Question about Refrigerators
Lbc22518ww problems. Refrigerator digits are not lit. Freezer digits have 6,7 and 8 lit. Unplugged unit for several hours and both refrigerator and freezer have number 4 lit. Then shortly after if defaults back to the above pattern. Compressor ho to touch. Coil is clean.
  • Rick Hayes May 28, 2011
    Is this a common problem?
    Do you know the part number?
    What exactly is the part called so that I can order it?( "main control board" or "control assembly"....)
    If I am to have a repairman arrive, it would probably make sense that i have the part in hand before he arrives.
    I am a contractor by trade. Is this part something I can install myself?
    Thank you
    Rick
    Failure of the control board, the compressor is kept constantly operational.
    The control board will have to be replaced, a job for a person who has done something like that before. You will have to call a repairman.
    Which board is being referenced here? I would like to order it and have it here for the repairman.
    where is the best place I can get it?
    I am a contractor. Is this something I can install?
  • Refrigerators Master
  • 2,605 Answers
Hello, welcome to FixYa.
With the info you posted, that error is explained by LG as follows...
Defrost malfunction - 2 hours after defrost starts temp sensor is not above 50F - Temp. fuse cut-off, Relay malfunctions.
You can open the freezer panel and ohm out the heater, fuse etc if you're able. To get to the bottom of this I'd suggest running a test program. To do so...
The test button is on the main PCB of the refrigerator (Test S/W at the back). The test mode will be cleared in 2 hours regardless of the type of test mode.
Let me know what you find and we'll go from there. I can send you a LG error code/service "pdf" if you want to provide an email address as well if you think that may serve you well.
Thanks for visiting "FixYa" for assistance today
Regards,
Macmarkus :)
Posted on May 28, 2011
  • 11,800 Answers
  • Azrael SRL May 28, 2011
    This is the exploded diagram
    http://www.appliancefactoryparts.com/ima...
    And this is the board
    http://www.searspartsdirect.com/partsdir...
    Yes, with a bit of care you can do the testing and replacement yourself.
Refrigerator and freezer not working
What is the model number for you fridge?
Mar 12, 2013 | Refrigerators
Tip
Tips of Repairing your Refrigerator
For prevent highrepair bill and the expense of replacing all your lost food. This article willprovide some useful tips that how to manually repair your refrigerator andfreezer yourself. Let's star with some basic information.
What you have to Do-
- Always maintain temperature range between 36 degrees Fahrenheit for the fridge, and between 0 to 5 degrees for the freezer.
- Keep clear and clean the coils with a vacuum or duster every 6 months to maintain efficiency and for reduce operating cost.
- During a power outage fridge will stay cold for about 7 to 8 hour and freezer can stay cold about 50 hour. Do not open door unnecessary.
- Daily defrost your manual defrost freezer and do not chip away the frost.
- Full filled fridge is more efficient than a half empty, but do not overfill.
- While moving and storage keep your refrigerator upright.
- After moving the refrigerator wait 24 hours before plugging it in.
- Keep at least 2 inches or air space behind your refrigerator and 6 inches above it.
What you have not to Do-
  • Overfill would not cool as well, so don't overfill your refrigerator.
  • Do not chip away the frost in manual defrost freezer.
  • Do not store your refrigerator unplugged for extended time. Some units or refrigerator require continuous use to ensure proper lubrication of compressor. If possible, plug in it once in a month and keep it run for a couple hours.
By using these tips you willkeep your refrigerator well.
on Dec 24, 2010 | Refrigerators
I have a GE side by side Refrigerator Freezer in my garage and this morning I opened up the refrigerator side and it was very hot inside. The Freezer side was fine. What is the problem?
make sure both fans on unit condensor and evaporator are operating,if so then check and make sure compressor is operating,if not it could be the ptc overload relay on the compressor or possibly the main board located behind a silver panel in the rear of the unit
May 05, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PTS22LCR (top freezer) will periodically stop cooling almost entirely. Leaving it unplugged several hours then plugging back in seems to fix the problem, at least for several weeks to a few months....
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 26, 2010 | GE PTS22LCR Top Freezer Refrigerator
Freezer defrosts.When unplugged and emptied for several hours and then plugged in freezer cools to 10 degree range for approximately 24 hours and then defrosts again
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 28, 2010 | Kitchen Ranges
ICE MAKER NOT WORKING LBC22518WW (LG REFRIGERATION)
Hello, just like your problem, our ice maker just stopped making ice. We solved the problem by unplugging the refrigerator for about 2 hours leaving the freezer door open.
It started making ice a few minutes after plugging it back in. Obviously the line that supplies the water had frozen and this allowed it to un-freeze.
We didn't remove any of the frozen items in the freezer, at the two hour mark, everything in the freezer was still mostly frozen.
Thanks
Jul 13, 2010 | LG LBC22518 Bottom Freezer Refrigerator
Refrigerator section not cooling
heatman101
Jun 20, 2010 | LG LFC22740 Bottom Freezer French Door...
Kenmore 71182100 refrigerator will not cool after clearing drain
Hey Donna! It normally takes 24 hours for your system to go back into it's "normal" mode after it's been off. I would wait until tomorrow and see if it's cooling down properly before you worry. You may call me if you like after you wait the 24 hour period. Hope this helps you! Ella
Aug 17, 2009 | Refrigerators
Warm on inside edges of front refrigerator doors, not very cold inside....and freezer is hard as rock. Setting on freezer is 3 and refrigerator was 3, but now we've turned up to 6. Definitely not normal....
The fridge gets its cold air from the freezer--it could be that there is ice build-up restricting air flow from the freezer. See if you can see any ice there...Is it possible to defrost the whole unit for several hours (even over night)?
Mar 16, 2009 | Jenn-Air JFC2087HRP Side by Side...
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
