Question about Garden
We have a countax 600ce and there is too much petrol going thro the carb. there doest seem to be any adjustment on the carb. any ideas the mower runs well while cold then spluters when warm and spark plugs are black as your hat.
    Guru:
  • 479 Answers
Check the air filter isn't dirty and the choke plate is opening fully when the engine is running. If the carburettor has a float bowl, remove it ( hold a container under it to collect the fuel) This works like a toilet cistern keeping the fuel at a constant level in the bowl. Check the fuel shuts off when the float is pushed upwards. If it doesnt, the valve that cuts the flow may be dirty allowing the gas in the bowl to overflow into the carburettor. Examine the float, it may be punctured and sinking in the fuel. Clean out any dirt which has accumulated in the bowl.
Posted on May 28, 2011
How do I adjust the throttle/speed on my countax C800 ride on Mower
Making a throttle adjustment for the mower - YouTube
? 23:51
https://www.youtube.com/watch?v=gt0Tmo1p9cM
Apr 8, 2012 - Uploaded by VeeTheAmazingGreek
My old mower was all over the place when running. It would idlehigh then low. I came up with a way to ...Missing: countax ‎c800
[PDF]C SERIES - Pdfstream.manualsonline.com
Nov 23, 2015 | Garden
How do I balance the carbs on my 1996 Kawa ZX6R
To balance the carbs you will need sychronizing gauges and a petrol supply to run the engine while you adjust the carbs into balance I'vhttp://www.youtube.com/watch?v=t0qf11BOx6oe added a youtube video to give you an idea of how to go about this task
Sep 09, 2014 | kawasaki ZX-6R Ninja Motorcycles
Countax C300H running problems
carb jets probably need to be cleaned
May 14, 2014 | Garden
Countax
The spark plug gap need to be set or replace.
Jun 19, 2013 | Garden
Will spark but not continue to run and then stop
This sounds like a problem regarding old fuel, how long has the petrol been in this mower? The carb may need adjusting?? You can do this be adjusting the small screw on the carb, if not then take it to a mower service shop and have the carb dipped and blasted and change the oil and fuel, should work fine then, ( the video I posted is irrelevant)
Oct 21, 2012 | Garden
My countax mower c300 keeps blowing the p c b board
hi, my countax k18 is needed for this season for my buisness, after about 10 or so minuits it cuts out on me, no deck attached And i havnt engaged or disengaged anything... any ideas?? its defo electric as it cuts out really quick....
Mar 25, 2011 | Garden
I have a JCB 5.5HP which has started leaking petrol badly through the carb. I have checked the float and needle which seem to be working ok. It really does flow out both when I get it started and when it...
The ONLY way IN for fuel is the Float Valve, Now if petrol is coming out of the float bowl, then, the Valve must be faulty OR the Float mechanism, or spring, itself.
Jun 07, 2010 | Garden
I have recently been given a Scott Bonnar SX 4000, Model mower. It would not start. By spraying petrol in the chamber it sometimes started but then stopped. Checked the spark and have disconnected and...
I would suggest 2 things to start.
1. Get a can of carb cleaner in the spray can and spray inside the carb.
2. Get some fuel line cleaner and put in the gas tank.
If neither of these fix problem, a carb cleaning is undoubtedly in order.
(If there is old gas in the tank, by all means drain and fill with fresh.)
Oct 31, 2009 | Garden
I have trouble initially starting my MTD Yardbug mower. Once going, the engine runs great, but it seems like when the throttle lever is set to choke, it doesn't actually choke. I usually have to either...
Sounds like your throttle cable is out of adjustment (i.e. when you put the carb in choke position is doesn't actually go into choke).
Aug 24, 2009 | Garden
Garden Logo
155 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
