Question about Viper Security and Remote Start System (basic install included)
I HAVE A VIPER 5101 NEED INSTRUCTION ON HOW TO INSTALL IT
  • 81 Answers
Here is the wiring for the viper
Posted on May 28, 2011
Viper 5101 1-way remote won't work after replacing battery
Replacement battery could be defective installed incorrectly
Jul 04, 2016 | 5101 LE 1 Way Car Remote Starter System
Wiring diagram for viper 5101 to install on 2006 toyota fourrunner
Go to autozone dot com and make a free account, then put in the year and make and model, look for the free repair guides and then go to the electrical diagrams.
Jul 21, 2013 | 5101 LE 1 Way Car Remote Starter System
I need an installation guide for a Viper 5101 remote start system . Where do I go online to find one
I didn't try downloading it, but I was able to view it:
http://www.scribd.com/doc/45065156/Installation-Viper-5101
Feb 01, 2011 | Viper Security and Remote Start System...
How to install viper5101 on hummer h1 2006 model.
hi,
i have the installation guide for the viper 5101, if you need the same will sent it to you. it will help you to do the same. sent your email id will sent u the guide.
ok
Jan 24, 2011 | Viper Security and Remote Start System...
I need instructions on how to use my viper 5101 remorte starter
go to www.directed.com this is the manufacturer of the viper remote starters, there you should be able to download instructions.
Here is how you program the viper 5101 remote.
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Dec 30, 2010 | 5101 LE 1 Way Car Remote Starter System
Is there anything needed to install a viper 5101 in a 2009 honda odyssey?
You will need some type of interface module to bypass the transponder in the key inorder for the remote start to turn on the van.
Dec 23, 2010 | 5101 LE 1 Way Car Remote Starter System
I need the wiring diagrams to install a 5101 viper remote start on a 2007 Honda Accord with auto trans.
Have you tried this site yet?
Here is a copy of your requested guide.
http://www.directeddealers.com/manuals/OG/Viper/G4102V_2008_09_web.pdfsee pages 13 and 31
Please let me know if you have any problems with it.
Thanks
Bruce
Dec 15, 2010 | 5101 LE 1 Way Car Remote Starter System
Viper 5101 Manual Transmission - can't start
First off, is it in neutral? It can't engage the starter motor if it's in gear. Secondly, If it was professionally installed, why not just take it back and demand that they fix it?
Your wiring should somewhat match this.
Jan 13, 2010 | Remote Start System
Viper 5101 installation guide not the owners manual if anyone can help please
Good grief.........where is the installation guide.........on viper web sight the guide is merely how to program the damn remote.....all 40 pages..
Nov 19, 2009 | Viper Security and Remote Start System...
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
310 people viewed this question
Top Viper Home Security Experts
Will Halftowaite
jason
Kevin Daniels
Are you a Viper Home Security Expert? Answer questions, earn points and help others
