Question about Samsung CLP 300 Laser Printer
Samsung CLP300 cannot get the rubber pick up roller back in
Ok I couldn't get the rubber band off so I removed the whole, JC73-00211A RUBBER-PICK_UP, but now it's as if it's too long to go back into the machine, which I know of course it is not, can some help me. Thanks, Julia
    Problem Solver:
  • 5 Answers
The rubber band goes around the plastic roller and is loose about loose enough to get a finger between it and plastic however the thing then pushes back into the curved space at the back of the roller so it forms a kind of c shape around the roller. If that makes any sense!
Posted on Sep 20, 2008
Paper will not feed
HELLO OK IF PAPER KEEPS GETTING STUCK ON THE PICK UP ROLLERTHAN U NEED TO CLEAN THE ROLLER TRY CLEANING THE ROLLER WITH A POLISH NAIL REMOVER..
WHAT THIS DOES IT FRESHES THE RUBBER SO CAN PICK UP THE PAPER...
1)OPEN TRAY OUT
2)GET A CLOTHING WITH POLISH REMOVER ON TIP
#RUBB THE CLOTH TO THEPICK UP ROLLER
3) STICK YOUR HAND INSIDE BOTTOM ALL DA WAY TO THE BACK WHERE U SEE THE ROLLER AND RUB AGAINST IT
4) TRY PRINTING
IF THIS SOLUTION HELPED RATE ME THANK YOU
Mar 26, 2013 | Dell 725 InkJet Printer
We have a Brother Intellifax 2820 fax machine, and the problem from the pick up tray after two copies it gives an error "No Paper Feed" can you tell me what is the problem. I cleant the pick up...
Tray this:
open the left cover, check the pick-up solenoid by hand, if it remain as bonded in the part under, you have to remove from the part under the little rubber band with a screwdriver. Then recheck the solenoid if it works good.
Sep 09, 2011 | Brother IntelliFax-2820 Laser Fax
The rubber-coated roller won't pick up the paper reliably every time anymore. Is alcohol cleaning going to work every time or is there another better way to bring the "sticky" back to the rubber?
you can remove and reverse roller to use it again.
Unpin it from roght and left carefuly, clean it again whit alcohol, turn rubber a little bit and put it back into the printer.
Good Luck!
Jun 29, 2010 | Samsung ML 2010 Laser Printer
PAPER DOES NOT FEED THROUGH - TRIES TO PICK UP AND WILL AFTER MANY ATTEMPTS - WHAT CAN I DO?
Sounds like the pickup roller is worn, you could try giving it a little more grip by giving it a clean or in more severe worn parts that are out of warranty i have used a fine sandpaper to rough the surface a little, just be sure not to leave any particulates on the roller. to remove the part simply locate the big dark rubber wheel at the back of the paper feed, with the front door down and the toner cartridge out, to my recollection the rubber part should be attached via a half moon shaped plastic insert that clips in at the top and hooks in at the bottom. so get your fingers behind the roller at the top and give it a pull and it should come away and then unhook, then give it a clean or find a better area of rubber on the item and swivel it round to that point, then hook it back to the bottom hooks on the bracket and push rearwards to clip it back onto the bracket at the top. hope that solves it, if not use some rubber bands around it to add a little more grip, shame to chuck these things away,
Sep 25, 2009 | Samsung ML 2010 Laser Printer
My printer does not pick up the paper sheets from the paper tray.When I took paper sheet in to slot it works.
Well - I don't know if this will solve it (since there could be many causes) but it worked for me.
1 - Remove Paper Tray
2 - look at rubber rollers in printer undercarriage
3 - carefully remove "rubber bands" from roller
4 - turn rubber bands inside out and carefully return to rollers
5 - remove toner cartridge
6 - remove print drum assembly
7 - return printer drum assembly and toner cartridge
the roller trick helps the printer pick up paper
the toner/print drum trick helps reseat the inner workings of the printer correcting any misalignments that impede paper flow
Jun 09, 2009 | Lexmark E232 Laser Printer
Pickup Roller wear
I have had the same paper jam nightmare as many CLP-300 users and just as I was on the verge of throwing it away I appear to have solved the problem. The paper tray has adjustable plastic guides on either side. I loosened them slightly to allow an spare eighth of an inch each side and I've had no problems since. I can't believe the problem that plagued me for months was so easy to fix.
Feb 01, 2009 | Samsung CLP 300 Laser Printer
Help
The only way to do this is with 2 small flat bladed screw drivers when u push them at the same time into the edge where the clips are one either side of the roller the whole roller will come off. If you can see opposite the clips there is a sort of hinge section this hinges down and the whole roller and rubber comes free. I just turned the rubber inside out and refitted it no more paper feed errors. It is a little tricky to reach and you definitely need the screw drivers to slip in the edge as pushing on the little lever to release it wont slip it past the notch that holds it in place. Good luck.
Aug 14, 2008 | Samsung CLP 300 Laser Printer
Samsung 300CLP "paper jam"
I have just posted my "fix" for the paper jam elsewhere on this forum. Check it out and I hope it helps you too?
Nov 24, 2007 | Samsung CLP 300 Laser Printer
Paper Jam
I have just SOLVED my CLP 300 printer paper jams by replacing the rubber band on the paper pick up roller. My old rubbber had worn flat and had dried out. I was lucky as Samsung had sent me one for an engineer to fit. However, being an engineer myself, I replaced it with instant success!
You could fix yours without replacing the band because all it needs is to be turned around to a non worn area. To get to it safely, unplug your printer from the mains supply and the USB cable. Remove the paper tray.
Open the front door and remove the imaging unit complete with toners. Now turn your Printer upside down and look for the rotating bar with a centre wheel and rubber band. The rubber band looks like it only goes half way around the wheel. This band is Clipped onto the wheel. With careful prising, you can unclip the rubber band. It's a bit tricky and tight but I have done it no probs. Perhaps being a techy myself has helped? Anyway, rotate the band around so that a fresh bit of rubber will be acting on the paper and refit. This is also tight and tricky, but can be done without dismantling the printer to replace the who bar.
The actual part that is unserviceable is the rubber on the Samsung MEA unit pick up roller. The part number is JC97-02647A
Now refit all the other stuff and test your printer. I have also got rid of the dreaded clicking too! But that's another story.
Hope this helps?
Oct 06, 2007 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
227 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
