Question about ASUS P5QC Motherboard - Intel P45, Socket 775, ATX, DDR3/DDR2, Audio, PCI Express 2.0, Gigabit LAN,
Atheros gibabit lan only work to 100 mbs in xp x64. what is the problem ?
Where do i get the ethernet driver for my mpc clientpro 414
ClientPro 414 Ethernet Driver >>Click here to download Windows XP Broadcom NetXtreme Gigabit Integrated 10/100 Fast Ethernet LAN DriverClick here to download Windows XP x64 Edition Broadcom NetXtreme Gigabit Integrated 10/100 Fast Ethernet LAN Driver
Oct 21, 2011 | MPC Computers ClientPro 414 All-In-One PC...
Replacing ethernet PCI card 10/100 by gibabit 1000
When you replace and install LAN card you need to install also the driver. Be sure that your onboard ethernet PCI card are disabled in BIOS. So that the new install LAN card are working.
Regards
PCmania
Sep 26, 2009 | Dell Ethernet Card Network Adapter
Please explain the difference between Intel ATX board D865GLCL vs. D865GLCLK.
Hello edk2,
Here are the diferences in the models of motherboards:
D865GLCLK: Video, Audio, Gibabit LAN D865GLCL: Video, Audio, 10/100 LAN D865GLC: Video, Audio
This means that the D865GLCL has the Fast Ethernet LAN Interface on-boardwhile the D865GLCLK has the Gig-E LAN Interface on-board. However, the D865GLC does not have an on-board LAN Interface.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 27, 2009 | Intel D865GLC/ D865GLCL/ D865GLCLK MB,...
Lan and wireless driver for toshiba a135-s2246
Unfortunately, the Toshiba Satelite A135-S2246 was never designed to run XP, only Vista. Which is why you can't find any drivers for XP. The nearest you can get is to find a laptop running XP SP2 that is using the same LAN (ethernet controller) and WLAN (wireless ethernet controller), and see if they will work.
Here are the drivers I found for XP (please check which one's you are trying to install):
Atheros WiFi card driver:
http://www.wireless-driver.com/download/atheros/2007-7-23/Atheros-ar5bxb6-AR5424-mini-PCI-E-Wireless-Card-Driver-Download.htm
Intel WiFi card driver:
http://downloadcenter.intel.com/default.aspx
You will need to search for the card that you have.
LAN (ethernet controller):
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=6&PFid=6&Level=5&Conn=4&DownTypeID=3&GetDown=false#1
You can pick third or fourth from top depending on your preference.
Please remember that Toshiba, Microsoft, Atheros, Realtek, Intel and especially myself accept no responsibilty for what may, or may not happen when installing drivers not specifically designed for your system. All that said, I hope it works for you.
Dec 05, 2008 | Toshiba Satellite A135-S2246 Notebook
XP Ethernet driver for compaq f739au
XP Ethernet driver for compaq cq40-116tu
Jun 08, 2008 | Computers & Internet
Wireless LAN problem
Make sure that the built-in wireless lan is disabled. If your pc is XP or vista, uninstall the new WIRELESS LAN(go to control panet, add/remove programs), select the Atheros Software. Leave the WIRELESS ADAPTER connected to your pc. Insert the disc, do not run the set up. RESTART THE PC. The drivers for the WIRELESS ADAPTER should install, if not load drivers manually.
MAKE SURE WIRELESS ZERO CONFIGURATION for XP is running. You should be able to detect wireless networks.
Mar 15, 2008 | Computers & Internet
Open Questions:
ASUS P5QC Motherboard - Intel P45, Socket 775, ATX, DDR3/DDR2, Audio, PCI Express 2.0, Gigabit LAN, Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
