Question about Frigidaire Dishwashers
I can hear water going into the washer, water is on the bottom, and it is hot when I open, but the upper and lower spray arms are not moving to clean dishes.
  • 4,323 Answers
Hi
The issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling and/or draining ability.Use your voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If your switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Posted on May 28, 2011
Why doesn't my Bosch SHU43 c06uc dishwasher have any cleaning force?
With your dishwasher empty, roll out the bottom rack. The feed line for the upper spray arm runs from a pump outlet directly behind the lower spray arm spindle. This tube runs up the back wall of the dishwasher and mates with the upper rack when it is pushed in.
This feed tube simply snaps into place in the bottom of the machine. It is a high pressure line that makes an immediade 90-degree bend towards the rear of the unit. They have a tendency to pop out. When and if it does pop out you get almost no water coming out of the upper arm and you lose effective pressure in the lower arm, too. The cure is to push that feed tube back down firmly into the port until you hear it snap into place. While you have the lowere rack out it is a good idea to clean the intake screen out and check for any debris in the intake well.
May 24, 2014 | Bosch Dishwashers
Dishes do not wash. First we were having problems with the top rack not getting clean and now the bottom is the same way. Any suggestions would help. Thanks in advance.
Your spray arm jets are probably clogged.
Depending on the model, the lower spray arm generally has a nut or thumb/butterfly screw (plastic) that you remove and then lift the spray arm off. I always soak mine in hot soapy water and then flush with hot water. If debris such as pieces of paper, bone, peelings are in there, you'll need to take a tweezer or toothpick to remove them from the jets. The upper spray arm usually has the same apparatus and you can follow the same procedure.
The upper spray arm receives water pressure from a tube that runs up the back of the machine on the inside. If the connection has been knocked out of line, the water can't flow through the tube to the spray arm. My kids used to knock ours loose when they loaded the lower shelf. Pull out the top shelf and see if the plastic connectors are in place. If not, snap them back on the shelf supports and this should align the tubes.
One more thing: the bottom of the door..on the INSIDE of the machine.It's amazing how much "gunk" settles and accumulates under there. I use an old toothbrush, moistened in soapy water to scrub the underside of the door. Then pour hot water on the area. Next run a regular cycle with NO items in washer and use 1/2 cup white vinegar...no detergent.
I hope these suggestions help your problem. If so please come back to Fixya and rate my advice!
Jul 22, 2011 | Dishwashers
Items still dirty after wash cycle in bottom tray. i opened door after few minutes to have look c and i think the bottom arm isn't moving round. given everything a thorough clean not sure what to do...
Jul 21, 2011 | Bosch Dishwashers
MY DISHWASHER DOES NOT APPEAR TO BE CLEANING MY DISHES
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 11, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
THE UPPER TRY DOES NOT GET CLEAN, THE SPRAY ARM ON THE BOTTOM OF THE UPPER TRY AND THE SPRAYER AT THE TOP DO NOT TURN?THE WATER THAT COME SOUT AT THE BOTTOM IS WEAK ? WHY?
It could be that your dishwasher is not getting enough water. Let the water fill the dishwasher, set the spray arms in the same direction. Add a large pot of hot water and run the dishwasher. Open the door and check to see if the spray arms have moved. If they have moved, replace the water inlet valve.
Remove the 4 screws holding the lower kick panel. Remove kick panel. Locate the water inlet valve. This is the electrical valve where the water pipe hooks into the dishwasher. Shut off the water to the Dishwasher and electrical to the dishwasher. Disconect the 2 wire plug at the water inlet valve. Disconect the water supply to the dishwasher at the valve and disconect the rubber hose attached to the valve. Install new valve and test machine.
I hope this helps.
Jan 05, 2010 | Dishwashers
The dish washer do not spray water,there is water in the machine
Do you hear the pump run when it is supposed to? If so, you need to tear down the lower spray arm assembly to the deck. (keep track of orientation and placement of each part) At the bottom, you will find a large screen that must be removed and soaked in hot water/white vinegar/detergent for an hour of so to remove water and food deposits. Scrub the screen lightly to help clean it. Check all openings in the deck area for any food plugging--vacuum them out with a wet/dry vacuum. Reassemble all parts in reverse order--inspect all spray arms for hole plugging and any split seams. Hope this helps!
Nov 28, 2009 | Cars & Trucks
The bottom rack is not cleaning properly. Its as if the water pressure is not enough to wash the plates clean.
Ensure that forks or other cuttlery is not poking out the bottom of the basket and obstructing the lower wash arm.
Check to see that the lower arm is receiving water(and not blocked) to do this empty the machine and put a plastic bag around the arm that engages with a socket on the back of the washer this will block water to the upper arm and increase the pressure to the lower arm. Set the machine to rinse when you can hear the machine start to work open the door quickly and see if the lower arm is spinning!
Nov 07, 2009 | LG Dishwashers
Very low pressure getting to spray arms
I removed the lower spray arm, and then the filter. I found that there was a lot of buildup under the filter area. I scraped the buildup off. I found that it was restricting the input of water flow to the pump
Aug 01, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher runs doesn't clean
If your machine has the collapsible tower in the center of the bottom spray arm, it may not be operating properly. While the machine is running, quickly open the door to determine if the tower has popped up. (You might see it collapsing when door first opens.) If it pops up, it may not be sitting straight, which means the water is then not shooting up to the funnel of the arm located under the upper rack. (Your upper dishes will certainly not be cleaned well if this is the case, even if there is enough water to wet them.) Now open the door after running the machine 15 seconds to determine if the arms are moving. If upper arm is not rotating, you can be sure there is not sufficient water feeding into it. If the lower arm is also not moving, you likely don't have enough water in the machine to begin with. After about 5 yrs, the hot water can expand something inside the water intake valve (a washer?) which then blocks the flow of water. This was our problem and was very easily replaced.
Dec 27, 2008 | Dishwashers
Dishwashers Logo
57 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
