Question about Ricoh Aficio 1035 Copier
I have nashuatec1805aficio, it have sc541 error display on the screen.I have tried clear by using yellow key then 107 then red key hold down for 3sec.after that i press 1 on SPmode display then it display 1.feed. then i failed to continue after. so where should i do after that .....
  • 155 Answers
Sc541/541 is a fixing problem, check if your thermistor or thermal fuse are defective, if yes replace them or clean the thermostat/thermistor. then reset it by pressing the yellow key then 107 then red key hold down for 3sec.after that press copy sp then exit turn off machine after 10 sec on. hope this helps
Posted on May 30, 2011
  • Joel Baleta
    Joel Baleta May 30, 2011
    sc541/542
  • Burretha Williams
    Burretha Williams Feb 12, 2014
    Thank you Joel Baleta. It worked!
Ricoh copy, printer,fax sp100sfe all in one is showing error code sc541. how do i clear
this was translated from Russian by Goggle so.....read it carefully they construct sentences differently than we do...
SC-541: The temperature of fuser defined thermistor
is less than 0 ° C for 5 s.Temperatura fixing reaches + 15 ° C (
center) or + 12 ° C (at the edges) 5 times for 2 min after the lamp Fuser.
Login to the service-yellow, 107 red (hold 3 seconds) 5-810-1.
Enter SP 5-810 (SC code reset) and select "1". Then hold down the Original type key and the OK or! key at the same time (this does not require the main switch to be turned off and on).
If the reset - does not help, clean the thermistor!nail varnish cautiously take off with it, only - film does not tear ... can also cautiously cloth soaked in acetone scrub
Google Translate
Nov 07, 2014 | Ricoh Aficio Office Equipment & Supplies
Three in one copy, fax and printer ricoh sp100sfe is showing error sc541 .how do i clear it
Nov 07, 2014 | Office Equipment & Supplies
SC542 PROBLEM IN PRINTER
SC 541 is a fixing unit error, clean the thermistor and then reset the code by pressing clear(yellow) then 107 and hold stop(red) key for 5 to 10 seconds then the display change. now turn off the machine from main switch, wait for five second and then turn on the machine.
this will reset the SC541. in case if the problem exist change your thermistor and check the thermostat.
Oct 31, 2014 | Ricoh Aficio CL3500N Laser Printer
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Aug 28, 2014 | Office Equipment & Supplies
Our copier reads an error message of SC541
this problem can be solved by pressing the yellow button,then enter 107 and hold down the red button till the screen changes to copy SP,press OK or 1.The macine will now be in service mode.switch the machine off then on again.if it go into SC541 again the problem lies with the thermistor of the fuser unit
Mar 07, 2011 | Savin Office Equipment & Supplies
Service Code - Fucntion Problem within the copier - Code SC541 Serial # of Mach J0122404128
this is a fuser code
try this:
1. Press the clear mode key (yellow key)
2. Use the keypad to enter "107"
3. Old down clear/stop for at least 3 secunds. (red key)
4. Enter the service mode.
5. Exit all the way and turn off.
6. Turn ON.
if that fails, contact technical support. It will be necessary to replace the fuser roll and the thermistor
Jan 24, 2011 | Gestetner 2212 Digital Imaging System...
Showing error message sc541
this is an error for the fuser the thermistors have not registered the temps properly check the fuser and if you know how to take it apart clean the thermistors.. you could try an sc reset using the following proceedure...Yellow clear button then 107 then hold down the stop button..wait for the screen to change to show copier sp turn off the machine and wait 5 secs then turn off. If this doesnt reset do the same proceedure on the copier sp enter this then look for mode 5. enter this mode and look for 810 sc reset and set this then turn off wait and turn back on....if this error occurs regularly the thermistors will have to be changed.. hope this helps..A
Jun 28, 2010 | Lanier Office Equipment & Supplies
Gives code sc541 on Ricoh 1035
Clean the fuser thermistors.For reset enter in the service mode : press total clear (yellow)key-107-clear(red)key,touch SP mode,open the front door and turn OFF the power switch.Unplugged the machine,wait 10 sec.,plugged the cords,close the front door amd turn ON the power switch.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
RICOH FT5832 ERROR CODE E-5 47
With the machine on, press clear modes(yellow button), 107, and then hold down clear/stop (red button). Enter 5810 then # key then 1 #. Turn off the main power then power back on. This code is a fuser lamp on condition. It should clear. If not reseat the fuser unit (gets hot), clear using above procedure and try again.
Apr 08, 2009 | Ricoh FT5832 Copier
Code 541
hi!!!!!
may be the was damaged
or
try to clean use dry tissue
or replaced the drum
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 1035 Copier Logo
155 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
