Tv power light blinks and won't turn on - Televison & Video
  • Televison & ... Master
  • 17,130 Answers
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Posted on May 28, 2011
4 Suggested Answers
diodeic
  • 1622 Answers
SOURCE: We have a 46 inch sharp tv model number 46SB54U
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will helpout ......
Posted on Jun 25, 2011
electrotech1
  • 1126 Answers
SOURCE: Have a 42" Tv that won't power up. Power to
The electrolytic caps need change out on the power supply or you can purchase a new remote at www.partstore.com
Posted on Sep 14, 2011
protvrepair
  • 153 Answers
SOURCE: Heard a pop , bulb blew out , replaced bulb , it
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Posted on Oct 29, 2011
Timer light blinking and tv won't turn on
Not much info to go off of, and the video is a bit blurry. Try unplugging the tv for a minute or two, make sure to leave it unplugged to allow power to dissipate. Then try again. Otherwise I would suspect power supply problem.
Apr 10, 2013 | Televison & Video
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Jan 28, 2013 | Panasonic PT-56TW53 56" Rear Projection...
Tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
Oct 20, 2012 | Samsung LN-S3241D 32 in.LCD HDTV
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
Power button won't turn tv on. light keeps blinking on and off
Main board to your TV is faulty. Check the chroma and video processing section. In most cases, it will be due to an IC fault.
Jul 23, 2012 | Curtis-Mathis Televison & Video
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Jul 03, 2012 | Panasonic TC-P50X1 50 in. Plasma HDTV
My plasma tv won't turn on only the light
Blinking light usually is a error code if blinks a certain number of blinks and the place to begin is to look for a bad fuse or bad puffed up caps inside on the power supply board--place to begin.........
Apr 16, 2012 | JVC Televison & Video
MY LCD PHILLIPS MODEL 42PFL3704D/47
Good day!!!
if you have power problem without blinking lights or standby lights (red) the possible problem is power supply board..However if the TV have blinking or standby light but won't turn ON..there are multiple cause of that and need further troubleshooting..
Mar 11, 2012 | Philips 42PF9431D/37 TV
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Televison & Video Logo
160 people viewed this question
Top Televison & Video Experts
Electro Med Services...
