Question about Sharp AL 1215 Black and White Copier
HELP, H4 ERROR
I JUST BOUGHT MY SHARP AR-5316E, BUT IN LESS THAN 4 MONTHS IT IS DISPLAYING H4 ERROR. WHAT IS THE SOLUTION , PLS HELP. Sharp AL 1215 Black and White Copier
  • Sharp Master
  • 2,794 Answers
The fuser isn't heating up on time. You could try turning the copier off for 30 seconds and turing it back on again to see if it goes away.
If it doesn't happen, there is a part that has to be fixed on the fuser to correct the problem. Usually it is the thermistor.
Posted on Aug 17, 2008
  • 24 Answers
Could just need a reset, sorry cant remember the code for that model, still sim 14, but to get into diagnostics i think is auto c auto c. give it a try you never know
Posted on Sep 05, 2008
SOURCE:
MY SHARP AR-5316E DISPLAYS H4 AND IS NOT WORKING
Dear friendscom, H4 :Heat roller abnormally low temperature.
__ possible cause __
  • Thermistor failure
  • Heater lamp failure
  • Thermostat failure
Perform the following procedure to reset the code:-
"#" key-- Interrupt key-- "C" key --Interrupt key--14--print
Jan 12, 2011 | Sharp AR-5316 Advanced Digital Imager...
Problem for Sharp AR-5320 Black and White Copier Ar 5516 display H4 error?
for AR 5320 just check 1- main corona 2- leveling the developer unit 3- clean cleaning plate,
for H4 just rest the machine as mentioned above, if not plz check fuzing unit -- thermostat
Aug 22, 2010 | Sharp AR-5320 Black and White Copier
H4 error on SHARP AR-5316E plz help
h4 refers to the fixer/fuser, check to see if there is a paper jam in it
Jun 03, 2010 | Sharp AR-5316 Advanced Digital Imager...
Pls give me display code ditael for sharp ar-5316e
(# interrupt C interrupt)this is how to go to code.what is your problem?
Feb 06, 2010 | Sharp AR-5320 Black and White Copier
Irc2105
There is no such error 'E215-0000' in ar 5320, for H4 use "#, Interrupt, C, interrupt. Display goes off, Enter 14, Press Print key.
Apr 08, 2009 | Sharp AR-5320 Black and White Copier
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp sf-7100 / status code
H4 means the fuser can't heat up. The fuser lamp probably burned out. Sorry, nothing can be done without tools and new lamp
Jan 15, 2009 | Sharp AL 1215 Black and White Copier
HELP, H4 ERROR
H4 is normally caused by the fuser taking a little longer than normal to warm up. Most of the time it is not caused by the hear rod itself. I will send you the process here is a few minutes.
Jul 24, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp sf2116 problem
press C-I-0-I i is intrerrup c is clear 0 zero the machine will shut down and type 14 and press the star key.this will reset the h4 code.
Apr 06, 2008 | Sharp AL 1215 Black and White Copier
Sharp AL 1215 Black and White Copier Logo
172 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
