Question about Kitchen Ranges
The power cord of a Dayton 5k449C electric motor (on a boat lift) got pulled from from the motor by accident. There is no diagram in the motor, it goes from the reversing switch to the back of the motor. The connection sites don't seem to be damaged. There are wires from the motor itself that were joined by wire nuts to the wires from the cord. It got disconnected when the lift rotated to much and pulled it. Please help, thanks.
aborcass
  • 2651 Answers
SOURCE: wiring hookup for a replacement part
hopefull yyou havent disconnect old switch yet. whirpool and kit aid are same Co. same parts used. assuming the correct part was sent for the corrrect burner. diffrerent element will require different rated swties(ie. small , large, dual and so forth.), the indivudal switches are labeled, on the swithc itself ( L1,L2,H1 H2, P1 andso forth, so although the switches looke differnet they should stil have the same lettered terminal to plug into .
Posted on Mar 16, 2008
Malcg
  • 32 Answers
SOURCE: wiring diagram
In the UK, to connect to the connection block of a fixed integrated oven in a Kitchen, you must be a Part P Registered electrician. Such an electrician will issue a Minor Works Certificate for this work on completion - otherwise they are not Registered!
Be aware that if the work is not done under Part P and a fire occurs, etc your insurance company are entitled to REFUSE to pay out for the damage including any consequential damage to neighbours property or for loss of life!!
The block has three terminals and the Live, Neutral and Earth are indicated by marks stamped on the metal back of the cooker (if a CE product).
L = Live and takes the Brown covered wire
N = Neutral and takes the Blue covered wire
52080c4.gifor E = Earth (CPC) and takes the green/yellow covered.
If the cable has an uncovered copper third wire or is coloured Red/Black it should be replaced from the connection accessory on the wall behind the cooker with a heat resistant 3-core Butyl cable of sufficient size to cope with the load of the oven.
If you let me know the rating of the oven (label on door) in amps or watts, I'll tell you what size of cable you need.
Posted on Apr 13, 2008
  • 145 Answers
SOURCE: Wiring diagram for a Goldstar A/C R6004
If you remove the cover it should be on a sticker in the control area. If it's unreadable you will need to contact the Goldstar.
Posted on May 19, 2008
SOURCE: JBP66G W1AD Oven won't get hot enough
the yellow may be the oven temp sensor?
Posted on Jul 01, 2008
SOURCE: Need advice on Kenmore electric range
turning frot burner on sparked and now all 4 burners don't work any more
Posted on Sep 12, 2008
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
Where is rhw spark plug on my wee boat motor.Where can I get manual for it with diagram of parts on motor. The only thing I can identify is the pull cord and lever for choke- I think.Any help much app
see this video
http://www.youtube.com/watch?v=Md-6H0rfEeI
see the orange thick wire your outboard may be similar notice the spark plug at the back of the motor near the bottom of the engine at the end of the thick orange cable. I recommend looking for a similar thick electrical cable and follow it to where it ends up.
Nov 02, 2014 | Boating
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
Wiring diagram needed for my 1972 johnson 50hp hydro-electric drive outboard motor
I don't have the diagram here, but it should be mainly color on color.
I'll look for a diagram if you couldn't get out.
Jan 04, 2013 | Clymer EvinrudeJohnson Outboard Shop...
I got a dayton 2hp. electric motor model#2N982M it appears you can wire it for 110volts,220volts, or 440volts - need a wiring diagram mine partially worn off.
That motor is a three phase motor and will not run on 110 volts. It is also a high RPM motor with a lot of torque and MUST be mounted to a solid surface before it is powered up or it could rip your arm off as it flies across the room. If you have access to three phase power then you could power that motor but not with standard household electrical service.
Heres a link to some info for it
Jun 17, 2011 | Dayton Heating & Cooling
I needa wiringdiagram for a dayton motor 3kx04a
I think the wiring diagrams found here might be the one you are looking for:
http://www.wrxtra.com/Misc/Electrical/Dayton/
Please let me know and rate my answer if correct.
Many thanks,
Chris
Mar 02, 2011 | Dayton Heating & Cooling
Wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
Dec 13, 2008 | Dayton Permanent Split Capacitor Motor Fan
Kitchen Ranges Logo
46 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
