Question about GE Zoneline AZ55H15D Air Conditioner
I have panasonic 1.5 window AC model no. CW-XC-184BY. When the problem started, the cooling started only after about 20 minutes delay and cooling was good. Now the cooling starts and stops within 1 or 2 minutes. The remote is working. What is the solution
  • 3,267 Answers
Check the coolant. It must be depleted. Requires a refill.
Posted on May 28, 2011
My AC unit leaks water inside
Isidro, If it's a window unit you will need to tilt it up from the inside. Thank you and please leave me feedback. Clean around the bottom of any debris so it can drain on the outside.
Jul 12, 2016 | Panasonic Heating & Cooling
Hi, do you know where I can get the specs of the Panasonic cw-1206fu? Thanks
11,500 Btu/h (at 115V)
10.0 energy efficiency ratio
IC thermostat control allows for precise, sensitive temperature control
12-hour delay START/STOP timer lets you select start or stop time up to 12 hours in advance
Aug 12, 2011 | Panasonic CW-1206FU Air Conditioner
Is it worth investing on Panasonic cube AC now? OR should I wait till performance feedbacks are available?
Dear All, After looking at the ads and influenced by the Reliance Digital Marketing Team unfortunately I bought 1.25 Ton Pansonic Cube AC for my House. The Model is disastrous and I am not even getting minimum cooling even though they promised that it will give 1.5 times more cooling than traditional ACs. The Air circulation is also not there even if we sit in front of the AC. When I contacted the service people from Reliance Resq and Panasonic..they are simply saying that the Air will flow straight only..in that case they asked me to fit the AC at 1 Ft height from Floor i.e parallel to my Bed. Which looks much more awkward in the Bed Room. It is better to go for Window AC than fitting this AC at 1 ft height.Air coolers available in the bazaar are better than this product. I feel that I have wasted Rs. 17000/- by investing in it. My suggestion to all of u is Better to buy a USHA Ceiling fan than buying a CUBE model Shashidhar
Feb 01, 2011 | Panasonic Heating & Cooling
Does the exhaunst fan turn on automatically when we cook or warm food items in our Samsung Microwave -- SMH 9187W?
Some interesting reading on page 8 of the owner's manual:
"Boilovers cause smoking and greasy spillovers that may ignite and spread if the vent fan is operating.To minimize automatic fan operation, use adequate sized cookware and use high heat on surface units only when necessary."
And on page 20:
"If the temperature becomes too hot around the microwave oven, the fan in the vent hood will automatically turn on at the LEVEL 2 setting to cool the oven. The fan will automatically turn off when the oven has cooled down sufficiently. This is an automated process and cannot be turned off. The fan may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. The Vent Fan will only operate in 1~4 levels modes while the microwave is working."
"Using the Vent delay off button
1. Press the Delay Off button once to turn the fan off after 1 minute.
2. Press the Delay Off button twice to turn the fan off after 3 minutes.
3. Press the Delay Off button three times to turn the fan off after 5 minutes.
4. Press the Delay Off button fiour times to turn the fan off after 10 minutes.
5. Press the Delay Off button five times to turn the fan off after 30 minutes."
If for some reason you don't have your owner's manual, you can still download it free here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Jan 01, 2011 | Samsung Microwave Ovens
2hp units are not cooling what do i do about them
Keep thermostat lower degree say 20 and also mode should be " Cool". Wait for 3 minutes, as normally compressor starts with 3 minutes after only.
Dec 08, 2010 | Panasonic CW-1006FU Air Conditioner
How to determine horse power of air conditioner
air conditioning units are measured in btu's stands for
(British thermal units)
6,000 BTUh to 10,000 BTUh will cool 400 sq.ft approximately
10,000 BTUh to 16,000 BTUh. will cool about 800 sq.ft approximately
16,000 to 28,000 BTUh will cool 2,000 sq.ft approximately
the idea is more but's the more cooling power it will have.
Aug 20, 2009 | Panasonic CW-XC203EU Air Conditioner
I turned on my AC. The compressor sounded like it was straining and the fan wouldn't go on, then compressor went off. But the green powwer light was still on on the plug. I turned it off, unplugged it....
I am guessing it is a window or wall unit right? not central AC? If thats the case, how old is it? New? can u return it? if not, if its older than 4 or 5 years, trash it and get a new one! If the fan isnt working after a few seconds or minutes the compressor will over heat and shut off, its not worth repairing
Aug 06, 2009 | Panasonic CW-XC125HU Air Conditioner
Can coolant be added to Panasonic AC CW-C101MU? Instruction plz.
this can be done if your a good hand at soldering. You need to put a inlet valve in the unit so you can put freon in this is kind of a tricky job most of the time it's easier to take it to the repair shop and let them put the valve on then after that you can recharge the freon on your own..........I hope this was helpful...... : )
May 09, 2009 | Panasonic CW-C101MU Air Conditioner
I makes a very loud noise
Had same problem with Ge AC. Unplug take out of window and remove all cover screws. Pull up on cover and pull cover off ac, Remove front cover as well there are a couple screws in the front. When looking at front of ac, hit the Styrofoam housing towards your left (towards control panel). Spin fan blade to make sure that it is clear. Plug in to double check. I put a couple quarters between the styrofoam and the metal housing, so it would not slide back. Also tape the styrofoam between the seams this helps with better cooling. Use some good tape nothing cheap. I used black duck tape. It took about 20 mins. The hardest part is re installing the AC.
Jun 02, 2008 | Heating & Cooling
GE Zoneline AZ55H15D Air Conditioner Logo
109 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
