Question about Sharp MX-2300N Color Copier
We have code h4-30 there was paper in the fuser unit How can we reset the code
    New Friend:
  • 66 Answers
Press #*C* respectively, then you will be st service mode after that enter 14 as main code and then press 14, then your machine will restart. this will resolve your problem, vote for this and rate this if any problems feel free to contact me.
Posted on May 28, 2011
  • Sreelal Devadas Jun 02, 2011
    Sorry I made a mistake tafter pressing the first 14 you have to press start then it will ask for execution exicute it and try again
How do I reset fatal error code 980 on C 610
check the fuser unit for paper/media stuck to the orange fuser roller. power off machine and re-install. If that dont work fuser unit must be replaced
May 18, 2014 | OKI C5650n LED Laser Printer
Callservice3 pansonic kx-772
Call s3 means abnormal fuser unit.
although you found jammed paper inside
you have to replace fuser unit.try once to reset with the code. if unit seems became OK. if not 1.disconnect power.2.remove the bottom cover.3.dis conn.2 thick cable connectors(fuser lamp) and small white connector(thermistor)4.turn up right & remove 2 long screws 5.replace the new unit.6.press#9000*529 start.(new installation reset code)
Remember these procedures must be done by a qualified technical person.(high voltage & extreme temperature area)
May 04, 2014 | Panasonic KX-FL611 Plain Paper Laser Fax
Unable to copy code h5 01
Cause: Paper jam in fuser unit or paper jam removed beyond required time.
solution: remove jam from fuser unit.....perform simulation 14 to reset machine!!!
Feb 23, 2011 | Sharp AR-407 Copier
What is c0120 error
error code C-0120 in konika minolta model no C-450
Feb 03, 2011 | Konica Minolta Minolta DI1610P Printer,...
Code : H5-01
Check for paper jam in or by fuser unit. Remove paper. On the keypad press P * C * and SIM 14 to reset copier. If you get 5 jams at the fuser unit in a row it gives this code. If it keeps jaming double check for paper, my have a faulty sensor.
Aug 31, 2010 | Sharp MX-2300N Color Copier
What is error code E000 mean
Solution:
Press "Additional Functions",
Press "#", then press the "Right Arrow" button till it says, "Printer",
Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
Then press "Set" again, the display will ask you "Yes" or "No".
Press the "Left" arrow for "Yes", then press "Set".
Now, unplug the power cord and wait 5 seconds and plug back in.
If this don't work, get a new fuser.
Feb 04, 2010 | Canon imageCLASS D880 All-In-One Laser...
H5-01 code
First thing H5 means you've had 5 continues jams at or before your fuser unit. So the first thing you need to do is make sure you all your paper out of the machine and double check the fuser unit for paper as well as the transfer belt unit for paper on it or behind it. You can simply remove it by first removing your fuser unit (lock is under fuser, a turn dial) then pull the transfer belt out and tilt up. **** Warning**** use caution when removing belt as to not damage the unit. After you do all this you will need to reset the code.
Press the buttons in the following order :
#/P key (program) - Asterisk (*) key -CLEAR key -
Asterisk (*) key - Ready for input of a main code of simulation
Type 14 with the key pad then press your copy key
Press execute then YES Once done press the CA key on the panel and the machine will restart.
Oct 01, 2009 | Sharp Office Equipment & Supplies
DP 3530 error code E04-02
Hello sir; You have to look at heating unit you havv paper jam over there!
Aug 23, 2009 | Panasonic Workio DP-3530 Copier
Help
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
We are not able to recive fax
this code means the fuser unit has gone over temperature, as a sftey feature the mc will have to have the fuser unit reset then if the reset (which is done through service mode) doesnt fix it then it may need a new thermostat or lamp.
Aug 26, 2006 | Panasonic Panafax UF-560 Plain Paper Laser...
Sharp MX-2300N Color Copier Logo
1,930 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
