Question about HP PSC 1215 All-In-One InkJet Printer
1 WHEN LOADING SOFTWARE FOR MY HP PSC 1215 PRINTER THE ERROR MESSAGE 1327 INVALID DRIVE E:\ COMES UP. THE OPERATION IS ABORTED AT 54% 2 ALSO, WHEN I TRY TO DOWN LOAD AN ADOBE ON LINE UPDATE THE SAME MESSAGE COMES UP IE ERROR 1327 INVALID DRIVE E:\ I HAVE WINDOWS XP
  • pajgr1954 Jun 06, 2011
    I DID NOT HAVE TO USE THIS SOLUTION. A PREVIOUS SOLUTION PAVED THE WAY ie [[[SYNTAX: SUBST
    ( INVALID DRIVE LETTER):\
    (EX ISTING DRIVE LETTER):\ ]]] I WAS PREVENTED FROM DOING THIS SOLUTION BY THE ADMINISTRATOR!! AND IT LED ME TO THE SOLUTION. 1 PUT A PASSWORD FOR THE ADMINISTRATOR AND I THINK THAT XP REINSTALLED ITSELF. I LOST ALL MY DATA AND BOOKMARKS (NOT A PROBLEM) WHEN I USED THE COMPUTER AGAIN THE PROBLEMS HAD ALL
    VANISHED!!!! HOWEVER, IT WAS YOUR HELP THAT
    WAS THE CATALYST. THANK YOU. I HAVE NO DOUBT THAT YOU HAVE MET THIS ONE BEFORE?
    REGARDS P.ROGERS
    ps VERY PLEASED.
    Guru:
  • 610 Answers
Don't worry, this is not a serious problem and it can be solved by editing a few entries in the registry. Let me just remind you though, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it so you can restore the registry if a problem occurs.
Click Start, and then click Run. In the Open box, type regedit, and then click OK. In Registry Editor, locate the following registry key:
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
In the right pane, note the values in the Data field of each entry. If any value contains a drive that is not correct for your computer, (most probably letter E:\) right-click the entry and change it to C:\ (e.g. c:\my documents) in the Value data box and then click on OK.
Repeat these steps to each entry whose Data value contains an incorrect drive on these lcoations:
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
Close Registry Editor and reboot the computer. Please be careful using the Registry Editor and remember to back it up before changing it!
Hope this helps.
Posted on Jun 05, 2011
  • 4,281 Answers
Make sure your dvd rom is working fine. Anyway you can download driver for your printer from below link then you can install it from that download so no need of cd/dvd disk. Click here Click on above link select your os and download driver and install. For cd/dvd rom problem make sure rom lense is fine reconnection ide cable connection to cd rom inside the cpu cabinet. then check. Let me know if you need further assistance. Thanks for using FixYa.
Posted on May 28, 2011
HP 4350 ERROR MESSAGE: 49.2F90
"the printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
If the above action does not solve the issue, contact HP or authorized service provider."
Mar 15, 2008 | Office Equipment & Supplies
I need down load software hp psc 1215 all-in-one free down load
hi,
Visit to the given link and select your OS for software at free of cost...
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=&cc=us&product=412187&
... hope this has helped you. Please rate the answer... Thanks...
Jul 03, 2010 | HP PSC 1215 All-In-One InkJet Printer
Loading drivers and software for ic455c web cam. when drivers are loading error message comes up error 1327 invalid drive:F\ my computer does not have a F drive
Teh cd that is supplied tries to load to the F drive. My computer and most do not hav a F drive. I hd to hook up an externial drive that is logged in as f to get the drivers to down load. Once I did that it worked fine.
Jan 05, 2009 | Micro Innovations IC445C Webcam
Hp 6110 all in one
I'm glad you posted enough of the specific error message to enable me to search for it on HP.com. I found a web page that may have the answer to your problem:
Error 1327 Message Solution
Try the troubleshooting suggestions listed on that web page and post back your results here. Good luck.
Oct 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Installing new software for the camera
Please check ur computer drives , any drive named (E:) and tell me
i give solution
Jul 05, 2008 | Logitech Webcam
Action :
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Mar 15, 2008 | HP LaserJet 4350 Printer
Can not load software for Pentax DSmobile scanner
This solution has helped a lot of people. The cause of the problem has
been known already and is explained clearly how to fix the issue on the
site link below.
'Invalid Drive during installation
Fixing Invalid Drive Error 1327
Sep 22, 2007 | Pentax DSmobile Path-Through Scanner
HP PSC 1215 All-In-One InkJet Printer Logo
89 people viewed this question
Seeker5211
Seeker5211
