Question about Hoover Vacuums
I have a hoover carpet cleaner model f5808 after shampoo the dirty water does not come back into the bottom canister. i push it back and forth. what am I doing wrong or what could be wrong with the cleaner.
5 Suggested Answers
SOURCE: Hoover SpinScrub Carpet Cleaner
I was having the same problem, the black seal under the tank that captures the water was broken, and it wasn't getting any suction.
Posted on Feb 06, 2008
  • 97 Answers
SOURCE: Hoover Steam Cleaner - dirty water is not coming up in the tank!
recovery tank (dirty water tank) not on correctly
Posted on Jul 20, 2009
  • 231 Answers
SOURCE: I have a Hoover steam vacuum carpet cleaner Model
the lever on the handle should be pressed when you want to apply solution to the carpet
Posted on Jan 04, 2010
SOURCE: hoover aquamaster
sounds like you need to attach the air hose
with reservoir in place you clip on the lid with tubes attached, one of them goes down to the floor cleaning nozzle, the other tube should be about 20cm long with an end piece,
this is the air hose and it fits into a small hole under the reservoir on the motor housing (the heavy mains powered part that clips onto the big recovery drum that sits on floor)
it's mentioned briefly in the manual, here it is in pdf form http://www.box.net/shared/rnh39ffjcq
Posted on May 14, 2011
I borrowed my friends Hoover carpet cleaner and cannot figure out which side the shampoo goes in. Model #F6213-910
Put water in one side (just pick one), if it doesn't spray on the carpet it is the other tank you need to fill with cleaner.
Feb 16, 2017 | Hoover Vacuums
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Please assist. i have not use my cleaner in awhile not sure if the clean water goes in the top or bottom.
The clean water goes in the upper tank mixed with shampoo, and after the water is extracted from the carpet, it will go into the lower tank. Clean water top tank, dirty water lower tank.
Hope this helped you!
Chris Jones
GoVacuum.com
May 13, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover carpet cleaner does not **** water it blows
push the little square thingy down on the very front of the bottom bucket, then put the lid on before you put it on the machine, then let the force of putting it together push the front thingy up when you put the bottom bucket on the machine as one assembly..... it makes the seal right somehow..... ....my wife about pulled her hair out before we figured it out the hard way...... I may get a reward tonight......
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Dec 29, 2009 | Vacuums
Instructions or manuel was not included.
i downloaded the manual for your machine, but not sure how to access it for you,but i do know about the problem, the tank that sits down on the front of the steamer and it has 2 clips that you push in to lock the tank is where your dirty water is put in when you are cleaning your carpets. the tank above ,the one where you put your solution and water in is what is used to shampoo your carpet. on the handle is a trigger (black) button ,this is the button you push in to release your solution onto your carpet. release the button to extract the water from your carpet,moving your steamer in a back and forth motion. the trigger button is the only button on the machine and is only used to put the water /cleaner located in the upper tank on your carpet, releasing this button and moving your steamer back and forth over the shampooed part with extract your dirty water into the tank that sits below the solution tank. go on www.hoover.com and click on carpet cleaners ,scroll down to find yours and click on manual. and the owner manual will download and you can print it out for future reference, i hope this will solve your problem, sandy
Nov 29, 2008 | Hoover F5810 SteamVac Upright Vacuum
Not sucking up water
Hi.  I had the same problem.  After looking at the manual I went back and made sure the canister was making a proper seal.  That fixed the problem.  Make sure when you put the top back on the canister (that holds the dirty water), that you place the two front hinges in  place first and then snap the center clap on the back of the top.  This will give you a proper seal for suction. (My two front hinges weren't fitting correctly.)
Oct 25, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell 9300 carpet cleaner
You put hot tap water (never boil water) into the clear bag through an opened hole in the canister. The dirty water will be correct outside of the bag. You remove the dirty water by open the valve at the bottom of the canister.
good luck
Sep 01, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover SteamVac Deluxe
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=624426
Posted by providence51 on May 26, 2008
My cleaner is not dispensing the shampoo solution. Still sucks up the dirty water that I manually applied with a scrub brush. I use this on my tiled screen porch floor and it has worked great many times.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There is a release value in the bottom the holding tank that may be bad and not opening or the trigger assm in the handle may be broken and not connecting to release the water to scrub and clean the carpets. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
