KXR00 I have a panasonic elfec electronic typewriter r200 and I don't have a manual. I am having trouble setting the Left & Right Margins Regaards Lesley
I have a manual...
To clear margins and have do the following: depress the "return" key so the carriage returns to the left margin. Then depressed the "code" "tab clr" keys.
To set margins and tad do the following: clear your margins in tabs using the steps above. Depressed space bar until you reach the desired left margin. Depressed the "L. MAR" key... you're left margin is now set. Depress the "space bar" until you reach the first required tab stop. Depressed the "tab set" key... your first tab stop is now set. Repeat steps 4and 5 for each tab stop required on the writing line up 13 can be set on each line. Depress the spacebar to move the carriage to the desired right margin. Depressed the "r. mar" key. Finally depress the return key.
Posted on Sep 19, 2011
Have you got a copy of the manual??
Posted on Nov 29, 2011
Do you know how I could find a manual to the Panasonic T40 Electronic typewriter?
Suzanne, Links below are what I could find as far as manuals or instruction on your typewriter.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Operate Panasonic Typewriter eHow
Original PANASONIC RK T40 Electronic Typewriter Operating Instructions...
http://www.jlaforums.com/viewtopic.php?t=206133038
Panasonic Typewriter Manuals and User Guides
Apr 17, 2016 | Office Equipment & Supplies
Users manual for Panasonic KX-RD 20TH typewriter
Search Results
    [PDF]PDF file created from a TIFF document. - Support - Panasonic
    service.us.panasonic.com/OPERMANPDF/KXE3000.PDF
    PanasonicKX-E3000. Operator's ... accessories recommended in these operating instructions or supplied by the ... typing with one ofthe most advanced electronic typewriters available... 0 Storing Margin Formats ln Memory ..... Set the first TAB at 20.
    Panasonic KX-R530 - Electronic Typewriter Operating ...
    www.manualslib.com > ... > KX-R530 - Electronic Typewriter
    View and Download Panasonic KX-R530 - Electronic Typewriter operating instructions manual online. Operating Instructions. KX-R530 - ElectronicTypewriter ...
Jan 12, 2016 | Panasonic Lands Phones
I have an Olympia Progress manual typewriter. It seems to be in good working order, well oiled and good action in the keys, except the carriage won't advance when I type. I don't believe the...
try typing with a little pressure on the carriage (push with right hand to the left) if it work like that then the carriage pull cord may be broken
Apr 23, 2013 | Office Equipment & Supplies
What do I press to set my left and right margin on the swintec typewriter 7040
Go to the margin you wish to change, PRESS BUT DON'T HOLD the MAR REL key space or backspace to the desired location press L. or R. mar key.
DickyO
Feb 18, 2012 | Swintec 7040 Typewriter
Brother LW-100
After a bit of research I was able to find a LW100. You throw me off track by saying that it's a "manual" typewriter, electronic typewriters that do NOT have memory are generally called manual. The LW100 is a mechanical typewriter. I am sorry to say that I do not know where to get a manual. But I might be able to help a little, All mechanical machines did not have "ribbon lift", if you know that the ribbon used to lift for each key strike then you would have a latching arm or a spring that is not doing it's job. People that use typewriters that DON'T lift the ribbon feature, have to resort to rotating the platen to see the paper. Best of luck to you, cheers (BTW, I was stationed at RAF Lakenheath for 3 years, and Loved it. I wish I never left there.)
Nov 17, 2011 | Brother Office Equipment & Supplies
I know this is a long shot, but I want to increase the amount of characters I am allowed on my Panasonic KX R200 electronic typewriter. As it was given to me secondhand, I am short of the manual, and am...
There should be a margin release key. It may say MAR REL or Be 2 vertical lines with arrows or a key with mar rel printed above it that requires the use of the code key. When you stop press MAR REL space to desired R. margin mlocation press R. MARGIN KEY.
DickyO
Oct 16, 2011 | Office Equipment & Supplies
I just baught a Panasonic KX-E4000 electronic typewriter that doesn't have a manual. Can you help me set the right and left margins. There is a 'code' key but no r margin or l margin.
Look again. I quarantee you somewhere on or around the keyboard there is a L MAR and a R MAR. I don't have a 4000 so I can't tell you exactly where When you find it, move the carrier to where you want the mar. set and push the appropriate key. If the carrier stops before you get to where you want to set the margin, hit the MAR REL key and use the SPACEBAR or BACKSPACE KEY to move the carrier to where you want it. If the L MAR and R MAR (and MAR REL) is printed on the case, hold the code button down and push the key under it. If R MAR is printed on the same key as the L MAR, use the code button. These instructions will set the margins on virtually every electronic typewriter ever made.
Jan 07, 2011 | Office Equipment & Supplies
Changing correction tape
i have the same problem. can't find a manual anywhere. someone please help
Mar 10, 2009 | Brother ML-100 Typewriter
278 people viewed this question
k24674
