I have trouble setting up my TEAC set top box HD8848
SOURCE: set top box - service list changed
yo, try this, i just bought the same STB and had the same problem. So far this has fixed it (fingers crossed).
http://www.teac.com.au/pages/hdb842softwareupgradever161008
cheers
Chris
Posted on Dec 23, 2008
SOURCE: teac digital set top box prompt every five seconds
I had the same problem - pretty easy fix. You'll need a usb flash drive with all other files removed. Go to following link:
Print out the instructions and make sure you have winzip installed on your computer. Instructions were pretty easy to follow and seemed to fix the problem. I haven't watched the TV for a long period of time, but it seemed to sort out the problem you described and system seemed to run better than previously eg. didn't hang - receception better.
Good luck
Posted on Jan 02, 2009
SOURCE: teac hdb820
I just did a factory reset this morning and I had the same problem until I realised that you have to use the "Output" button to get the Video Outputs to DVI Digital (see page 17 of the manual), if that's what your connection is, then I could select "menu" and do a channel search. Hope this helps.
Posted on May 30, 2009
SOURCE: Remote control for teac set top box HDB842 will not work .
I had the same problem and tried new batteries with no success until I had a close look at the terminals. One of the +ve terminals was rusted (Ithink a drink spill, hastilly wiped off). After restoring this terminal everything is now OK. Hope this helps.
Posted on Jun 01, 2009
SOURCE: idigital RM-810 universal remote code to suit Teac SDB440
http://www.chunghop.com/en/products_view.asp?id=302 contact the manufacter
Posted on Aug 24, 2009
What is the code for a teac set top box model hdb850
Codes are in the remote. If you are using a TEAC remote with a TEAC STB, you may be able to find something that will work.
Jul 16, 2016 | Teac Televison & Video
I am unable to find the owners manual for the Teac MC-DV100 SuybWoofer
For almost any set-top box, there isn't a sub-woofer output. Without that output (it would be labeled on the STB), you can't hook up a subwoofer directly to it.
HOWEVER, the model number you give isn't just a subwoofer: it's a whole sound system with a subwoofer attached to it. If you have the whole sound system, you just hook the STB's audio output to the amplifier's "Aux Input" (it might also be called "line input").
If your model doesn't have that (can't tell from the web), you'd have to buy an "AV Receiver" that has at least a 5.1 set of outputs. These start at maybe $150 new, $50 on eBay. MAKE SURE YOU BUY A RECEIVER WITH A "powered" SUBWOOFER OUTPUT!! You connect the receiver to the STB, and the subwoofer to the receiver.
Jul 15, 2015 | Teac Audio Players & Recorders
Need code for teac HDB840 set top box tried 2130 didn't work
2819,2883. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 03, 2015 | Teac Televison & Video
I set up teac HDB840 to tv- via coxial cable from wall to set top box, then rca cables output of set top box , then to input to tv.-tried av button on tv showing av1 av2 and av3 but still no picture only...
Hi, Your set top box (PVR) is running on channel 3 or 4. Go to menu and sellect a source TV, DVD
Note: Do not connect more than 1 set of cables to tv or you may damage something.
TV > box connect RCA cable or HDMI not both.
Set top box > connect RCA or HDMI Not both.
audio devices > TV connect RCA or HDMI not both.
Good luck.
Jun 18, 2011 | Televison & Video
I have a digital set top box model teac dv-b800.this unit now has a flashing c-100 code has soon has you power same up and nothing else.Can you tell me the problem.
appears to be a known issue with your model of set top box and teac is aware of the issue, but will only repair for free if you are within your 12 month warranty period, if you are outside warranty, consider repairs as they are approx 60.00 and the fix appears to resolve the issue.
Cheers!
Feb 14, 2010 | Audio Players & Recorders
Failed tv reception after about an hour????
Witout knowing your set up I can only guess at the set top box getting hot and failing.
Is the Teac box well ventillated? If not, put it somewhere where it can get cool air (ie not enclosed in a TV cabinet for instance).
I doubt it's your antenna if it works for a while, but you maty want to have your coax connection checked out. If you use a booster, that may be failing.
Sorry I can't be of any further use.
Jan 13, 2010 | Televison & Video
Connet Hd set top box
May 31, 2009
Born to Race,
I have just bought a TEAC HBD841 which was on discounted sale at a local Electrical Store
Besides not being able to figure out how to connect the device to my elderly TV because the inadequate instruction booklet that is written in a language an Electrical Engineer would have difficulty understanding - does not explain which plugs go where, (try plugging a three plug lead into a 2 plug TV) but since then I have found out that the HDB841 has been withdrawn from sale and is no longer available.
No wonder it was cheap!
I suggest you get rid of it - quick
GB
Apr 20, 2009 | Televison & Video
Set top box - service list changed
cheers
Chris
Dec 17, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
