be a model number for the engine stamped on the mower somewhere. more than likely, you will need to buy the filter from a honda small engine shop as opposed to a poulan supplier. if you bring the filter in to your local honda equipment shop, they should be able to match it up quite easily. good luck!
Aug 29, 2010 | Poulan "Poulan" Push Mower
How to change oil in poulan pro 650 series model hp-22 mower
Drain plug is under the motor. tip the hole machine back, (handle lying on ground) put something heavy on handle to hold it down, the plug usually is a 1/2 size wrench. Put a pan under machine to catch the oil. Take the drain plug out, drain oil, put drain plug back in, tighten it, and put machine back on all four wheels. Add oil. Take about 3/4 quarters of a quart. SAE 30 or 10w-30.
Apr 14, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Where is the oil drain plug for a poulan self propelled 22 inch 625 series mower
remove spark plug wire from plug,tip machine on its side.look under blade for a threaded plug with a square head where bottom of motor protrudes through deck.on most models you can simply tip machine over far enough to allow oil to drain out the dipstick[filler]tube.
Sep 27, 2009 | Poulan Pro " Pro" Self Propelled Mower
I need repair parts for poulan pro 240 42 cc recoil pulley
I would go to Poulanpro.com and look at a breakdown and get your part numbers there. If not give me the model number and I will go to a couple other sites I know and try and help that way.
Feb 19, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 22" Self Propelled High Wheel Mower Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
