Question about LaCie MosKeyto - USB Flash Drive - 16GB USB 2.0 Hard Drive
I have a Lacie mosKeyto 8GB USB Flash Drive. When it it inserted into a PC it just does not show up at all, meaning computers do not detect it. What can I do? thanks
  • t_nedilko May 28, 2011
    Hi, thanks for that, but I have tried it on many different computers and it seems that its the USB flash drive problem. I've only used it for a week or so before this happened so I'm not sure what have gone wrong, any ideas on what i can do in fixing this? many thanks
  • 89 Answers
Hi have you try connect it to other computer? if is working i guess your usb port have problem try to connect your flash drive to other usb port at the back your cpu. if not working your usb flash drive have problem. thanks
Posted on May 28, 2011
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My Lacie Moskeyto USB stick can no longer be seen by my PC. More than that if the stick is inserted the My Computer window remains blank and the "hampster wheel" turns indicating the PC is...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps you
Sep 12, 2011 | LaCie MosKeyto - USB Flash Drive - 16GB...
I cannot get a SanDisk flashdrive to go into either of the USB ports on my new desktop computer. I am using the USB ports located on top of the computer
To test the functionality of the usb ports in front of the computer
1. Insert another flash drive or another usb device like a usb mouse on front the computer 2. If it detect the usb device that means 2 things flash drive might be bad and the front usb port is working 3. If it does not, It means that the flash drive might be bad or the usb port is not connected to the front panel of the computer 4. Try also inserting the flash drive at the back of the computer see if the usb drive is detected in all ports 5. Check the BIOS for any usb port associativity
Jul 05, 2011 | HP Computers & Internet
Lacie moskeyto is undetected in Windows 7
if your BIOS is set to "allow classic USB support" (or similar terminology), then you are restricted to the drivers available at the date of BIOS version (or your PCs date of manufacture). The reason is, 16gb flash dd not exist n 2006. Most PCs/BIOS before 2006 can only mount 4gb flash memory or less. Most 2007 through early 2009 is limited to 8gb (this is not a restriction for USB HDD enclosures, older PCs can mount hundreds of gigabytes with older BIOS drivers).
1. If your BIOS allows you to change this setting, deselecting it may allow the OS to load a driver (Vista and Win7 both have native 16gb drivers).
2. Updating BIOS, if a newer one is available for your PC is also a solution, as flash media driver updates are almost always included.
3. if neither options are available for your PC, then you can go get a specific driver for this device from LaCie.com
One caveat: LaCie is renowned for slicing flash memory into two partitions. One is usually a "fake" read-only CD partition. This will not work in many updated BIOS, and even some of the newest PCs. USB HDDs can have multiple partitions, but not flash memory. If this is the case with your PC, then again, your only solution will be getting a device-specific driver from LaCie.
May 27, 2011 | LaCie MosKeyto - USB Flash Drive - 16GB...
I can't access my files on the LaCie Moskeyto 16 GB USB flash when I plug in the dive in my laptop. The device manager says that no driver has been installed.
you might need to update the drivers or reinstall it
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
Apr 06, 2011 | LaCie MosKeyto - USB Flash Drive - 16GB...
My trancend 8gb pendrive when inserted dont show name of transend
Dont worry much about that, it's the way your PC recognises the device. you can rename the drive if you want in my computer
May 06, 2010 | Transcend (589307) Media
LaCie MosKeyto - USB Flash Drive - 16GB USB 2.0 Hard Drive Logo
266 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
