Question about Cell Phones
I have a DVD that is stuck in my LG television.
    Genius:
  • 1,622 Answers
Hi,Ok look at the DVD drawer carefully , you will see a tiny hole , this hole is expressly to eject the DVD when the electronic eject has failed . Take an ordinary paper clip and straighten it out . now insert the clip into the hole and press , this will release the drawer mechanism and with it your lost DVD Too easy !!!
Also
Removing the back cover would only allow you access to the frame and shields which must also be removed. Thereafter the DVD deck must be removed and repaired or replaced otherwise the TV will not be usable as it will still be locked in DVD mode. The system is waiting for a trigger pulse from the DVD deck that the disc has been released / ejected before it will accept any command to switch to other sources.
Unplug the unit for an extended period of time (an hour or so). The ides is to discharge and force the system to revert to factory defaults. Thereafter, try the above again. Should that still be not corrective, then perhaps your best bet would then be to consult with and/or seek the services of an authorized Service Center (specially if still under some form of extended warranty) or a qualified professional
if the DVD unit uses a slot type entry, have you tried using a credit card like something to 'fish' / 'jar' the erring disc while pressing on the EJECT button? Spraying with a can of compressed air through a nozzle like tubing may also be considered. The idea is to float the disc to initiate the eject procedures. A likely possibility is that the center hole of the disc is stuck to the spindle of the player.
Good luck and thank you
Posted on May 28, 2011
How to remove stuck dvd from lg blu ray
sounds like the disk may be sticky on top and is now stuck to the chucking clamp. Try to cut power as the door tries to open, then open the door as much as it will aloow and you should be able to fish the disk out. If it is stuck, you may have to push down the disk with a screwdriver to release it.
Jul 28, 2014 | LG Televison & Video
Dvd is stuck and wont eject
I would like to know how to remove dvd from hdlcd combo tv
Feb 27, 2013 | LG 32LG40 32 in. LCD HDTV
DVD disc stuck in vision plusTV/DVD combo
There should be a tiny hole somewhere on the front of the DVD tray, where you put the disk in. If it's not on the tray itself, it should be very close to it. Bend a paper clip out a bit, and carefully press it into that tiny little hole, and the tray should open up. If that doesn't work, then it's physically jammed, and mechanically unable to open.
Jan 31, 2013 | LG 32LG40 32 in. LCD HDTV
DVD disc stuck in built in dvd on LG LCD TV/DVD combo
1. Power the set down.
2. Hold the eject button on the drive while you plug it back in and power it back up.
That should eject the drive.
Aug 29, 2011 | LG 32LG40 32 in. LCD HDTV
LG DR787T Multi DVD Recorder is stuck. When I turn on unit it is stuck on hello. It flashes or blinks but will not do anything else. Can not open tray drawer.
If the problem isnt solved by a Unplug and plug back in, it will be a return to LG issue I am afraid, this unit is prone to faulty Hard drives and Power units, both of which can cause this error, there is no way to disern which one is causing it
May 11, 2011 | Televison & Video
Aloha I put the DVD in the Tv/ DVD and it didn't turn on, won't eject. Stuck :( Laurie
Same thing just happend to me this week - same TV about 1 year old! Any ideas how to get it out?
-Andy
Aug 22, 2010 | LG 32LG40 32 in. LCD HDTV
There is a DVD stuck in the built in DVD player in
try unpluging set while tv is on and plug it back in it should come out
Feb 03, 2010 | LG Televison & Video
Dvd player thinks it's loading a dvd but there is no disk in the player. it won't stop trying to load after turning power off, ejecting, etc
Unplug the TV.
Use a flashlight and look inside the player you may see a DVD or a label from a DVD inside.
If you are sure theri is no DVD stuck in the player then the player may need to be replaced..
Contact LG @ 1800 243-0000 The TV has a 1 year full warranty.
If you are past the 1 year they may help you with the repairs just be patient and polite.
Jan 13, 2010 | LG 32LG40 32 in. LCD HDTV
Trying to program my dvd player with my lg tv remote
Turn on dvd player by hand using your lg tv control push set up dvd plus code.pointing for 15 seconds.
Nov 19, 2008 | LG 32LC7D Television
Cell Phones Logo
125 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
