Question about Maytag Refrigerators
The ice cube maker creates cubes that are hollow and not solid. Also, the filtered water has very little pressure and sort of dribbles out. I checked the line in and it seems clear into the back of the unit. The model# is: MF D2562KEW Thanks, Dan
    Master:
    Sergeant:
  • 385 Answers
Sometimes if you go to where the water line is hooked to the house plumbing and turn the valve all the way off and then back on it will clean the opening and fix the problem.Hope this is the case with yours.Give it a try.
Posted on May 28, 2011
My automatic ice maker has produced hollow cubes, foul tasting cubes and now they just made cubes with a green color in the middle. What's up?
Hollow cubes usually caused by lack of enough water during fill. My guess is green is mold buildup. Check house water supply to refrigerator. Sometimes the little shut off valves for the refrigerator block up and need cleaned or replaced. Once you get proper size cubes, if taste/ color problem persists they sell small in line filters you can add in the water line to the refrigerator.(about $25.)
Mar 12, 2015 | Whirlpool Refrigerators
Frigidaire side by side with ice maker .. ice maker jams and quits making ice
Hollow ice cubes are a result of lack of water to ice maker. This can be caused by lack of water pressure (clogged filter, bad water valve, obstructed fill tube, etc..) you will need to find the cause to correct this hollow ice cube issue. The ice maker should take on 5.5 oz of water when it cycles (2/3 cup). Mot of the time its a water supply issue and the line could be kinked behind the unit as it was rolled back into place.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Dec 30, 2013 | Frigidaire FRS23H7CS Side by Side...
Low water pressure in ice maker and water dispenser I changed the filter but water just dribbles out of water dispenser and ice maker makes hollow cubes
Make sure the water line to the back of the fridgeis not kinked.Ifit is replace it. Hope this helps,If so give us a 4 thumbs up. THANKS
Mar 02, 2011 | Maytag MSD2758G Side by Side Refrigerator
Ice cubes are hollow shells
Check around the hot gas valve for leaks/oil.
Aug 03, 2010 | Scotsman DCE33PA1BC 15in Built-in...
Slow ice cycle
Are you having any temperature related symptoms, i.e., soft ice cream that appears to have melted slightly and refrozen, soft breads in the freezer, warm or hot outer surfaces anywhere? If cooling is not a problem whatsoever, are any of your ice cubes smaller than normal, or do you have hollow ice cubes; you would be able to crush the cubes in your hand? If either of these pertains to you, you have not enough water coming to the ice maker, due to a faulty water valve not opening completely, or your water source pressure is low. disconnect your water line from the fridge, test pressure of the water line by placing end in a bucket, turning water on. It will be obvious how the pressure is. if pressure is good to really good, you have a bad water valve on the fridge. If pressure is so-so to bad, change source water valve.
If cubes are not small nor hollow, but rather normal full size cubes, just not enough, you probably have an intermittent problem with your icemaker, replace that.
Mar 31, 2010 | Avanti Freezer Compact Ice Maker - 12 lbs....
Maytag msd2356ae ice maker will only give me hollow ice any ideas.
Hollow ice cubes are most often cause by insufficient water supply. Icemakers fill for about 7.5 seconds, resulting in about 4.75 oz. (140 cc) of water into the ice cube mold. If there s not enough water pressure available at the fridge, cubes may end up hollow and/or the fill could continue to dribble, eventually causing the fill tube to freeze closed.
pls rate my suggestion.........
Jul 25, 2009 | Maytag MSD2454G Side by Side Refrigerator
550 Ice Maker Making Hollow cubes or Small Cubes
Hollow cubes are usually a result of lack of water supply
Jul 12, 2008 | Sub-Zero Bottom Freezer Refrigerator
Ice maker making hollow cubes
check your incoming water pressure, change the water filter recently? hollow ice cubes is a sign of low water pressure
Mar 05, 2008 | Refrigerators
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
Admiral Refrigerator makes hollow ice
Hollow ice cubes are due to low water pressure to the fridge. Water thru the door should have good pressure behind it. This is a good indicator of water pressure. Should be able to fill a glass quickly. Causes for low pressure are self-piercing saddle valves on the water line (switch to drill type (1/4") valve) or reverse osmosis system or filtering system on water line to the fridge. R.O. systems should not be used. Increase water pressure and that will fix the hollow cubes. The loud noise may be the sound of the water valve on the fridge when it is acivated. This sound is normal and some are louder than others.
Oct 05, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
50 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
