Question about GE AHK40LK Dehumidifier
My GE dehumidifier (AHM40LKG1) says its full and its completely empty. I also cleaned the filter. There is a green P2 lit up.
4 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: GE AHH40LH DEHUMIDIFIER
Either the humidistat is bad and not letting the unit cycle off, there isn't enough humidity in the air, or the condensor coils are too dirty.
Posted on Nov 16, 2007
SOURCE: polar wind dehumidifier: p1 or p2 code after emptying tank.
P1 error indicates that:
  1. The water tank on the side of the unit is full.
  2. The water tank in not properly seated in the housing.
  3. The switch at the back of the water tank housing is not engaged or is loose
Posted on Sep 01, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag Dehumidifier will not run. Indicator light says "full"
Here is a tip that I wrote to help people with just that dehumidifier2_bing.gif problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Posted on May 04, 2010
A bypass to well no longer occurs,; instead the bucket keeps filling up...also can't pull the filter out for cleaning purposes... In addition are we defeat ing the purpose of the dehumidifier by placi
well if the unit has never been taken apart and cleaned well inside, and it's five years in service , Id say thats your problem, anything thats got room air blowing thru it for five years ,It's gonna need to be tottaly cleaned in all areas
Dec 23, 2014 | Danby DDR6009REE 60 Pints Energy Star...
My GE Dehumidifier smells funny
You need to clean the filters every other week and I clean the bucket everytime I empty it with either mean green or water and vinegar
That should help it alot
May 01, 2012 | GE Dehumidifiers
Lifted up the dehumidifier onto a counter to empty the bucket and removed/clean the filter. Completed this task, replaced the filter and bucket, then sat the dehumidifier and it tilted a bit backward but...
It does have a tilt over safety feature. But if it wasn't plugged in when it tilted, it shouldn't have tripped the switch. However, if it was plugged in, it probably tripped the switch. Check your Owners Manual for how to reset the switch.
Feb 06, 2011 | Haier DE45EAL Dehumidifier
My DeLonghi Portable Dehumidifier Model DEM10 has stopped working. It doesn't make the same noise when you turn it on anymore i.e the slight refridgerator sound. Does this sound like a repairable problem...
First, make sure the reservoir is empty. If you plug the unit in and see a green power light, but the unit won't run, make sure the reservoir is properly inserted. Many dehumidifiers have switches or sensors to make sure that the reservoir is placed so that it won't leak. Look for these sensors and make sure the reservoir is engaging them. If your dehumidifier has a float or switch to indicate a full reservoir, make sure this switch isn't being tripped accidentally.
Good luck.
Aug 13, 2010 | DeLonghi Dehumidifiers
heatman101
May 02, 2010 | Maytag M7DH45B2A Dehumidifier
Polar wind dehumidifier: p1 or p2 code after emptying tank.
Jul 24, 2009 | Kenmore 54501 Dehumidifier
Empty bucket light is on and dehumidifier will not run
The float switch for the condensate reservoir (bucket) is malfunctioning.
It's sending a false signal that the bucket is full.
Maybe just stuck and needs cleaning or it may have failed.
May 31, 2009 | Whirlpool AD65USL / AD65USM Dehumidifier
P1 and P2 error codes
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
I hope that helps.
May 25, 2008 | Danby DDR2506 Dehumidifier
GE AHK40LK Dehumidifier Logo
279 people viewed this question
Top GE Dehumidifiers Experts
J.D. Browning
J.D. Browning
AZBen
AZBen
Are you a GE Dehumidifier Expert? Answer questions, earn points and help others
