Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
CABRIO, NOT ENOUGH WATER TO DO MORE THAN A VERY SMALL LOAD
  • tombeckdesti May 28, 2011
    VERY GOOD THANKS FOR THE QUICK RESPONSE
  • 4,323 Answers
Hi
The issue is with the water inlet valve that is either clogged or bad, you'll have to check this valve and if bad it should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on May 28, 2011
5 Suggested Answers
  • 100 Answers
SOURCE: Washer doesn't fill with water. Only enough for a small load.
A - Two things could be your problem...
1) - sometimes the screens in the fill valve or inside the ends of the fill hose get clogged up...use a tooth brush to clean them out. Don't forget to shut off the water first before removing the hoses to check for this.
2) - The fill valve itself may not be opening fully = time for a new fill valve.
Posted on Dec 17, 2008
  • 99 Answers
SOURCE: Kenmore washer only will fill to a small load water level
This is Joyce
This is your water sensor, it is going off before it lets the machine fill up, if not this then the control on your machine that determines the size load you selected. go to kenmore.com download your manuel. see what you can find out about the machine.
let me know if you need any other assistance
thanks
joyce
Posted on Feb 13, 2009
  • 6 Answers
SOURCE: my top load 4.5 cubic whirl pool cabrio washer
your agitating belt might be slipping or worn, try holding the switch down with a pencil, and keeping the lid open and see if the agitator is moving or sluggish..good luck.
Posted on Jul 29, 2009
  • 572 Answers
SOURCE: How do you set the Cabrio to wash a small load?
this one only has 1 setting on water level. same size uses same level
Posted on Feb 25, 2010
Our cabrio washer (whirlpool) is not filling with enough water
You should have a LF code if so, then the water valve is your problem.
Jul 06, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
What is load capacity for cabrio wtw6500ww1
It may only think it's overloaded. When the cycle starts the control checks the load to determine how much water to add. If there's a problem like stuck basket or rotor, bad sensor etc it will quit with the error you see.
Jun 19, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
What does sensing mean on a whirlpool cabrio
This means that the washer is sensing if there is enough water in basket with quantity of cloths.
Jun 10, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Water is leaking onto the floor underneath my Whirlpool Cabrio (top-loading).
If its a small intermittent leak from the front left corner its the tub ring, whirlpool has redesigned the tub ring to fix this concern..
Sep 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I replaced the water pump on WTW6400SW2 cabrio washer twice already within the last two years. This unit is only three years old. Do you have a solution to the problem?
What was the reason. Pump Motor electrical coil failure ? or water impeller failed. If motor problem, you have to check the associated small capacitor also.Hope no water finds way to the motor.
Mar 30, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer leaks out the bottom of machine need access to inside of machine
A small amout of water leaks underneath on the left side of the washer-they think the tub ring is causing the problem. Whirlpool Cabrio
Mar 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Feb 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My top load 4.5 cubic whirl pool cabrio washer does not seem to clean my clothes. it almost acts like there is not enough water
Jul 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Mar 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
351 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
