Question about Sewing Machines
Replacing Light bulb in Pfaff 1471 cd
The light bulb in my machine has burned out. tried to unscrew/pull it out not knowing if it was push in or screw type. The bulb itself came out with two fine wires sticking out and left the metal base in the socket. Being up inside the machine, it is hard to get ahold of and see to know if it needs to be pulled or unscrewed. How on earth do I get the metal base out to replace the bulb without damaging the socket?
  • Anonymous Dec 07, 2008
    I have the side cover off but can not unscrew the bulb. Is the bulb a screw in type. I don't want to break it off while it is in the machine. I can see a small spring attached to the black part that holds the lower part of the bulb. Do I do something with it?
  • Anonymous Apr 15, 2009
    need to replace light bulb in pfaff 1471...
5 Suggested Answers
Zenqi
  • 208 Answers
SOURCE: Temp misplaced Pfaff 1471 manual during move.
Unplug the machine and check to make sure that the contacts for the batteries are clean and that the batteries are installed with the correct positive and negative orientation. Plug the machine back on and test.
Posted on Jun 27, 2009
  • 14 Answers
SOURCE: How to replace light bulb at Pfaff Creative 2124?
On these machines you cannot open the left side to remove the bulb. Your machine accessory kit should have come with a rubber tool that is ribbed with a cup-shaped opening on either end. This is a tool for removing the bulb. Tilt the machine with the base facing up so you can see where the bulb is and use this tool to twist the bulb gently. It sould come out with no problem! Hope this helps!
Posted on Sep 12, 2009
Testimonial: "Thank you"
  • 980 Answers
SOURCE: what year was serial number 82848782 produced?
The 1471 first came out about the early 70's
Posted on Oct 27, 2009
  • 98 Answers
SOURCE: I bought a new sewing machine light bulb to
your bulb part number is X53061020 and no the blubs are not universal I would suggest taking the old bulb with you along with the part number I gave you in order to get the right bulb when you go to the store.
Posted on May 31, 2010
How do you open the sewing head to change bulb on Pfaff 955 hobbymatic
To access the light bulb, use the button-hole foot to lift up the insert on the arm cover. Remove the cover. Hold the edge guide slightly tilted and push it into the opening in the head of the sewing machine. Press down on the lamp housing to hold it still. Push up on the bulb and turn it counter-clockwise. Once the bulb is loose, pull it down and out of the lamp housing. To replace the bulb, continue to hold the lamp housing. Push the new bulb into the housing and rotate it clockwise. Release the lamp housing and then use the button-hole foot to replace the cover.
Pfaff has the manuals for most of their machines here: http://www.pfaff.com/en-US/Support-and-Updates/Support . The Hobbymatic 955 support page is http://www.pfaff.com/en-US/Support/3529 . The direct link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Pfaff_935_955_HobbyMATIC-manual-EN-FR-DE-NL.PDF . See page 51 (page 59 of the PDF) for the directions to change the light bulb, These pictures may help you see how to get to the bulb. If you need a replacement button-hole foot, see http://www.sewingpartsonline.com/buttonhole-foot-low-shank-new-1932l.aspx .
I hope this helps.
Jul 21, 2017 | PfaFF Sewing Machines
Pfaff 1471 threading instructions
Hello Patricia P. Thomas
Download a free Pfaff 1471 Manual here
https://www.manualowl.com/m/Pfaff/creative-1471/Manual/333543
The threading instructions are quite simple to follow.
Please let me know how this works out for you.
Happy Stitching
Feb 27, 2017 | PfaFF Sewing Machines
Pfaff 1471 frozen. Button lights on, nothing works; frozen.
UNPLUG it from the wall wait a few minutes and plug it back in .if this does not work contact Pfaff tech support
Sep 15, 2015 | PfaFF Sewing Machines
How do you change the light bulb on a pfaff 7550
If you look down on your machine from the top you will see a small whole with a screw in it (you may need to lift the handle).
The screw is a flatblade/philps/20 torks.
Losen the screw about 2 full turns (do not take it out).
pull off the panel on the left and you should be able to see the light blulb.
Turn the light bulb about 90 degee and it should droop out.
Replace with only a 120v 15w bulb.
Hope his helps
Apr 07, 2011 | PfaFF Creative 7570
Can the light bulb on the Pfaff 7570 be changed without the bulb changer tool?
Yes. First turn off the machine. You need to get out the cover (cap) with the stitches number in it. Move the bobbin winder to the position to full a bobbin. Unscrew the screw near the bobbin winder. Next unscrew the screw near the thread reel holder. Pull up the handle to carry the machine and now put up this cover. Unscrew the biggest screw at the left hand, just unscrew a little. I'ts a little more down. Then pull up the cap at the left hand (the cap that have the thread trimmer). Now change the bulb and put all the caps to the right position. I hope that you understand me, my first language is spanish.
Dec 08, 2010 | PfaFF Creative 7570
My pfaff 1471 shaft with needle will not go up and down it is locked and what ever I try doesn't solve the problem. I have tried unlocking and locking the wheele but nothing seems to work. How can I take...
Undo the screw in the stop motion wheel, then unscrew the stop motiuon wheel, turn the 3 pronged washer intoi a different position, put the stop motion back and the stop motion screw and test, if that does not work move the washer again.
Aug 10, 2010 | PfaFF Sewing Machines
Need to locate a lamp changer for the Pfaff 7570
You my be able to change the light bulb without one. On some versions of the Pfaff 7570, you can remove the left end of the machine to access the bulb socket: remove the top cover that has all the designs pictured on it. Lift the carrying handle. Immediately behind the handle is a hole about 3mm in diameter. Down in that hole, probably too far down to see, there is a phillips head screw. Drop a Phillips head screwdriver into the hole, set it into the screw head and unscrew that screw. This will loosen the left end cap. Pull toward the left to remove this piece and you can access the bulb and socket.
Oct 06, 2009 | PfaFF Creative 7570
Pfaff 1222
With power off, needle out, no presser foot, remove top cover off of the machine. Left side cover (light area) has 2 flathead screws deep inside the cover. No need to remove the screws, just loosen the up and the cover can be removed by pulling it out. Now you'll see the light bulb, remove the bulb. On the bulb holder there is 1 screw that secures it, remove the holder. Now actuate the lifter lever, you'll see where it is attached to. It has a small screw that holds it, it might have come off.
Jul 07, 2008 | PfaFF Tiptronic 2030
Sewing Machines Logo
163 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
