Question about Home
I do not have a 'drip' but a constant flow,volume
  • 2,100 Answers
I take it it is a shower only, no tub fill? Is it a single handle or two? Either way, shut off the water, pull off the handle(s), pull out the cartridge or valve, take it to the store and match it up, replace the faulty seals, springs, o-rings, you should be all set. Single handles are a bit more tricky. Hope this helps.
Posted on May 28, 2011
This unit flows continuously thru the drain line that returns to the waste drain is this normal
What's causing this refrigerator problem? [Archive] - Straight ...
boards.straightdope.com > ... > Main > General Questions
Mar 16, 2012 - 32 posts - ‎16 authors
The drain line should come out of the unit some where and empty into a .... water generally goes down the back wall of the fridge and through a ...
How To Repair A Freezer Dripping Water Into Refrigerator ...
removeandreplace.com/.../freezer-drain-frozen-water-dripping-into-refri...
May 27, 2015 - The freezer drain hole and drain line in the bottom of my freezer keeps icing up. ... is to simply run hot water through the drain line to allow water to flow. ..... Divert Water Dripping Outside From Air Conditioner Window Unit June 30, 2015 ..... How To Fix A Toilet That Is Constantly Running - DIY Toilet Repair ...
Refrigerator Troubleshooting & Repairs ' HomeTips
www.hometips.com/repair-fix/refrigerator.html
May 22, 2015 - Refrigerator Runs Too Much ... If your refrigerator runs without stopping, it may be too low on refrigerant to ... 4Make sure the drain line isn't plugged. ... Instead, the unit may have dirty condenser coils, a door that doesn't seal tightly .... on the tubing and, eventually, restricts airflow through the refrigerator.
Dec 29, 2015 | Refrigerators
Tip
Drip it don't drop it
The popularity of Drip Irrigation Systems has been rising in the past years. It is true that this method of irrigation is usually a bit more expensive than sprinklers and isn't as resistant on the long run, but on the other hand the water saving and the system's efficiency definitely make it worth it. So why not giving it a try?
First of all, this system waters plants and flowers more slowly and the water goes straight to the roots, so no water goes to waste.
Moreover, it requires to be activated with less frequency than sprinklers.
In most countries it's one day of irrigation every week during the winter, two days during spring and fall and three during the summer.
Did you get one yet?
If you did here are two basic suggestions to start and keep up a satisfying drip irrigation system.
1. In order to figure out how long to leave it running, you can measure how much water your emitter produces and according to that and your plant's needs, set the system's timer.
So take a spoon and measure how many seconds the system takes to fill it up.
14 seconds = 1 gph (gallon per hour)
7 seconds = 2 gph
4 seconds = 4 gph
If your system is of the first kind, producing 1gph, usually you should leave it running for about 90 minutes, if it's the second (2gph) for about 60 minutes and if the third (4gph) for about 30 minutes.
(If your plants require a higher-flow emitter you can get one that produces up to 20 gph and leave it for about 12 minutes each watering.)
2. In order to keep your drip irrigation system in good shape check its line periodically for breaks, or its emitters for clogs.
Make sure that each emitter releases the right amount of water.
Also you should flush the drip irrigation lines and filters about twice each year. You can do this by uncapping the end cap on the drip line and letting water flush through the line.
on Sep 10, 2013 | Garden
Mazda 3 won't idle.
code p0 refers to intake air temp sensor --circuit malfunstion causes are wiring open circuit(broken)wiring short to ground bad earth and ECM.
code po113 refers to mass air flow( MAF) sensor/ volume air flow (VAF) sensor --low input. Causes may bewiring short to ground MAF?VAF sensor faulty ECM
code po327 refers to Knock sensor (KS) bank 1--low input. Cause may be insecure (loose) KS poor connection- wiring ---short to ground incorrectkly tensioned KS and ECM
Mar 10, 2013 | Cars & Trucks
I have a problem with my Albion Direct Combination Water Heater Cylinder. it constantly overflows
Check the ball valve seating and check the valve in the ball valve is clear
Jan 11, 2018 | Water Heaters
ICE MAKER NOT WORKING
Good day!!!!
