Question about Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard
Resolution problem not more than 32bit. i need more resolution.
    President:
  • 2,340 Answers
You have not install the correct onboard Graphic Card driver for your Mainboard, so you currently are running on Generic Graphic drivers and you have a low resolution.
From the specifications of your Mainboard, assumption that you are using WinXP or W2K OS.
You can download and install the "Intel® Extreme Graphics Driver for 845 Chipset-​Based Intel Desktop Boards" to your system.
Hope it helps.
Posted on May 28, 2011
My fonts and displays are to large how do i reduce them
Right click on desktop and choose "Properties" then select screen settings and set your resolution to say, 1280x1024 32bit,or if that is too small, try 1024x768 32bit, this will help.
Feb 24, 2010 | HP G60 Notebook
Can i connect an external monitor to the vga port and if so how do i enable it
Yes simply plug it into the VGA port on the laptop, Then go to desktop and right click, choose "Properties" when the windows shows the Monitors, you need to "Enable" the screen, and set the resolution, via the Slider, & set to, 1024x768 32bit, to start with, you may be able to set it to 1280x1024 32bit, after you get it all going, you need to also, select "Extend the desktop onto this monitor" Once all this is done, Reboot, it will now all work.
Feb 22, 2010 | Computers & Internet
I have a Dell inspiron 1011 netbook. The problem
Sounds like your screen resolution it way to low. Right click on an empty spot on the desktop and go to properties in the drop down menu. Then select the settings tab and raise your resolution to at least 800x600 32bit. 1024x768 32bit may be better. Good Luck
Nov 23, 2009 | Dell Inspiron 1000 Notebook
Resolution 1024x768 stuck in 8bit color i need
If you are runnineg windowsXP goto control panel by catagory select appearence and things then display, setting, then under color select 32bit, if you are unable to select anythingother than 8 I recommend you go to DELLs website and download display driver for your system.
Nov 23, 2009 | Dell Dimension 2400 PC Desktop
GRAPHIC CARD PROBLEM
Hi, I noticed you posted this same problem again. Here's the answer from the first post which should answer your question.
The maximum performance of your video card is limited by the hardware you attach it to. In the display properties of Windows, your highest resolution is 1280x1024 because your monitor is not able to go any higher than this. This resolution is a typical maximum for a 17" monitor. Some 15" can do this, and some 19" can do this. In order to get a higher resolution, you'll need to get a bigger monitor with a higher native resolution. For example, a nice 24" monitor can only do 1920x1200. The video card can go higher, but it's limited by the monitor. 32bit color is your highest setting - that's 16 million colors. Your video card's 1GB of RAM only determines how much rendered data (usually 3D) it can store and move at any given moment, which is related to but not determined by your screen resolution. That's a very nice card - you should be able to get very good frame rates, color, and performance out of 32bit color and 1280x1024. If you want a higher resolution, you'll need to get a bigger monitor.
May 13, 2009 | Computers & Internet
Nvidia geforce 9400gt 1gb card problem
Monitor turned black when i change the resolution to 32bit
press f8 when the computer starts up before windows boots and select start in vga mode or low resolution mode. after you get into windows change the video settings again but if the screen goes black, dont touch anything...it will revert back to what it was before. most likely, the resolution you picked isnt supported by the monitor. you also want to make sure that oyu have the video drivers installed properly aswell.
Apr 26, 2009 | Computers & Internet
My computer is trouble
Becoz you have to install VGA driver first...and u can get it from motherboard's website..
Jan 29, 2009 | Intel Motherboard
Chimei CMV 938D 'Out of range' error message only when using DVI Connector on specific resolution and color depth
I know this sounds obvious but- I had the same problem, and turns out the cord want plugged in quite properly at the back of the monitor. This may not fix every problem, but, I suggest you check the cord pligged in at the back of the monitor is firmly in there and restart, then if you still get the problem, contact the company.
Jul 21, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
