MY ALL IN ONE PRINTER WONT PRINT IT SAYS ITS CONNECTED TO MY pc BUT SAYS A FIRE WALL IS BLOCKING DISABLE FIREWALL STILL ZILCH ANY IDEAS
  • 68 Answers
How is it connected? Via a cable (usb) or wirelessly, etc. If it thinks there is a firewall in place, it must assume the printer is on a different network then the PC and it has to be routed. Normally the printer will set itself up using DHCP from your router, if you have DHCP turned of you may have to turn it back on or manually set an IP for the printer in the IP. Refer to the Owners Manual.
Posted on May 28, 2011
I cannot print from laptop to wireless hp j4680 printer
Hi
one possible cause for this could be your connection setup. Make sure your antivirus is not blocking incoming connections from other wireless devices. You must disable your firewall for your wireless connection to be accessible to other wireless devices. If you're using norton then your firewall is managed by norton, so you should disable the firewall from the norton interface. Hope this works.
Oct 09, 2011 | HP J4680 Office Jet All-In-One Printer
Tip
How to disable Firewall In windows 7..?
The compleate method is given below.....!
1.Control Panel
2.System & Security
3.Windows Firewall
4.Turn Fire Wall On or Off(leftside)
5.check (Turn Off Windows Fire Wall.)
that is it..............!
on Mar 16, 2010 | Computers & Internet
Printing preferences cannot be displayed. The print spooler service is not running. (What does that mean? I cannot print anything from all 3 of my computers at work can you please HELP ME! )
If you are getting this problem to a Network Printer then you should check the Firewall of Server PC or The PC to which Printer is Directly Conncted, Disable Firewall of that system and check the Properties again on remote pc on which you are getting this message, in miy case norton internet security was blocking printer to all my network pc and i was getting same error. but when i set the firewall to shared mode (its only in NIS) all pc started to print normally.... :)
Jun 22, 2011 | Samsung ML-2510 Laser Printer
Printer will not print shows ready and when asked to print goes offline and doesn't print. Tested cable - ok (scanner works ok) tried with two other machines (PC &Mac) and different cable same result. ...
make sure your fire wall is not blocking. you can also go to device printers and you should see your printer at bottom screen with yellow mark on it right click it then trouble shoot then fix.
Feb 06, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
My dell v305 printer wont scan anything
The problem could be because of ONE out of FIVE problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Jan 27, 2010 | Dell V305w All-In-One R840635AU InkJet...
Just switched to FIOS and had no problem but all of a sudden my Dell Printer will not communicate with PC(64 bit)..??
Thanks,
Abhishek
Dec 15, 2009 | Dell 924 All-in-One InkJet Printer
Desktop won't connect with printer connected to laptop
Make sure both computers can share files and can ping each other, if not, it's just a firewall issue. Try to disable your firewall first.
Oct 23, 2008 | Linksys Wireless-G WRT54G Router
Firewall blocking runescape
Disable all firewalls, as Norton, Zone alarm etc.
Also disable windows firewall from control panel.
If it still does not work check the router settings. Routers have internal firewall, you may need to add your laptop's ip or mac address to the firewall as trusted one.
An alternative is connecting laptop by wires to the router, probably the router firewall will let it go , as wired connections are set to less resticted security.
Sep 17, 2008 | Video Game Consoles & Games
NComputing L230 won't connect to host
First Please check your Lan IP Address for host pc.
change IP address and subnet mask on L230
disable firewall or any antivirus that is blocking ports.
Then you will get connected.
Aug 13, 2008 | NComputing L230 Network Terminal
Hai
Port forwarding only applies when you have a router.
You're on a PC with a direct link to internet.
So... there must be a software firewall, like the one in windows? disable it.
Try again...
I'm not familiar with nokia 5310... does it create a lan connection? or is just like some other regular modem?!
maybe your operator is blocking that kind of traffic.
Jul 15, 2008 | Computers & Internet
21 people viewed this question
jasbo
jasbo
