Question about LG Televison & Video
It is still not working plz can u help It still flickers
  • LG Master
  • 17,130 Answers
This is typical with many sets when it goes old as there is a high possibility that the components over a period of heating and cooling , tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs.
Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Posted on May 28, 2011
Sir, i have dell 1209s projector. when i turn it on, it works only for 5-10 min. with flickering image. after that two red lights comes on the buttons. plz help me
It may be a faulty lamp module, Have you replaced the lamp at all. It may be at the end of its life.
www.avprojectorlamps.com is probably the cheapest company to use.
hope I was of help to you
Aug 05, 2011 | Dell 1209S DLP Projector
My samsung lcd (model name - 933sn) monitor screen is flickering in every 2 seconds, although i have set the recommended resolution setting 1360 x 768, and the refresh rate is 60 hz, i have already...
This could be an issue with your computer's video output card rather than the monitor. Try connecting your monitor to another known good computer and see if it still flickers; you can also try connecting another LCD monitor to your computer, and see if the same behavior occurs.
Hope that's helpful.
Jan 13, 2011 | Samsung 933SN Monitor
Flickering mouse
Sounds like overheating, buy a zalman fan kit, with the little blue aluminium heatsinks.
Jul 21, 2009 | Power Color Powercolor ATI Radeon 7000...
Crackling and flickering of monitor continuosly
somehow i dont think theres anything you can do for it, judging by what you said, the overload was way too much for the screen
so, solution, get another screen, and get a decent surge protector, might not do much but it may prevent this from happeneing again
hope this helps
May 16, 2009 | E-Machines eMachines Monitor E15T4
LG 42LC2DB LCD TV Flickers when Ps3 is connected via HDMI port
Make sure you have the PS3 set to the correct frequency for the TV. Many cannot accept 1080p / 24fps etc.
Try different settings.
I hope this helps.
Mar 28, 2009 | Televison & Video
Screen flickers
ram problem once clean the ram and insert it again if the problem occurs again the change ur ram it will rectifye ur problem
Jan 22, 2009 | HP Pavilion MX70 17" CRT Monitor
Neff B1432 Oven Not Heating; oven light flickering
If the fan is working o/k then you need a new element fitting.
Remove the panel at the rear of the oven, there you will see the element, remove the fixing screws and ease the element forward,taking care not to lose the wires, disconnect the leads and fit new element.
The light flickering is probably the bulb not screwed in propely or a bad contact, nothing to worry about.
Plz rate my solution.
Thanks
Dec 19, 2008 | Neff B1432 Single circotherm plus Electric...
JVC NV-50D500 Flickering
convergence board problems u will nedd replacment soon
plz do rate this post
Nov 30, 2008 | JVC AV-48WP30 48" Rear Projection...
Screen flickers
may be cos of coldsolder at the main board.
just try try up to resolder suspected point.
May 11, 2008 | LG Studioworks E700B 17" CRT Monitor
Will not turn on
  • as the power flickered at your house so most probably due to fluctuation fuse must have gone.
  •  & it that found to be ok then there is a possibily that output transistor  must have failed.
  • though it is not major but if you are not aware of high voltage plz take the help of tech person.
  • hope this will help
  • good luck.
Oct 21, 2007 | Insignia NS-30HTV 30" TV
Televison & Video Logo
Computer Repairing
Computer Repairing
