Question about Hotpoint Aquarius WMA52 Front Load Washer
Belt replacement We cannot get the belt on , tried to loosen the motor , but is built into the plasticframe from the drum ?
Belt is a streach fit
put belt onto motor pully first then feed belt round drum pully
Posted on Aug 27, 2008
Drum belt snapped
unsure of your model here, but generally a drum belt change will require loosening the motor supports, putting the new belt on, then tightening the motor to correct belt tension.
Nov 09, 2013 | Washing Machines
HOW TO FIT A DRUM BELT ON A TUMBLE DRYER KELVINATOR
Normally you loosen the bolts to the motor after fitting the belt around the drum. DON'T try to streach the belt to fit over the motor pullery.
Dec 19, 2011 | Dryers
How to replace a belt on this style dryer, is there a trick
REMOVE THE SOCKET FROM THE WALL OUTLET.
To replace a belt that passes over the drum on a dryer you need to be able
to pass the new belt over either the back or the front of the drum. This
entails removing the front panel to clear the whole drum or loosening off
the rear bearing support to pass the belt under it so that the belt can be
passed over the drum. From there it is just a case of passing the belt
over the motor pulley and replacing all the parts. Select which will be
easier on your machine. After replacing everything but the top panel,
make sure that the belt is correctly installed by turning the drum several
revolutions by hand and ensuring that the belt is running true and still
on the motor pulley. Tension the belt by either adjusting the motor or the
tensioner, if the machines has one of those. Replace the top cover and
you are set to go.
Mar 19, 2011 | Dryers
How do a replace the belt on the drum of my indesit washer dryer
To replace a belt that passes over the drum on a dryer you need to be able to pass the new belt over either the back or the front of the drum. This entails removing the front panel to clear the whole drum or loosening off the rear bearing support to pass the belt under it so that the belt can be passed over the drum. From there it is just a case of passing the belt over the motor pulley and replacing all the parts. Select which will be easier on your machine. After replacing everything but the top panel, make sure that the belt is correctly installed by turning the drum several revolutions by hand and ensuring that the belt is running true and still on the motor pulley. Replace the top cover and you are set to go.
Feb 19, 2011 | Indesit Washing Machines
Tub won't turn belt broken ,how do you replace belt?
You can remove the lower panel below the door and see the motor and belt. To replace the belt you need to unscrew the front panel and slip the belt over the front of the drum. Reattach the top front panel with screws and loosen the tension roller from the front bottom access panel. Hook the belt around the motor pulley and tension roller. Tighten the tension roller and turn the drum by hand to make sure there are no restrictions and the belt and motor pulley are turning. It is best to inspect the drum rollers on the bottom of the drum to make sure the rollers have no play in them. If you can wiggle the rollers front to back replace them too. Replace the rest of the panels and check the units operation.
Feb 05, 2010 | Whirlpool Dryers
How to attache drive belt to drive drum .belt will not reach.loosening bolts that hold motor on did not help.forced on but belt twisted on drum.
Remove rear cover of washer, and top cover also, tilt washer towards you, get someone to hold washer steady, fit belt round motor pulley,and slowly feed belt round drum pulley, watch your fingers, keep feeding belt round oulley, turning drum at same time, it will be tight, but persist, and belt will go on.
Please rate my solution.
Thanks.
Sep 28, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Maytag washer will not spin. motor overheats and drum won't turn
If it has a belt try loosening the belt and see if the transmission and pump will turn and are not stuck.
If they are they will have to be replaced. Try the motor and see if it turns freely with the belt loose or off. If they all turn freely check motor.
Jun 09, 2009 | Maytag Atlantis MAV6000 Top Load Washer
How to replace belt by motor
To replace a washer belt, remove power, remove back panel. On the left side is the motor, clutch, pump and belt. The pump is driven by a coupler clamped to the pump and clutch assembly. Loosen one of these clamps enough to move the coupler away so the old belt can be slipped past the coupler and also to facilitate the new belt to be installed. The belt runs in a pulley built into the top of the clutch assembly and can be "run" onto the transmission pulley very easily. To adjust the belt tension, pull out the washer, tilt it back against the wall......there are 3 nuts and bolts holding the motor assembly to the bottom frame, loosen these nuts off, the holes on the motor bracket are oval shaped so the motor assembly can be moved back and forth. You can move motor to tighten or loosen the belt, just make the belt fairly snug and don't over tighten it.
May 03, 2009 | Washing Machines
How do I replace the belt that makes the drum spin on a Hotpoint Ultima WF860 ?
The belt goes around the drum and onto the motor pulley. No need to loosen anything. Put tension on the belt and fit it onto the motor pulley by gently turning the motor and pushing the belt onto the pulley at the same time.
Oct 28, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WMA52 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
