My computer it does not detect any drive and had error code 1000-0141
  • 68 Answers
Please indicate the brand, model, O/S version, etc. How long have you had this machine? Open the BIOS on bootup and see if it can detect the devices there.
Posted on May 28, 2011
Error message on dv 1000 pxe-mof and pxe-e61
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Apr 17, 2013 | HP Pavilion dv1000 Notebook
Not booting up
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Apr 03, 2012 | IBM ThinkPad T42 Notebook
Error codes pxe-m61 and pxe-mo0f
The error PXE-M61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Dec 19, 2011 | Toshiba Satellite P35-S611 Notebook
I tried to download windows 7 on my ACER 5351, and near the end the laptop restarted. It came up with this error code : Cannot boot from CD: Code 5. When I took the CD out, the following error code...
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Aug 11, 2011 | Computers & Internet
Hd will not read and puts up error code 43
I had the same problem with a WD external hard drive. I tried it in multiple computers and it was never recognized. I uninstalled the driver from the same screen where you see the error 43 message, then swapped the USB cable connecting the drive... and then the computer detected it. It suggested a chkdsk which I ran, it looks like its back to normal now
Nov 25, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Computer won't boot up. Error code 0146 and error code 2000-0146
Good day.
Error code 0146 basically refers to a hard drive. This means your computer is not detecting properly your hard drive or your hard drive itself is defective.
Let's first isolate the problem. Go to your BIOS setup (Pressing F2 upon power on) and check if your hard drive is properly setup in your BIOS. Make some necessary adjustments and save setting.
Turn-off your pc and try to check the data cable and the power cable is properly connected to your hard drive. You may also try re-seating the data and power cables - remove first and then connecting it again to the hard drive. Loose cables may cause problems. Power on the pc.
If you still receive the same error, then you need to replace the hard drive with another one.
Good luck.
Tedmac
Sep 28, 2010 | Computers & Internet
To solve code error 0146 and 0148
Both of these are hard drive errors. Error 0146 is a failed hard drive or bad drive sector, and 0148 is that thew machine is no longer detecting the hard drive. Basically, your hard drive has failed and will need replaced. Replace the hard drive and you will be set. The best place I've found to buy hard drives is at pricewatch.com, they have the best prices on the market.
Jul 29, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
David Payne
David Payne
