Question about ASUS (90N804SH021) Hard Drive
Computer has stopped working and it says on the screen hardrive problem how do i fix this it is also not regonising any other hard drives i put in?.
  • 89 Answers
Hi is this IDE or SATA Drive? check first your IDE cable that connects to hardisk to mother board same as SATA cable. or reformat your pc so that you can determined if is the hardrive is the problem. thanks
Posted on May 28, 2011
Computer won't recognize external usb hard drive
try it on another computer if that dosent work you should
reformat your computer but first backup all your data by putting your another internal hardrive on your computer and move all your files you need to the empty hardrive and after that take the hardrive with all your stuff in it off the computer and then reformat the hardrive which the external hardrive does not work on and install a new operating system then put the other hardrive with all your stuff back on your computer and transfer your stuff into the hardrive with a operating system then try the external hardrive
OR
you can burn all your stuff into a CD or a DVD
OR
you can put all your stuff into FlashDrives and then after you reformat the hardrive with an operating system put your stuff back into the computer and after that the external hardrive should work
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
Regonises the USB attatched to the hard drive but not the hard drive itself?
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Mar 06, 2012 | Hitachi 1TB LifeStudio 35 Desk Plus...
Hi , i have a 500gb hardrive i bought a few months ago, full of family memorys and although it powers up the computer has stopped or failed to regonise the hard drive , pleaser can you help .im desperate
Replace the cable you are currently using with your printer cable and see if it is the cable if that is not the case I would open the case, and check your connections on the hard drive, there is a chance it might have come loose.
Jun 23, 2011 | Genica 2.5 USB 2.0/eSATA Aluminum External...
No system disk has been found, insert CD and press any key to continue. There is a black screen on my PC, no matter what CD I put in, or pressing any key, the message above just appear again on the...
this problem come from your har drive
your hard drive not recognized by motherboard
to solve, open your computer, disconnect hard drive cable then connect again
then turn on your computer
this problem usually found on computer with sata hard drive
Mar 31, 2011 | Computers & Internet
My passport 500gb external just stopped working. It froze up so I removed it and plugged it back in. When I plugged it back into my computer it starts spinning but then makes a click sound and stops.
The clicking sound is caused by the spindle inside the hardrive, because it was not removed properly. Just connect you external hardrive to your computer, if it makes the clicking sound again dont remove it yet, just restart your computer properly. In that way all the devices connected to the computer will be refreshed and properly shut down. If it is not detected still, unplug the haardrive then try another USB port. Recommended ports are at the back of the CPU if your using a desktop. These USB ports have higher voltage output that can power up all external hardrives properly.
Jan 13, 2011 | Western Digital My Passport Essential...
My maxtor hardrive makes anoise wen it is pluged in by way of usb
put in a new hard drive & yours old hard drive in your computer and make the old hard drive as yours slave.
Jun 30, 2010 | Maxtor Hard Drive
Freeze
I THINK YOUR HARDRIVE IS GOING OUT IS THE HARDDRIVE MAKING CLICKING NOISES When trying to Load.
Replace hardrive and this should fix your problem
Jan 13, 2008 | Toshiba Satellite M45-S169 Notebook
Computers & Internet Logo
53 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
