Question about Refrigerators
I have a refrigerator Bosch Model KSU45621AU Auto frost and the Fridge compartment is not running at a cold temp can you help Please. Thanks Ali
  • 17,129 Answers
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Posted on May 28, 2011
Maytag dual cool
Frost buildup in freezer is an indication that there may be air being drawn into either the fresh food section door seal or the freezer door seal. Your model has a 61005543 Air Damper
That may also be either defective or stuck in the open position due to frost buildup. You are just going to have a look behind the rear wall of freezer to see what is going on. Unplug first before servicing. If you would like me to upload a Service Manual please let me know, John Tripp Appliance 911
Contact Me Here
Mar 09, 2014 | Refrigerators
Siemens ka..n freezer problem
Look inside the back wall of the freezer to see if you have a layer of frost building. If yes this will indicate that the refrigerator is missing its defrost cycle. When you miss defrost it is usally number 1 the defrost control. Number 2 is the defrost heater has burned out and #3 the defrost thermostat. For you to look up the correct replacement parts you will need to find your refrigerators model number found most times inside the fresh food compartment. Click Here for=> Bosch Refrigerator Defrost ControlsI will be here to answer any questions you may have or if you have your model number let me know and I will help you find the parts you need, Thanks Sea Breeze
Feb 16, 2012 | Bosch Refrigerators
Fan in freezer is making a real bad sound...... griding like it may be struggling to to stay running
This can be caused by frost accumulation on or aroundthe freezer fan Icing . And due to this no cooling will be in fridge compartment.
Unplug power and . defrost it. And after some times, switch on fridge.
This is due to auto defrost switch malfunction. keep temp setting at 5 degree and check auto defrost (if your fridge having that option) is working. If not you have to replace PCB. Thanks.
Jan 28, 2011 | Maytag Admiral Top-Freezer Refrigerator
Bought a brand new LG bottom freezer fridge a couple of months ago. I like the refridgerator part to be cold, so we keep the fridge temp on 6 (1-7 are temp choices. 7 being the coldest). We had the freezer...
If designed as most combination units, one of the two controls influences the temperature directly, the other only determines how much of the generated cold air is allowed to enter the other compartment. The typical arrangement is that setting the freezer temperature determines how often often the compressor runs; the other diverts a portion of the cold air into the refrigerator side.
Using the common thermometer for cold temperatures (~$5 US), adjust the freezer temperature for 0 to -5 degrees F (the often recommended temp.), then the other control for the desired refrigerator temperature, suggested as 35-45 F. This is the most common practice.
If you cannot balance them the way you want, reverse the procedure, setting for refrigerator temp., then freezer.
Dec 13, 2010 | LG LBN22515 Bottom Freezer Refrigerator
Hi, I have a Bosch intelligent frost free 44 which I bought second hand a few days ago. Manufacture date appears to be 2006 and was told it works fine but I am not sure. When I first turn fridge on the...
I think it's the freezer fan that stopped working,open the freezer and see if it goes you should hear it running and even see.This fan allows the cold air into the fridge compartment,without it it takes ages for the fridge to get cold.I've got the same problem if you find the motor online let me know on alvalen31@hotmail.com
Nov 03, 2010 | Bosch Refrigerators
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Mar 14, 2009 | Bosch Refrigerators
Frost free fridge freezer the fridge isnt staying cold we have tried turning the temp up and down but it makes hardly any difference.
you need to find out what going on in the freezer,is the fan running?is there frost on the back wall?let me kn ow and we can go from there,mike
Sep 12, 2008 | Bosch Refrigerators
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
