Question about Dryers
How do i change the element in a t522vw creda dryer
    President:
  • 3,074 Answers
Http://www.ehow.com/how_2087872_replace-belt-creda-tumble-dryer.html
Posted on May 28, 2011
Hi my creda t522vw dryer door won't close
This has happened on some of the front load commercial dryers in one of my building. The door alignment pin that mates with the latch was not meeting in the center of the latch. On one of the dryers the latch pin broke, I replaced the pin and thought I had fixed the problem. After a second parts search and realizing how much work it would be to open the front of the dryer to replace the hinge, I opened the door just enough to clear the housing and lifted up on the latch end of the door to try to bend the hinges back up. I had to pull up with more force than expected, but the door alignment was better and the latch mated properly. I then got out my RED Sharpie and wrote on the top of the, "PLEASE DON'T LEAN ON THE DOOR" The problem has not returned.
I hope this was helpful.
Jun 02, 2014 | Dryers
Creda tumble dryer not heating up, drum is rotating with no probs, filter is clear, any ideas please?
either heating element is faulty or the stats are faulty...............
easy fix.........
Jan 16, 2011 | Creda W120VW Front Load Washer
Hi the door catch for my Creda T522VA Simplicity dryer has broken - where can I get a replacement?
http://www.espares.co.uk/parts/tumble-dryers/doors/creda/t522vw/p/1580/720/0/423760
hope it helps
Jul 05, 2010 | Dryers
The motor appears to be running but the drum isnt turning but will turn manually when you try to move it by hand creda t522vw .
The belt is either really worn or broken or has fell off..You may need to replace it/fix it
Feb 21, 2010 | Dryers
Creda t522vw has topped spinning but still
Could be the belt has failed, you need to remove tho top cover, and check to see if the drive belt is intact, grasp the belt and see if it is o/k.
Another way to check is turn the drum from inside and it should go round., if not, then it is probably the belt.
Hope this helps.
Dec 06, 2009 | Dryers
Creda tumble dryer T632CW is not heating up. Any
SOUNDS LIKE YOU NEED NEW HEATING ELEMENTS.
Oct 18, 2009 | Dryers
No heat from dryer
there are ways to the element disconnect the power, then get to the element from the back of the dryer. disconnect the 2 wires on the element and use a muti meter. find the ohm section on the meter(it will beep when you connect the test leads) . connect the test leads to the element, if the meter does not do anything the element is bad.
Apr 14, 2009 | Dryers
Fluff escaping from my Creda Simplicity Dryer T522VW
You don't say how much fluff is escaping, but some things to check are -
1) That the lint screen is fully seated into the top of the dryer vent
2) All the way to where it discharges the house, is clean and free of restriction
3) Check that the dryer door gasket and lint screen cover gasket's are in good condition and do not allow air leakage.
Make certain the flex duct leading from the back of the dryer is connected tightly to the dryer and the vent duct, and make sure the flex duct is not split or broken.
Jan 22, 2009 | Dryers
No heat to tumble dryer
Check the thermal disc with an OHM meter. One will be next to the heat element (high limit) and another on the air exhaust area which is the low limit.
Dec 16, 2008 | Dryers
CREDA TCR2 TUMBLE DRYER
put it in the bin
Sep 12, 2008 | Dryers
Dryers Logo
217 people viewed this question
Top Dryers Experts
