Question about Canon PIXMA iP5000 InkJet Photo Printer
Canon pixma ip 5000 error del operador la luz de encendido verde parapadea 5 veces en naranja
3 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: me sale un foco en color naranja
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
pineworks
  • 4041 Answers
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
Hola me sale cambiar fusor en una impresora oki b6200 como quito ese error sin cambiar el fusor
Acci?n:
Encendido y espere hasta que la lista para imprimir el mensaje aparece en el panel del operador.
Pulse el bot?n "Seleccionar y el bot?n de flecha hacia abajo al mismo tiempo"
El men? siguiente aparece "Reiniciar contador del fusor U4"
Pulse el bot?n de flecha derecha
Panel del operador mostrar? "Fuser U4 Utilice el SEL para Reset"
Pulse el bot?n SELECT
Panel del operador leer? "Clearing"
Pulse la tecla Men? para volver al "Modo Listo para Imprimir"
Aug 31, 2012 | OKI B6200 Laser Printer
Parpadea la luz verde de encendido .la luz roja de lamp tambien
SOY NICO,Jose si es la D que parpadea es el sensor ,3 gear pressure switch tienes que cambiarlo, me pasaba lo mismo lo cambie y problema resuelto,cuesta 67 dollars con los taxes en el dealer,lo puedes cambiar tu mismo,busca este codigo en internet P0845 y mira las fotos donde esta ubicado,esta es la imagen ,quita la rueda del lado del chofer y lo veras,para cambiarlo desconecta el negativ bateria,,4_28_2012_1_09_18_am.gif
Apr 22, 2012 | Cars & Trucks
Que significa chekch
Una señal luminosa "check engine" le está diciendo que la computadora que controla el motor de su auto ha detectado un problema que causa que el vehículo produzca excesivas emisiones. En ocasiones la luz será acompañada por una notoria serie de problemas en la respuesta del carro, como pérdida de poder del motor o dificultades para encender, pero otras veces el vehículo puede operar "normalmente".
Las fallas comunes que pueden causar que se encienda el "check engine" incluyen:
- Falla en componentes del motor como los sensores de oxígeno, temperatura del refrigerante, presión interna (MAP) o de flujo de aire.
- Motor que no enciende debido a fallas en las bujías, cables, componentes del encendido, inyectores de combustible u otras partes del sistema de combustible.
-Fallas en el sistema de control de emisiones como mangueras de vacío rotas o sueltas, el tapón del tanque flojo o desaparecido, o una defectuosa válvula de recirculación de combustible (EGR).
Si se enciende y luego se apaga tras unos instantes, puede ser un problema momentáneo en el sistema. La luz se apaga cuando el problema se detiene, pero la computadora debe haber guardado un código de diagnóstico de problema en su memoria. Si la luz no regresa, puede ignorarla. Sin embargo, si la luz se enciende y apaga intermitentemente, lleve el vehículo para que lo revisen y puedan escanear el computador para determinar que codigos de falla hay almacenados en el.
Suerte (recuerca calificar y comentar esta respuesta).
May 14, 2011 | 2004 Chevrolet Impala
Como activar remoto
Al momento de programar un nuevo remote el codigo anterior se borra por lo que el resto de remotos quedar?n inactivos por lo tanto todos los remotos que tiene deben ser programados al mismo instante, ademas ubique el boton de valet antes de proceder a programar.
Si Ud. tiene un remoto de 1 via (sin pantalla)
inserte la llave del auto en el switch y muevalo hasta la posici?n de on ( no es necesario prender el auto), luego regrese enseguida a la posici?n de off. esta sequencia por 3 veces, osea
1.- On - Off; On - Off; On. la llave se queda en on a la tercera vez.
2.- La sirena sonar? 3 veces
3.- Presione y mantenga presionado el bot?n de valet por 5 segundos
4.- La sirena sonar? 5 veces y la luz de la alarma se ilumina
5.- Presione el bot?n #1 (candado) en el primer remoto
6.- La sirena suena una vez
7.- Nuevamente presione el bot?n #1 en el primer control
8.- La sirena sonar? dos veces indicando que esta programado el remoto
9.- Repita los pasos 5 y 7 con el resto y cada uno de los remotos
10.- Regrese la llaves a la posici?n de off
Si Ud tiene un remoto 2 vias (con Pantalla)
1.- Inserte las llaves en el switch On -Off por cuatro veces dejando en On a la cuarta vez (On - Off; On - Off; On - Off; On.)
2.- La sirena suena 4 veces
4.- La sirena suena 4 veces y la luz de la alarma se enciende
5.- Presione el bot?n #1 en el primer remoto
7.- Mueva la llave a la posici?n Off
8.- Repita estos pasos del 1 al 7 para otros remotos de 2 vias.
Mar 02, 2011 | 5000RS-2W-1 Remote Starter with...
Cambie el filtro por uno nuevo y la luz sigue prendida en rojo como cambio a color verde
Una vez que filtran la luz se vuelve roja, sigue siendo rojo hasta que se resetea. Para restablecer el indicador del filtro, presione ambos LOCK y DISPENSADOR DE AGUA
botones simultáneamente y mantener durante 4 segundos. Hacer luz verde que parpadea tres veces cuando el indicador
se restablece.
Feb 05, 2011 | Maytag MSD2655HE Side by Side Refrigerator
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
I have a Samsung that say Transfer Belt Error
Hi
I have a utility to reset the consumables errors on this printer, but only if the component is past its lifecount. (60k for transfer belt)
Its called CLP-300_Reset_RLCv04.exe or just RLCV-04.exe (if you can find a copy)
If you need a copy, let me know and I'll find some way to get it to you.
I've used it for transfer belt reset and it works.
Dec 19, 2008 | Samsung CLP 300 Laser Printer
Pixma MP160 not faxing
ERROR E27
Hola gente no lo consigo ni por un lado ni por otro.
Alguien lo ha conseguido ???
Sigo las instrucciones al pie de la letra:
Describo las teclas que he usado:
parar -> tecla en roja que tiene un circulo y dentro un triangulo
on/off -> tecla que pone on/off arriba
1- Pulso y mantengo pulsá la tecla de parar
2- pulso y mantengo "on/off" y suelto parar
3- teniendo pulsada "on/off" pulso dos veces para y en la segunda suelto para y on/off
4- la impresora se enciende y pone un cero en el contador
5- pulso una vez la tecla parar se enciendo la luz de la izquierda que es naranja la que esta con el triangulo y un rayo dentro
6- pulso otra vez para y la luz se va a on/off
7- pulso para otra vez la luz pa la izquierda es decir triangulo y rayo
8- pulso otra vez para (ya van 4 veces) y la luz pasa a on/off
y ahora que....
por que yo pulso ahora on/off y la impresora hace ruido pero la apago la vuelvo a encender y las luces de falta de tinta, es decir la de la B y la C siguen encendida
no se que hacer he mirao por todos los foros del mundo estoy a punto de tirarla por la ventana y comprarme otra
saludos
Apr 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA iP5000 InkJet Photo Printer Logo
566 people viewed this question
old marine
old marine
