Question about Samsung Washing Machines
Hi , i have a samsung washing machine, actually it was working normally, but suddenly , the electric current starts to break out when the washer is connected to power. i think there is a power mass , but i dont know what to do ? please help in case you can. regards.
    Brigadier General:
  • 6,277 Answers
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 28, 2011
How to calibrate samsung top load washing machine
there should be another 7 letters/numbers after wa14 maybe the full model number is on the back or in a manual
Sep 19, 2015 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Karcher pressure washer doesn't work
it;s normally a switch interrupter must replace with actual with for motor protection.
Aug 14, 2014 | Karcher Garden
In IFB front washingmechain AC h1 error is coming what to do
AC h1 is actually AC hi error which means input voltage is too high. Wait for sometime for voltage to stabilize Washing machine will automatically start. If not call electrician to check electrical fault for high voltage
Jul 03, 2014 | Kenmore Elite 45986 Front Load Washer
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer will occasionally be filling with water and pumping water out, problem will last until i turn timer knob to next action, after turning timer to "sweet spot" washing machine will...
These timers are normally sealed units (crimped and pressed sheet metal) and replaced as a unit.
If you could open one up, you'd find
that the contacts causing the intermittent problem are burnt from arcing. All washing machine timers
will eventually get this problem with enough use. As an electrician, you'll recognize that all switches
(washing machine timers are a series of switches oriented around a slow (timer) motor) are rated
for a given number of make/break cycles. Washing machine timer contacts are no different.
If you could actually "shine up" the offending pair of burnt contacts, another pair would soon
show the same symptoms, since all the contacts in your timer have endured the same number of
make/break cycles.
Feb 21, 2011 | Washing Machines
My lg washer was working and suddenly a burning smell came out of it and we dont know how to make it work again
Try a small amount of soda crystals put it in the soap draw about half the amount you would normally use of regular soap powder and put it on the hottest wash it will break down any gunk or loose limescale which could be causing the smell.
Thank you
Jun 07, 2010 | LG WM1814CW Front Load Washer
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
Machine stops during the wash cycle.
Hi this is abhishek,welcome to fixya
over weight normally doesnt cause machine to stop during the wash cycle,,iit is actually tub gettiing stuck or a timer problem...
thank uy........
May 03, 2009 | Bosch Logixx WFR 2867 Front Load Washer
Stopped Dead
these machines only have 2 problems
dive coupling no wash or spin
or lid switch machine totallaly dead normally caueded by droping heavily & breaking the housing of the lid switch
Oct 30, 2008 | Washing Machines
Washer tripping the electric
fault probably with heater short to earth posswibly as a result of washing coins etc. take offr back panel and disconnect heater and tape up wires. start machine and see if trip still goes
Apr 19, 2007 | Tricity Bendix AW1000W Front Load Washer
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
