Question about Acer Aspire One PC Notebook
A rectangle with a star has appeared saying i need to configure some thing
  • 3,267 Answers
Its hard to tell because each version of Linux has its on special files that it can download. Look in all of your applications and see if you find a program called Synaptic Package. All you have to do is click on it and it goes to the repository and will update all of the packages and its dependent packages automatically. Not all versions have Synaptic, some just say Software manager, but its the same thing. So if you loaded Skype off of the Internet then you probably don't have all the files as Linux does not work like Windows. You can look for the Terminal window to open and type sudo apt-get install Skype see if that works, but again, if the program did not come from the specific repository then it may not update. If you want to remove it then you can either find it in your file manager program (again in applications) and delete it. Or you can try sudo apt-get remove Skype. Third option is to right-click on it and see what options you get if one says cut or delete then you know what to do. The sudo options will ask you for a password which you should have, its the root password. Last solution is to reload and start over, I've done that more than once :).
Posted on May 28, 2011
Where is the oil pressure sender on a 4.6l north star engine?
Vary rear left side almost touching fire wall .You will need a special tool to remove and install it .Its a large socket costs 20.00 or so depending ware you buy it .
Sep 18, 2016 | 1997 Cadillac DeVille
How do you increase voice volume
At the bottom of the screen )in the default configuration) there are two rectangles. Tap the screen near the vertical line that separates the two rectangles. A Volume slider will appear. Use your finger to move the bead (button) to the right to iincrease volume.
Aug 25, 2011 | Tomtom ONE GPS Receiver
My samsung star cannot connect to a wifi network...it says dns failed...helpppp..
u need to configure dns settings manually from the wlan or connectivity option.so call the customer care know your dns no.i prefer www.whatismyip.com
Sep 28, 2010 | Samsung Star GT-S5233 Cell Phone
I have a TSP700 parallel port label printer and now have a new computer with no parallel port, so I purchased an adapter;- parallel to USB, but having tried every thing, I am running, windows XP pro, I...
you might need to fiddle around with the usb virtual printer port configuration , when you add printer. when adding a printer, uncheck the install automatically tick box, then on the NEXT page click on the drop down list of "use the following port" and try virtual port. it might work.
Mar 21, 2010 | Star Manufacturing Star TSP700 Receipt...
Black Rectangle appears on screen for no reason
Just use your remote or the tv menu to turn off closed captioning.
Jun 03, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Acer one notebook not connecting to internet
Hi Kat,
Ok, firstly i would recommend restoring all back to factory settings as it would appear that this a a configuration problem and that should fix it as i believe there is no personal or data to be backed up as yet.IF there is, simply back it up to a thumb drive.
To restore to factory settings(Like it has just come out of the box basicly) When the laptop starts up hold down ALT and keep pressing F10.
A screen should appear with configuration settings and an option to system restore.
Select system restore and it should have prompts from there.
May 19, 2009 | Acer Aspire One Netbook 8.9" Notebook
A black rectangle is displayed on the screen
the black rectangle appears as soon as the channel indicator goes off. someone has turned on the closed captioning in the menu of the set. it is in the "text" mode. go into the menu and turn off the closed caption feature.
Mar 20, 2009 | JVC AV-32320 32" TV
Bad reception on my blackberry pearl.
that triangle means you have activated your roaming feature on your phone......so you should contact or visit your carrier and have them deactivate it for you.
Feb 27, 2009 | AT&T Blackberry Curve 8300 Smartphone
Dark Translucent Rectangle appears in front of picture
Go into the customer menu and find the "closed captions" heading. Within the closed caption you will find "TEXT". If you turn off closed captions or the text, whichever you menu lets you do, your rectangle will go away. Hope this helps
Dec 21, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Acer Aspire One  PC Notebook Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
