Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Hoover WindTunnel Self-Propelled V Belt
I replaced both belts and still the thin V-belt is loose??? Is there an adjustment that I am missing?
  • graylocks1 Aug 26, 2008
    my v-belt is loose. I have replaced it, and the problem persists. Makes all the right sounds, but the brush will not turn, and there is a smell of burning rubber.l
  • Anonymous Nov 13, 2008
    I ordered to v-belts figuring mine was to loosed to turn the agitator. The new belt did not help. I'm perplexed
Hi, That is what was happening to my Windtunnel. Until I looked at the little round disk "plastic". there was a crack in it and this puts pressure onto that V belt to make the brush spin. I have a replacement idler arm assy unit which has to be replaced. I hope this helps Cindy G.
Posted on Aug 16, 2008
SOURCE:
How to stop the main belt from comming off the motor shaft on a hoover modle u6634-900/windtunnel
Hello there! If you have replaced the belt and it is still slipping off, you may be not have the right belt for your vacuum. This unit takes a flat belt and a v-belt. Make sure you are replacing the belts with Genuine Hoover Parts. I have included the links below where you may go to order the belts specific to your cleaner.
WindTunnel PowerDrive Belt 2 Pack
WindTunnel Self Propelled Belt
Hope this helps!
Jun 21, 2014 | Hoover Self-Propelled WindTunnel Bagless...
Hoover self-propelled windtunnel U6430-900 flat belt gets hot & becomes hard to push. It has a filter bag. Purchased 8/2/01. Took one plate off bottom. Used a compressor to blow out dirt & dust. ...
Belts get hot when fibers from carpet get wound arounf the belts mounting shaft. Best to take a razor and cut off any fibers so the belt doesn't get hot again
Aug 10, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
Why wont the self propelled brush on the hoover wind tunnel work. large belt is ok. the small belt looks 0k.
no don't do that,have a little patience.check where the self propelled assembly is and see if anything got in there,something might be loose and the teeth are meeting each other.thats a good vavuum.i have 2 but their not self propelled.try taking the belt off the self propelled machanisn and try it again.if it works then something is keeping the propelled machanism from working.dig a little deeper,what do you have to lose?
Mar 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover wind tunnel upright self propelled. U6473-900. Brush does not work. Heard it was a 'brush controller' problem and can be fixed. Please tell me how.
Most likely the flat belt has stretched enough so as to not turn the pulley that in turn turns the brush roll using a V belt. Also there is a small idler wheel, if hook up, then it won't engage the V belt.
May 20, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Self-Propelled WindTunnel by Hoover U6445906
· Sometimes grabs the carpet for no reason.
· Comes back too fast when I push it back.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Self-Propelled WindTunnel by Hoover U6445906 Without knowing the brand name or model number you may have the height adjustment to low and the vacuum will say “bite down” on the carpet of which will make the belt burn and might leave marks on the carpet – and if you have a self-propelled vacuum it does come back fast if you because you have a transmission just like a car and you have to control the speed of the vacuum or because it may have a weak belt the vacuum will pull back easier – I really would like to know the brand name and model number so that I could accurately give a better answer . Recommended belt change for flat belt(s) are 4 to 6 months for better cleaning and one a year for a geared belt – both can stretch and lose their cleaning function
Apr 05, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Replace the belt
Take off the bottom plate, put the new belt on the motor shaft first, then stretch it to go over the pulley, it is hard, but it will stretch to go over it.
Mar 27, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover Self Propelled Wind Tunnel Turbo Powered 7600 The thin belt too loose
If this is a "V" belt, make sure the small roller that tightens the belt is ok and not jammed up. It may have to be replaced. Also if the flat belt is stretched at all, it won't work either.
Nov 18, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
455 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
