Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
My New drive (WDBAAU0020HBK) cannot be initialised: It appears it is write protected. I cannot format it eithere. It is unusable. Any ideas?
  • 670 Answers
please check if there are any switch that you can slide to disable the drive being write protected.
Hope this helps!
Posted on May 28, 2011
I have a Optiplex Gx260 which has only 800mb of memory left. I have removed all unused programes but it seems that the hard drive capacity is being taken up by things which arn't clearly identifyable.I...
One drive should be set as master, (the bootable system drive) and the extra drive as slave. Disc management should be able to initialise it then and format as required.
If you install iobit.com and asc-setup, (it is free ware) run the regisrty utility followed by disc cleaner, that will show you where your space has gone. All useful stuff can be stored on the slave disc.
Hope that helps.
Feb 25, 2011 | Dell OptiPlex GX260 PC Desktop
I installed a new hard drive. on the compaq presario v2000. all im getting is realek media error. i went into bios set default. no resolve. tried cd rom first. no help.jumper pin is outter two verticle....
Does the laptop BIOS "see" the new drive? If not the drive must be "Initialised" first, otherwise it will not recognise you have a drive in the bay. Place the drive in a USB caddy and using another laptop or your laptop with the old hard drive in it, select Control Panel and Adminastrative Tools. Select Computer Management, From the side panel select Disk Management to view selected drives. The disk drive that is connected via USB will be there. Click the drive and select initialise then format and select a drive letter. OR
With the new drive in the laptop bay, set the BIOS menu, on your laptop, to use DVD/CD ROM drive as first boot device.
Place your System disk in the drive and boot from the disk.
Follow the instructions, (if any) on the screen and let the new system software initialise and format the new drive.
Hope that helps
Dec 17, 2010 | HP Compaq Presario V2000 Notebook
How to enable Secondary IDE in NEC VERSA M400
I presume you have bought a secondary hard drive and want to fit it to your laptop.
Firstly fit the new drive, it then needs to be initialised, this can be done by running Control Pane, select Administrative tools, select Computer Management. Run Discmanagement and find the new hard drive, initialise it and format it.
That should solve your problem.
Nov 03, 2010 | NEC Computers & Internet
1tb external hard drive wont appear in my computer
Have you "Formatted" it before you used it, If NOT, Right Click on drive and select "Format" format NTFS. After this you should be able to use the drive as normal. Also Right Click, MY Computer, choose "Manage" when it comes up select Disk Management, and you can initialise it and format there.
Feb 28, 2010 | Buffalo Technology 1TB DriveStation...
HI Sir, my pendrive not acces as wel as not format, also not dislay the boot file. so suggest me.
Either your pen driver is locked by password. or it is write protected.
Try formatting in dos. Or it is still unusable. get a new one.
Jan 16, 2010 | Computers & Internet
My Canon PowerShot A430 does not want to unprotect one image. I have tried to go to erase all in the menu, and I have tried to got to protect to see if it will reverse the protection but it does not do...
Reformat the SD card with your computer. This will delete all data on the card. Do you use a usb cable to upload pics to your computer or put the SD card in a media slot? Either way, find the drive that corresponds to your SD card or camera in "My Computer". Right click on it and select 'format'. A new window will open with a check box for 'quick format'. Check the box and click OK. A prompt will appear stating all data will be erased. Click OK. In a few seconds, the card will be reformatted.
Oct 06, 2009 | Canon PowerShot A430 Digital Camera
Have a Finepix S602Zoom which on warning display now shows ''Card not initialised''- have bought a new 4GB card- but still have the same problem.. Any ideas - software prob?
This is a common error in the FinePix product range. When you receive a "Card Error" or "Card Not Initialized" message, this indicates that your camera's memory may be temporarily corrupted. This can be due to not formatting your memory card on a consistent basis. Most users will use the "delete all" feature and continue to take pictures but by doing this the file format of the card may become unstable and unusable.
Fuji recommends formatting your memory card in your camera after saving the images from your previous shooting session. Once a memory card is formatted the images will not be recoverable. So format the current cards and they should be useable again.
Sep 25, 2009 | Fuji FinePix S7000 Digital Camera
Seagate drive partition
This is fairly straightforward using the Windows XP tools.
IMPORTANT, copy everything you want to keep from partition F otherwise it will be deleted. Drive G will not be affected.
  • Right click 'My Computer' >'Manage' then click disk Management.
  • Right click your drive F and 'Delete Partition'.
  • You now have 210GB unused space on the drive.
  • Right click the unused space and "Create Partition".
  • Specify the size of the new partition to your requirements or create more partitions until the free space runs out.
  • You can then right click and format the new partitions. 'Quick Format' is fine unless you have been experiencing disk problems.
To swap around drive letters in Disk Management:-
  • Right click the drives and 'change drive letters', to X, Y or Z or whatever
  • Now you can change the drive letters back to F, G, H or whatever order you want them in
I'm sure you get the idea, you just have to change the letters of the drives to unused letters to make a space in the sequence (not that any sequence really matters)
Good luck
Nov 08, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
414 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
