Question about Zanussi Washing Machines
My machine has stopped on the display it says e12 whats wrong
    Sniper:
  • 59 Answers
Problems with water fill in drying.
Unplug the appliance, take the top off and check that the plastic condenser below the fan is clear and clean.
If this is ok, the most likely fault is the triple valve isn't opening properly to feed water into the condenser.
Posted on May 28, 2011
My washing has a E12 code on it.
I appreciate your inquiry, friend!
From what you have described your Electrolux washer is displaying an error code of "E12". An "E12" error code stands for a non-fatal reading or writing to the memory. This can be cleared with a reset and you can do that by unplugging the power cord for roughly ten minutes. If this does not resolve your issue it could be a possible problem with your control panel and that may need to be replaced. I hope this information is helpful. -Matt
Mar 15, 2015 | Electrolux Washing Machines
WHEN POWER ON THE TREADMILL I HAVE AN ERROR CODE E12 ON DIGITAL DISPLAY OF INVERTER HITACHI J100.HOW CAN I CLEAR THE ERROR? THERE IS NO EFFECT WITH STOP/RESET BUTTON.ALL VOLTAGES AT INVERTER'S...
Hi Basil, Sorry for the delay in replying, I was confused as to the nature of the issue, If it is a treadmill or inverter issue......This is an inverter problem that you have. To reset the E12 error code you need to turn the power off and then on! This should clear the code!
Oct 21, 2014 | Exercise & Fitness
Siemens e12 46
This
is either a fault with door lock or the pecker unit on the door this video
might help
Jul 22, 2013 | Washing Machines
Hoover washer dryer Error Code E12 during dry programme. How can I fix?
E12 means a problem filling on dry cycle.
Nov 03, 2012 | Washing Machines
Washer is showing E12 error. Help
Hello.
This code means an error code. That the dishwasher electronic control has detected a condition it needs to check. When you see a code, follow these steps to solve the problem:
· Press "Stop/Clear" to clear the display and stop the beeping if any.
· Reprogram the dishwasher.
· If the code still displays, turn off the power to the dishwasher at your breaker box and wait five minutes and clean all part (area) that are open to water carefully before turning it back on.
Thanks for using fixya
Aug 02, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Thermador prd486edg oven/heating flashing 1/2and neither oven heats. help!
only code that is close ( e12) ( E12) look at display and make sure .. mm if the code is E12 then " CT oven:latch switch problem ) this may help Note E . 1 turn the clock selector knob to off 2 tweak the oven control by turning the clock selector slightly to the left ( counter clockwise ) this may stop the flashig message / beeping and clear the display window. " try it and pray mm .
Dec 09, 2009 | Thermador PG304BS Gas Kitchen Range
Gestetner CP6123 giving error E12
You should check the all paper sensor, there must be a pieces of paper in some sensor and make the sensor in wrong direction. You should remove all and off the power for a while and the start to use it.
May 11, 2008 | Gestetner - AO40 Wide Format Copier Copier
Washing Machines Logo
318 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