The water filter may be plugged with sediment, or you may have low water pressure. The water pressure for icemakers needs to be at least 40 psi, and up to about 120 psi for proper operation. Water filters need to be changed every six months. If you would like to test your water pressure, we have an Icemaker Water Flow Tester available from our website. This will help you to determine if the water pressure at the supply line is high enough for the icemaker to function properly. To determine if your filter is plugged, look for water both before and after the filter. It may be hard to determine if there is water flowing through the filter. Sometimes it is necessary to pull the filter out of the feed line to see if water is flowing from the exit of the filter into the refrigerator or freezer. You can do this over a bucket to catch any dripping water. Some models have a filter bypass plug to help determine if the filter is clogged. If so, you would remove the filter and replace it with the filter bypass plug. Now test your water flow.
If your refrigerator has a water dispenser, you can hold a large cup or glass under it for 20 seconds. You should have poured about 13-14 oz. of water in that 20 seconds. If the amount is less, try removing the filter and bypassing it. If you now get the 13-14 oz. of water, the filter was clogged and it's time to replace it. If not, you have low water pressure in the line, and your icemaker may not work properly.
On occasion, the water inlet tube will freeze where it enters the icemaker. This can happen because the water is dripping slowly, or the freezer is just set too cold. A hair blow dryer can be used to thaw this, but be careful around the plastic tubing. You don't want it to crack or deform. You may want to turn the thermostat up a little bit if this is a regular occurrence. If you have a constant, regular drip, you may want to invest in a new water fill valve.
Another reason that your icemaker may not be making ice is the bail arm along the side of the icemaker. This arm must be in the lowered position for the icemaker to operate. If the arm is stuck up, it has shut the unit off. This is a safety feature of the unit. Normally, if there's too much ice in the bin, the arm will get stuck in the raised position and keep any more water from entering the icemaker. You must lower the arm to begin making more ice.
I hope this solution will be helpful...
Thanks for using fixya and don't forget to rate and write a testimonial if it is work..
Aug 31, 2011 | Refrigerators
I have the 5200 btu air conditioner for my bed room and it started dripping constantly, it is coming between the seams in the front. Should we tilt the air condition on an angle so it can drip out, or do...
Yes, tilting it is required. 1/4" to 1/2' is the general rule of thumb. That way, the water will flow to the drain hole near the rear of the unit. It would be a good idea to check the drain hole under the drip pan, to make sure it's not clogged.
Hope this helps and thanks for choosing FixYa.
Aug 01, 2011 | Haier Mechanical Air Conditioner HWF05XC7
We have a 15 year old Rheem "SK 1261" which recently has developed a steady and constant hot water drip from the hot water over flow. Initially it was a slow and inconsisent drip but now it...
If you are paying for your water, I litre per hour is going to cost you. If the unit is 15 years old, I would seroiusly comsider replacing it buy, if it's just a bad valve, you could try to replace it. If it is cracked at the threads, it's time to replace it for sure.
Dave
Jun 24, 2011 | Rheem Water Heaters
Just replaced particulate, activated carbon and polishing filters. Turned water supply back on, made sure polishing filter in properly as to flow. Allowed about three hours to fill tank. When I turned...
Is this an RO system or just filtration? If so, does the membrane need replacing and/or is the GPD capacity on the membrane compatible with the system?
Another thing to look at...is your flow rate this low at a constant rate (perhaps taking 3 hours to accumulate 30 secs worth of water)? What are the micron ratings of the filters you are using? If they are too low or at the submicron level, this could massively reduce flow.
One more thing...you're only using one tank right? Because throwing a couple inline with each other with different pressures and capacities will also do this...
Aug 25, 2010 | Culligan Under Sink Water Filter
Seems it doesnt come on unless i turn on two
This is a common problem. They are desighned to come on when a certain volume of water goes through it and with todays low flow water conserving devises they don't always come on with one faucette.
You can have a loop installed that allows a higher volume of water to flow when a valve is turned on. It simply flows back into the supply side of the unit.
Aug 24, 2009 | Bosch AE125 PowerStar 4 GPM Indoor...
Home Logo
67 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
