Question about Microwave Ovens
Instructions please for a 'Bosch espresso cup' coffee maker
No nothing similar at all.
Posted on Sep 30, 2011
    Guru:
  • 479 Answers
The manual can be downloaded here:
http://www.bosch-home.com/us/products/small-appliances/tassimo-coffee-machines/list.html
Click on the picture of your model type, then click on "additional documents" and finally click on "user manual"
Posted on May 28, 2011
Bosch combi cup manual
Unfortunately the manual necessary to adjust the problem is no longer available. That was over 20 years ago!
Feb 26, 2014 | Microwave Ovens
Lost directions - how to descale keurig ?
Hello, Here is a tip i wrote, see if this helps you.
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Jun 29, 2011 | Microwave Ovens
We have a 12 cup Mr. Coffee about a year old. We put 4 scoops of coffee in and the appropriate amount of water. Every day, the filter overflows and grains of coffee get into the pot. How do we keep this...
Because I own a espresso company,I believe I can help you. There is several things that can cause a coffee machine to over flow. 1, putting to much coffee in, where water can not drain through filter. 2. The grind of the coffee, if it is ground to fine, like ground for espresso, will not allow coffee to flow through filter , drip machine that are not under high pressure like espresso machines have to have ground more course. 3, wrong type of filters, not fine enough for water to flow, or made for high pump pressure machine such as espresso machine . 4, putting to much water in, is not an issue on a mr coffee, because even if you fill it to full cup line, it would have nothing to do with filter over flowing, besides the coffee grounds always absorb some of the water anyway. In conclusion, my positive professional diagnose is Grounds of coffee to course, and 4 scoops seem a bit to much for a filter of a mr coffee machine that holds only 12 cups. To test this is make a pot same way and use only two rounded scoops and see what happens, if does not over flow that solves that. But your saying I want it stronger, believe me I know. I too like my coffee strong and a flavorful . I have that solved too. Go to a good walk in espresso shop, like a star bucks, tell them you want some good strong blend and have it ( Ground for Drip) and then still only put two rounded scoops, it takes less do to the blend and kind of coffee. Please let me know if my advice worked, thanks mike. oh notice my screen name of mc1 bean, now you know, I know what I am talking about :)
Jun 07, 2011 | Microwave Ovens
My Keurig coffee maker will makes a grinding sound when the start button is pushed, the K-cup is in place, but water does not pour through into the cup.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
May 07, 2011 | Microwave Ovens
My Keurig coffee maker no longer gives a full cup of coffee even on the largest setting.
heatman101
May 04, 2011 | Microwave Ovens
How do you go about "descaleing" the coffee maker? The water does not flow through the coffee capsule very well.
I know that most grocery stores sell a "cleaner" or two next to their coffee filters/coffee makers/kitchen appliances section. These are usually heavily acidic, and will do a great job of cleaining your coffee maker. I've always been wary of acid in my coffee though, so I just use white vinegar. It'll do a decent job of cleaning out the coffee maker. Run a 1:1 mix of water and vinegar through your coffee maker, drain it, then run water through at least twice.
Scaleing/deposits building up in a coffee maker are signs of imperfections in the water. All tap water has it, but if you don't want to worry about it, use bottled or filtred water in your coffee pot. Plus, your coffee will taste better!
Mar 16, 2011 | Microwave Ovens
We received a 14 Cup Delonghi coffee maker DC312T and the carafe leaks. We love the coffee maker, & do not wish to return the unit. It was ordered on-line... All we need is a replacement carafe. ...
Sorry to read about your problem, I hope this helps you out.
Contact Delonghi at Delonghi.com
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | DeLonghi Microwave Ovens
How to program my Hamilton beach Coffee Maker,49464 To make coffee in the am before I get up.
12 Cup Programmable Coffee Maker 49464 could help you to operate your Hamilton Beach Coffee Maker. Anyway, if you are looking for a best coffee maker that can extract a perfect cup of coffee, allbestcoffeemakers.com is a great choice. Hope it helps you!
Nov 30, 2010 | Hamilton Beach Microwave Ovens
How much coffee grounds should I use for 30 cups of coffee made in a west bend 30 cup coffee maker?
!/4 cup of coffee for every 8 cups of water or almost a full cup of coffe for your 30 cup pot...
heatman101
Sep 07, 2010 | Microwave Ovens
Microwave Ovens Logo
1,064 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
