Hi.
Error 4 is internal leakage (overflow).
when this happens often the dishwasher starts with the pump running continuously.
Switch off the power from main circuit breaker, drain the inside of the appliance and clean the drain filter in the bottom panel of the tub. If problem persists, check the drain hose at the back. Ensure that it is not kinked, and that height is as from installation manual.
If that does not work, then the machine is faulty. Repair is done removing the kickplate at the base of the appliance, checking for water leak in there. Disconnecting pump hose and removing debris, testing the overflow switch by running a cycle with its contacts jumped. The inlet valve must also be checked to ensure that it is not leaking.
Turn off power and remove water from inside the appliance. Usually that is enough to sort out the problem.
Regards.
Ginko
Hi Ginko
Thanks for the Advice. The above what you have sugested I did already. I have tested all of the components seperatedly and all are funktioning. If all els fails I believe then that the Main PC board got dammaged. So I will replace the PC board and that should sort the problem.
Thanks
David du Plessis
