Question about Maytag Ensignia MAV2757AWW Top Load Washer
I have a Maytag Ensignia and the water will run but the tub will not fill.
    Master:
    Sergeant:
  • 385 Answers
You may have to just raise the drain hose up higher. It sounds as if the water is going out the drain hose as it tries to fill.Drain hose should be up as high as the top of the washer.Hope this helps.
Posted on May 28, 2011
Maytag ensignia top load washer will not fill with water at start of the cycle?
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
Tub is filling with water while off. is it the control valve inside the washing mach?
You need to check your water level switch. Make sure the clear hose that runs from the tub to the control panel is clear, not kinked or clogged and has not come loose at either end. Hope this helps
Mar 21, 2010 | Maytag Ensignia MAV2757AWW Top Load Washer
The water continues to run into my Maytag Ensignia after the cycle is complete
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Oct 05, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag washer
Many of the maytag toploaders have a rubber fill hose at the top of the outer drum.
Sometimes if the machine is fully loaded (or overloaded), during the spin cycle if clothes are above the top of the drum they can actually knock the rubber flange of the hose out of the drum. Then when the machine fills with water, it will dump it down the outside of the tub and it will appear that the water is leaking from the top and side of the drum... Fix it by snapping the fill hose flange back into the hole in the top part of the drum... let me know how you do or need more help...
Mar 23, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag ensignia washer...cold water settings
You need to remove the cover and check the voltage to the cold water inlet valve. Do this with a volt meter while it is set to fill with cold water. It is most likely an AC voltage that is around 24 volts. If you have voltage then the valve is most likely bad.
Feb 16, 2018 | Maytag Ensignia 3.3 cu. ft. Top Load...
Washing machine
the number one cause of this is your drain hose is too far down in the stand pipe or too low beneath the tub the drain hase should loop above the tub and about 4 inches down in the stand pipe if not this will create a siphoning effect that will drain the water as it fills
Jul 13, 2008 | Maytag Ensignia MAV2757AWW Top Load Washer
Water comes back in
Does after the second spin the tub fills with water again or stay with no water ?
Sep 04, 2007 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag Ensignia MAV2757AWW Top Load Washer Logo
155 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
