Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
I HAVE AN ERROR MESAGE SCANER JAM EEROR 5 - HP LaserJet M1522nf Multifunction Printer (CC372A)
  • HP Master
  • 1,915 Answers
This error is caused by failed drive motor in the flatbed unit. The good news is that this is a known issue that HP will fix at no charge. The procedure is the same as this tip that I wrote, which you can find here.
Posted on May 28, 2011
HP Laserjet M2727nf Mfp Printer Scanner Error 8
The HP M2727 has a known issue with the scanner error 8 and bad formatters. HP has extended the warranties on this product. I suggest you contact them directly and they will most likely exchange the unit.
Nov 08, 2011 | HP Laserjet M2727nf Multifunction Printer
I had a paper Jam and know printer error 5100 mesage is coming up, I turned off the printer for 5 min but when I turn it back on it make a turn nois and then a screeching noise then stop.
Sometimes when you get a paper-jam and remove the sheet, there can be little pieces of paper still stuck in the machine. This will cause your printer to do exactly what you are describing. Also remember that when removing a paper jam, use caution and care when removing the paper. To much force can damage the rollers and small gears inside your machine.
I hope this assists you,
Regards,
Nico
Jul 06, 2011 | Canon MX882 All-In-One InkJet Printer
Error : paper jam Epson DFX-9000
I find problem printer epson dfx-9000 with mesage
error : 0E
turn off printer
help solution this problem ????
Sep 14, 2010 | Epson DFX-9000 Dot Matrix Printer
MP160 canon printer. Flashes "E" then "4" then "2" on screen. The "alarm" light is flashing too. No paper jammed. powered on/off. Reinserted ink cartridges. Problem remains. Thank you. From Mel
This error means that you have scaner trouble, most likely the scaner is stucked, or the main logic pcb is faulty.
Try to remove copy glass and manually walk the scaner few times and put him in left position, grease it.
If doesnt help, the best way is to buy new printer.Logic board is too expensive for repair.
Hope that helped
Jul 03, 2010 | Canon PIXMA MP160 All-In-One InkJet...
The alarm light is flashing and the display says: E 3 What does this mean?
The E3 eeror is a paper jam error.
First, Unplug the printer from the power cord. Disconnect the printer cable as well. 2nd, open the covers and using a flashlight, look for any small debris inside the printer. The smallest piece can trip the error. Remove anything you find. Next, get some "canned air" at any computer or office supply store and blow the inside of the printer thoroughly. You may even turn it upside down so debris can fall out.
Plug it back in to the wall socket and connect to your PC again and give it a try. That should resolve the issue.
May 05, 2010 | Canon PIXMA MP240 All-In-One InkJet...
My canon mp240 has the E3 error and it will not go away
Oct 29, 2009 | Canon PIXMA MP240 All-In-One InkJet...
The scaner wont work.
Not sure if this a solution, but I think error E5 is that the cartridge is missing or in the wrong position, even if you just use black ink you must have both carts in.
Feb 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
Jan 28, 2009 | HP LaserJet 4 plus Printer
Scaner don't worlk
L1, on a Sharp is scanner locked.
Check the lock tswitch, that on a sharp looks like a round shaped oject on the left side of themachine, under the scanner.
If it is not the lock switch, then the scanner is jammed, in this case call a technician.
Dec 20, 2008 | Sharp AR-5316 Advanced Digital Imager...
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
mukhtar21 shaikh
mukhtar21 shaikh
