Question about Mitsubishi WS-55807 TV
Mitsubishi CK-3526R (PIP model)
The screen on my brother's TV started to darken for unexplained reasons. I removed the board on the back of the tube, but that was a temporary solution. It got to the point where it stayed dark. I dobut that the tube's worn, because one time, it went up for a second and died right back down. Also, when it gets dark, I can see about 40 faint white lines running across the screen. I have a hunch that it might be the horizontal driver, but it's just a hunch. I looked for leaky capacitors and loose soldering points, but I didn't find any. Can anybody help me?
  • ae_7fam Aug 19, 2008
    I should mention that the lines are starting to double in size and that it dims into the nothigness, including the menus.
    i have tried disconnecting for 5-10 mins, but didn't work.
    how could possibly disconnecting the tube and reconnecting fix the tv (temporarily)?
  • ae_7fam Sep 25, 2008
    HAHA.... I knew that as soon as the back was put on, a soultion would pe posted! Kinda ironic, if you ask me.
    I'll get to it when I get the time.
  • 927 Answers
GOOD DAY; 1. CHECK C218 4.7 UFD 50 V, AND C220 47 UFD 35V ON THE SIGNAL PCB. 2. CAN BE OBSERVED AS DISTORTION ON DC PEDESTAL PORTION OF STAIR STEP PATTERN. SUSPECT C222 OPEN. LOCATED ON PCB-SIGNAL AT IC200 PIN 35. (10UF 35V) 3. SHOWS UP ON COLOR SIGNALS ONLY. OK ON B/W PICTURES. CHECK X600 AT IC200 PIN 13. SHOULD BE 3.58MHZ. LOCATED ON PCB-SIGNAL. PT# 285P02905 4. (COLOR LINES) CHECK C601 47 UFD @ 35V ON THE COLOR CONTROL OFF PIN 36 OF IC200 ON THE SIGNAL PCB. 5. SUSPECT C222 OPEN. LOCATED ON PCB-SIGNAL AT IC200 PIN 35. (10UF 35V) . REMOVING CRT SOCKET, YOU MAY HAVE CORROSION ON THE PINS OR POOR CONNECTION ON CRT BOARD, AND BY REMOVING IT COULD HAVE CLEANED THE PINS A LITTLE. TRY CLEANING PINS ON CRT AND SOCKET. GOOD LUCK, big IRISH.
Posted on Sep 25, 2008
  • MICHAEL MULLINS Sep 26, 2008
    Let me know if works, it should. Good Day, big IRISH.
Mitsubishi CK-3526R TV
not sure what light picture has to do with problem  but no there is no  vertical hold control  prob bad electrolytics invertical feed back circuit, need tech..
Dec 07, 2008 | Mitsubishi WS-55807 TV
Tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
Tv problem
Hi and welcome to FixYa,
Based on your description of the fault on a conventional CRT TV , initial suspect would be a capacitor in the vertical circuitry. There would be a number of capacitors within the vertical area, the probable faulty one would be the biggest of the bunch. It would be relatively close to the vertical IC that is mounted on a heatsink. Incidentally, the technical name of your describe fault is "vertical foldover".
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 29, 2008 | Televison & Video
Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CK-35402, CS-40FX1
manufacturer.
personal code.
Oct 26, 2008 | Televison & Video
Mitsubishi tv model VS6061 rear projection with rolling picture.
I know this is an old thread, but I would like to post this information in the hope that someone will find it useful.
