Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
I had error 195c init unable 73 - Brother DCP 165C Compact Color Inkjet Multifunction Printer
5 Suggested Answers
  • 60 Answers
SOURCE: machine error 48 or init unable 48
There are several issues that pertain to this code, including a service update. If your printer is still under warranty – visit your local ASC, find one here, this issue is covered! First off, the Service Update, the encoder strip needs to be cleaned with a lint free cloth. The encoder strip is responsible for relaying the position of the print head to the main pcb. If the encoder strip gets dirty, many different problems can occur. The encoder strip is exposed, which allows grease, paper dust, finger prints, ink, etc. to get onto the encoder strip. (The white strip when you open the scanner cover)
If the machine still errors, the encoder strip needs to be replaced – Part Number LS4467001
If the machine still errors, replace the carriage PCB assembly – Part Number LS6543001
If the machine still errors, replace the Printhead – Part Number LK3211001
If the machine still errors, replace the Main PCB assembly – Part Number LT0284011
THANK YOU FOR USING FIXYA! – DON’T FORGET TO RATE OUR SERVICE!
Posted on Feb 03, 2010
Mix-it-up
  • 832 Answers
SOURCE: unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
Posted on Mar 13, 2008
yooperbud
  • 8637 Answers
SOURCE: unable to init massege erro
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
SOURCE: Brother DCP-195C Compact Colour Inkjet error
brother dcp 195c 46 error
Posted on Dec 24, 2010
Please solution about Brother printer "Init Unable 48 error brother dcp-195c
Look inside the printer using some light. If you do not find anything like piece of paper, or paper clip, etc then you most likely have a faulty printhead.
May 30, 2017 | Brother Office Equipment & Supplies
UNABLE TO INIT 4F BROTHER DCP-195c CAN'T TO PRINT.LCD SHOW UNABLE TO INIT unable 4F. my brother printer when on the screen show unable to print. how to solve the problem ?
The printer have its own initialization but seem to fail to complete initialization process. Check and clear the carriage jam, open check for motor failure in the carriage system.
Dec 18, 2015 | Brother DCP-195C Inkjet Multifunction...
How to clear "unable to init.73" in brother dcp-j125 printer?
Hi
This is a mechanical problem of some description. Open the scanner cover and remove any foreign objects and paper scraps from inside the machine. Then, disconnect the machine from the power for several minutes and reconnect it. This should clear the error, but if it does not repeat the procedure making absolutely certain there is nothing in the printer obstructing the paper path.
You can get a manual for this machine here:
http://data.manualslib.com/pdf2/36/3557/355673-brother/dcpj125.pdf?5f68814c3d046699f5763ce9725a25e1
and there is a manual resetting procedure that you might try here:
Reset Methods for All Brother Printer Models
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 29, 2014 | Brother Dcp-J125 Compact A4 Colour Inkjet...
How can I fix DCP-195C unable to Init 4F?
Could be print head or print head PCB problem .
Sep 06, 2014 | Brother DCP-195C A4 Colour Inkjet...
Init unable 50
Set the maintenance unit into place, if the planetary arm does not
move smoothly, clean it. purge cam switch harness not connected correctly,correct the connection,purge cam switch broken replace the maintenance unit, gear(s) on the maintenance
unit broken paper feed motor defective replace the engine unit,
power supply PCB defective replace the power supply
PCB. Main PCB defective replace the main PCB.
Dec 02, 2013 | Brother DCP-195C Inkjet Multifunction...
Printer brother DCP-195C how i can repair the error on printer screen "INIT UNABLE 50"
I have brother DCP-195C but having problem with no power.. pls help me to solve it..
Oct 23, 2010 | Office Equipment & Supplies
INIT UNABLE 5A , brother DCP-195C
How can i fix brother printer dcp-195c error Init unable 5A
Oct 22, 2010 | Brother Office Equipment & Supplies
Init unable AF, DCP185c
brother dcp 195c init unable af problem solve solution
Apr 04, 2010 | Brother DCP 165C Compact Color Inkjet...
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
144 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
