Question about Gateway MT3418 Notebook
The transformer box is getting hotter than it usually does. And it does not now give a blue light on the LH light of the pair on the front of the computer, but a pink light. The part is the mains plug at one end, plugs into a box in the middle and then into the power plug on back of computer.
  • 89 Answers
Hi I guess your battery pack is need to replace thats why your adapter is getting hot due to battery pack leakage and is not charging normally. thanks
Posted on May 28, 2011
Why doesn't my neotv netgear remote no longer communicating with box?
What do the different Remote control front LED lights mean?
  • Blink blue color twice per second: Remote control has paired NeoTV PRIME and is trying to connect NeoTV PRIME.
  • Blink blue color once per second: Remote control is trying to pair the NeoTV PRIME.
  • Orange blinking: Remote control battery is low. Please replace a new set of AAA battery.
go to page 15 of the following document:
http://www.netgear.com/landing/stream/img/gtv-specs/GTV100_IG_25Oct2012.pdf
Sep 09, 2014 | Computers & Internet
Turn signal lights not working. turn on emergency flashers and the right signal flashes and bath back lights and the front right flash but the left front don't. any idea's
The 2 filament on the LH Front turn signal is most likely burned out, ...........or the ground to it, & the entire socket needs replaced. Caution lights, send signals to ALL FRONT & REAR lights. All turn signal lights must be in working order, as it is a "pulsating" currect surge sent to the bulbs, LH or RH, depending which direction you wisk to turn. If 1 filament is broken, the circuit is incomplete, & no flash will occur. Usually you will get one light that stays on, & the front or rear missing lighting, is the one whichis the culpret.
Aug 29, 2011 | 2001 Ford F150 Styleside SuperCrew
My plantronics Bluetooth will not go into pairing mode no matter what I do. I held down the call button and it does work. Are there any other alternatives?
When you hold down the call button do you get a red then blue flashing light? This is pairing mode. (also the only way to get this headset into pairing mode) Make sure the phone is close to the Bluetooth headset. For most phones pairing a headset is done by
  1. Settings/Tools > connections > Bluetooth > On (your phone manual will have all the specifics but this is usually the buttons)
  2. Turn your headset on (on/on switch) and wait till the indicator flashes red then blue.
  3. Set your phone to "discover" or "add a device" which steps are usually - setup > connect > Bluetooth.
  4. Once available headsets are available select your headset. If it asks for a code the generic code is 0000
  5. A successful pair is indicated by a blue light and also a confirmation on your phone.
Regards, Tony
Apr 20, 2011 | Plantronics Explorer 240 Bluetooth Headset
Cant get it to woork blue light just blinks
you have to put ur bt device into pairing mode in order to pair it to a cell phone usually when u turn your bt device on you continue to hold the power button for 6 to 10 seconds and when you have a solid light you are in pairing mode then your cell will pair to your device,it will ask for a pin or pairing code,most blue tooth manufactures use a 4 digit code.the codes to most blue tooth devices are as follows 0000,1234,9999,or 1111.i hope this helps
Feb 20, 2011 | Jabra BT125 Headset
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
THE TV WILL NOT POWER UP
It depends on a lot of other things, but you could try these steps . . .(assuming its a TFT flat screen)
Has the mains fuse blown ? try a different mains cable.
If it works from a power supply/mains transformer (a small box attached to the mains supply cable), check that box - they usually have a small green light on them to show they are getting power. These are easily replaced if that part is faulty.
Has the power cable come detached from the rear of the TV ?
Does a power light appear on the actual TV front (usually blue or green), and then go red (or off) after a few seconds. In that case the screen has a more hard to fix problem inside :(
Apr 04, 2010 | Sylvania LD370SS8 37 in. LCD Television
My tail lights will not stay on. They keep going out.As a matter of fact, i don't think they come on at all now.
You may have blown a fuse or two. Have you checked fuses?
RH Tail, Number plate = C7 RH box
LH Tail, Number plate = C7 LH box
RH Reverse, Rear Fog = B8 RH box
LH Reverse, Rear Fog = B8 LH box
burnt diodes on the back of the dash can give this fault also, have somebody check the electrical contacts...
Feb 28, 2010 | 1994 Jaguar XJ6
My samsung wep 301 will not pair with blackberry 8330. In the desktop manager, the check box to enable bluetooth support is greyed out. Windows 7 BB Desktop 5.0.1 Samsung WEP 301 Blackberry 8330 I'll take...
Please rate. This is how we (advisor/problem solvers) get people to know...we know what were doing. Thanx
1.First make sure your phone is off. Do this by pressing and holding the Multifunction button (the one that flashes blue) for 4 seconds. For "OFF" it will flash blue and red along with a series of 2 tones. Then will stop flashing. For turning "ON" hold multifunction button for 4 seconds and it will flash BLUE 4 times and 1 tone indicating it is on. It will continue to flash every 3 while in stand-by mode and every 8 seconds while on a call. 2.Set your phone in "Discover mode" make sure you look at your manual on how this is done if don't know how. Usually found under Bluetooth settings. 3.Making sure your headset if off. Press and hold the Multi-Function button until the indicator light turns solid blue (hold for approximately 8 seconds). THE MULTIFUNCTION BUTTON WILL BE LITE ONLY HALF BLUE INDICATING PAIRING MODE. 4. You phone will find and ask to pair. Press confirm/OK and enter "0000" 5.If pairing successful, light will flash blue 10x rapidly before going to flash every 3 seconds. IF UNSUCCESSFUL LIGHT WILL REMAIN ON, AND YOU WILL HAVE TO RE-ATTEMPT.
Jan 15, 2010 | Samsung WEP410 Bluetooth Headset Wireless...
Blue LED light connection from Bezel to Motherboard
red white is the pair that supplies power it should be 2pin socket on motherboard
Sep 19, 2009 | E-Machines T6520 PC Desktop
HOW TO INSTALL A MOTOROLA H550 BLUETOOTH HEADSET
Usually to pair a new device like that, there would be some trick to set it up. Im not familiar with your exact model, however ive had success with holding some buttons in.
Usually you would hold down the power button, or perhaps the volume up and down together, hold them down for a few secs and the light will go blue/red/blue/red to show its in pairing mode.
Jun 18, 2008 | Motorola Mobility H550 - Bluetooth Headset...
Gateway MT3418 Notebook Logo
57 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
