Question about Beckett Corporation Beckett Professional Pond Pump, 3500 gph
The impeller for my Beckett w3500hd broke, where do I find a new one?
How to remove a pressed on impeller
Is it pressed on using a keyway on the impeller shaft or is it simply a pressed interference fit?
Jul 21, 2014 | Beckett Corporation Beckett Professional...
Where sale a impeler for beckett w3500.
http://www.homedepot.com/p/Beckett-3500-GPH-Submersible-Waterfall-Pump-W3500HD/100024869
Or if Home Depot can't help you in ordering an impeller for a pump they carry, try sending an email directly to Beckett and ask for assistance on where to get one...
customerservice@beckettpumps.com
Good Luck
May 09, 2014 | Beckett Corporation Beckett W3500 7114310...
Cant remove broken impeller
Lift off. You may have to attempt to pry it off with two screwdrivers. Other method is to hold it by the impeller while someone takes a brass punch and a hammer and gently hit the end of the shaft to knock it free. Try to avoid damaging the shaft or you will have to dress the shaft up to get the new impeller on.
Aug 20, 2012 | Beckett Waterfall Pump W5000 4983 gph
How to remove impeller
Pull off. Or pry off with two screwdrivers. Or hold it by the impeller and have someone tap the end of the shaft with a brass punch.
We have a Beckett W5000 a rock got in the systems and broke the plastic puppelor. Where can we buy trhe part to fix it???
Email Beckett at: customerservice@beckettpumps.com
Call Beckett at:
972-871-8000 or Toll Free at 1-888-BECKETT (232-5388)
Fax Beckett at:
972-871-8888
Write to Beckett at:
Beckett Corporation
c/o Customer Service
3250 N Skyway Circle Dr
Irving, TX 75038
Warranty & Technical Assistance:
The NEW toll free number for warranty information, replacement parts, and technical assistance with water gardening and fountain products is 866-466-4319 or email Beckett atCustomerCare@beckettpumps.com
For information on CE, VDE, or DENAN (PSE mark) certified pumps:
Please email Beckett at: customerservice@beckettpumps.com
Or write to them at the address above.
Aug 28, 2011 | Beckett Water Gardening Beckett Statuary...
Beckett # W1150 WTRFall/Str Pump: Our pump will run for an hour or so, and then it s...
This same symptom happened to me.Check the impeller, if you can pull it out or it just sloshes around in the well housing, then the impeller lock has come out of it's place. Simply pull off the outer intake grill, then twist off the outlet housing. Now you can see that white notched washer and how it must be seated and aligned. Once seated in place use a small screwdriver to turn and lock it in. Now you will see your impeller shaft is no longer loose.
May 17, 2010 | RTO Beckett # W1150 WTRFall/Str Pump
Where can I find a replacement impeller for a 10 year old beckett water pump? The only model information I have is "798" stamped on the out side of the casing.
I'll bet you need to buy a new pump.Most pond pumps from Beckett are sealed and the impeller can't be or should not be changed.
Sep 27, 2009 | RTO Beckett # W1150 WTRFall/Str Pump
Is there such a thing as a rebuild kit?
There is no 'rebuild kit' for the pump. Clean filter and, depending on your mechanical skills, remove pump and cover and cleans out any debris in pump impeller.
Sep 03, 2009 | Beckett Water Gardening Garden
I need an impeller housing (part no. CX1777) for a Beckett Versa Gold G325AG20 pump.
The web site for "Otimus home" will get you in touch with more parts than most sites. This site is for pool parts they also have a site for spa and smaller pond equiptment.
Aug 20, 2009 | Garden
Beckett Corporation Beckett Professional Pond Pump, 3500 gph Logo
154 people viewed this question
Top Beckett Corporation Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Beckett Corporation Garden Expert? Answer questions, earn points and help others