I just finished fixing this problem on my 1994 VS-6061... the problem is the PIP (Picture In Picture) board located on the Power Signal board. The PIP board contains the numbers 530B552. I bypassed the PIP board by following the directions I found at the following link:
http://forum.doityourself.com/entertainment-center-tvs-stereos-vcrs-dvds/130383-mitsubishi-cs-35301-rolling-picture-problem.html
"Plug in a 4.7ufd @ 35v filter cap (+)at pin 5,(-)at pin 11. Plug in a .01ufd(any voltage) between pin 7 and 9. Just plug the caps into the socket, where the PIP board was mounted (they don't need to be soldered). Just don't let the leads from the two capacitors touch, as they cross each other. The 0.01 cap is non-polarity, so either way it plugged is fine. Basically you will bypass y-signal through 4.7u, in pin 5, out pin 11, and bypass c-signal in pin 7, out pin 9 of the PIP socket.”
The bypass requires 2 capacitors: One 4.7ufd @ 35v and one Non-Polar 0.01ufd @ any voltage.
Remove the PIP board, then plug the two capacitors into the socket where the PIP board was mounted: plug the 4.7ufd capacitor with (+)at pin 5,(-)at pin 11 and plug in the non-polar .01ufd capacitor between pins 7 and pin 9.
If there is a ground wire (possibly brown) soldered to one of the tin cases on the PIP board, then you should connect this ground wire to the PIP socket either at pin 2, 4, 6, 8 or 10 which are grounds of the socket.
This PIP board was used in many Mitsubishi televisions and they were plagued with problems...This is why many of these older Mitsubishi televisions had similar problems…
Good luck
Jul 19, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Mitsubishi TV hand me down
the problem you have is the video goes thru the pip board first and the pip board has a problem this is a known problem. the pip board has some capacitors that leak on the board. the model you mention is CS-27MX1 not XM1 but anyway the back casing was made for several sets of that size. so the pip is the problem and the bulletin is as follows;
1. NO MAIN VIDEO,THERE IS VIDEO IN PIP ON EXT1 AND EXT2:-CHECK FOR 1VPP OF LUMINANCE ON PIN 1 OF IC7000, IF MISSING OR LOW CHECK THE VALUE OF C7001 (4.7UF 35V), LOCATED ON THE PIP-PCB.THIS CAP MAY LEAK ELECTROLYTE ONTO THE BOARD AND OPENED A FEED THROUGH IN THE PATH BETWEEN C7001 POSITIVE LEAD AND THE EMITTER OF Q7003 OR CAUSE INTERMITTENT COLOR. PT#181P504090. 2. NO MAIN OR PIP VIDEO, CHECK CHECK C7014, 47 UFD 35V ON THE PIP PCB. PART # 181P502060 3. CHECK FOR 7.2V DC ON THE BASE OF Q7003,IF LOW OR MISSING.CHECK THE VALUE OF R7002 (150 OHM 1/10W).LOCATED ON THE PIP-PWB. PT#103P401050 you can by pass this by removing the pip board and jumping the VP connector pins 7 to 9 and 5 to 11
Mar 07, 2008 | Televison & Video
Tube tv bouncy picture
I've seen this problem before, would need your model #, meanwhile is your picute bounce when you hit the if pack, or pip module, if it does that were your problem is. these or your silver cassing, standing upward.
Regards
What About Bob
Feb 18, 2008 | Televison & Video
My mitsubishi vs 5071
You might have a bad PIP board, When you say NO picture. Is it totally blacked out or blacked out with "blue snow". The PIP has been alot of problems in this chassis and you will experience what your describing. Capacitors are the root of the PIP boards failure. Let me know if I can assist you further.
Jan 26, 2008 | Televison & Video
Tv problem
Good Day;
Sounds you have a bad vertical output IC that is defective along with some caps. Change IC > LA7838 > IC401 and ALL CAPS like cap off of pin #6 1ufd 25v and etc.
Good Luck, big IRISH.
Dec 12, 2007 | Mitsubishi WS-55807 TV
Mitsubishi CK-3513R - Horizintal white line
this ic is soldered onto the board with a heat sink it is related to horizontal circuit.your problem could also be the flyback.good luck
Apr 12, 2007 | Mitsubishi CK-35308 35" TV
Mitsubishi WS-55807 TV Logo
140 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
