Question about Troy-Bilt Pony Garden Tiller
Rough running starts fine but can not put in run without dying
Starts and runs fine but when I put it in gear it dies
Riding Mower Dies When Put in Gear ' ThriftyFun
www.thriftyfun.com/Riding-Mower-Dies-When-Put-in-Gear.html
It starts fine, but when I put it in gear to go forward or reverse it dies. It also dies ... The engine on my riding mower will start and run while the clutch is pushed in.
Starts and Runs but Dies When put in gear - YSR 50 ' South Bay Riders
www.southbayriders.com > ... > Community > Maintenance and Repair
Aug 25, 2010 - 15 posts - ‎4 authors
The bike will start and run perfectly fine. However, the moment I put it into gear it dies. ----------------- How we got to this point:...
Engine dies in gear, runs in neutral - Hot Rod Forum : Hotrodders ...
www.hotrodders.com > Tech Help > Engine
Jan 4, 2010 - 12 posts - ‎10 authors
But if I drop it into any gear besides neutral or park, the engine will ... In this case, it shifts fine, and on time, however acceleration is ... start. the engine idling rough and wanting to stall when put in gear is the indicator to me.
Jan 21, 2016 | Garden
1991 Ford F-350 runs rough at cold start, dies if gas peddle depressed?
If you have a carb its chock .If injection its fuel related filters regulator restrictions if fuel flow ect.
Sep 11, 2017 | 1991 Chevrolet C1500
2002 express 1500 van, will not start
remove dog house locate test port and install guage should be 45-60 psi
Mar 03, 2010 | 2002 Chevrolet Express
It starts fine, runs 20-30 seconds, runs rough,
check the actual fuel line. Also is it fuel injection or carberator
Aug 03, 2009 | 1992 Dodge Power Ram 50
My girlfriend has a 93 olds cutlass ciera and it dies in reverse
When is the last time she had a tune up?
I would start there. Plugs, Wires, Distributor Cap and Rotor. Hope this helps you and thank you for using FixYa!
Mar 26, 2009 | 1993 Oldsmobile Cutlass Ciera
91 jimmy starts cold, runs rough hot, dies when put in drive
Try to unplug the mass airflow sensor and start it. It will idle higher but should run fine. If it works then you need a MAF sensor. Be sure you have an OBDII code puller to clear the computer when done
Jan 25, 2009 | 1995 GMC Jimmy
Troy-Bilt Pony Garden Tiller Logo
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
